lucasgg
Pi Servo Control - Stops Listening to Input
Wed Apr 11, 2018 3:54 pm
Using this script, pi stops listening to input immediately. The servo continues to hold/readjust its position, however.
import os
from os import system
import RPi.GPIO as GPIO
import time
from time import sleep
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
GPIO.setup(16, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
GPIO.setup(3, GPIO.OUT)
pwm=GPIO.PWM(3, 50)
pwm.start(0)
while True:
    input = GPIO.input(16)
    if (input == True):
         system('/home/pi/Desktop/175Degrees.py')
        duty = 175 / 18 + 2
        GPIO.output(3, True)
        pwm.ChangeDutyCycle(duty)
        sleep(0)
        pwm.ChangeDutyCycle(3, False)
        pwm.changeDutyCycle(0)
    else:
        system('/home/pi/Desktop/90Degrees.py')
        duty = 60 / 18 + 2
        sleep(0)
pwm.stop()
GPIO.cleanup()
*however* when I use this basic input listening script, it never stops listening in the time i have tested it.
import time
while True:
    if (input == True):
        print("input true")
    else:
        print("input false")
I am a beginner programmer
saltydog
Re: Pi Servo Control - Stops Listening to I`nput
Wed Apr 11, 2018 10:53 pm
If the servo is still working (moving), then it is still listening, isn't it?
Chris
joan
Wed Apr 11, 2018 10:59 pm
Python scripts need to be entered within code quotes for clarity, otherwise the formatting is lost.
pcmanbob
Thu Apr 12, 2018 9:45 am
copying your code from the quote screen and placing it between code tags
import os
import time
pwm=GPIO.PWM(3, 50)
pwm.start(0)
while True:
    if (input == True):
        duty = 175 / 18 + 2
        sleep(0)
    else:
        duty = 60 / 18 + 2
        sleep(0)
pwm.stop()
GPIO.cleanup()
import time
while True:
    if (input == True):
        print("input true")
    else:
reveals an indent error on your first system line.
my first question is what are the 2 python programs doing that you are calling using system ? if these never completed then your program will never return to continue with the code following them.
lucasgg
Thu Apr 12, 2018 1:31 pm
Chris
When the script is running, if I change the input, the servo does not respond or change its angle based off of the new input value.
lucasgg
Thu Apr 12, 2018 1:41 pm
import os
import time
pwm=GPIO.PWM(3, 50)
pwm.start(0)
while True:
    if (input == True):
        duty = 175 / 18 + 2
        sleep(0)
    else:
        duty = 60 / 18 + 2
        sleep(0)
pwm.stop()
GPIO.cleanup()
import time
while True:
    if (input == True):
        print("input true")
    else:
Please describe what a system line is. This will be a long journey of asking dumb questions for the sake of learning.
I probably should mention that I do not completely understand the from "x" import "x". I have figured out that it brings in a "part" of the operating system so that the code can interact properly. A brief explanation would be appreciated.
B.Goode
Re: Pi Servo Control - Stops Listening to Input
Thu Apr 12, 2018 1:59 pm
It is the line beginning system in your code...
    if (input == True):
        duty = 175 / 18 + 2
B.Goode
Thu Apr 12, 2018 2:39 pm
As a brief explanation what you have written is probably sufficient.
Rather than getting half-truths, if you need more detail it is probably best to refer to the official python documentation:
https://docs.python.org/3/tutorial/modules.html
It is unlikely that you will understand everything there at a first reading. (I certainly don't, after several attempts...)
lucasgg
Thu Apr 12, 2018 3:06 pm
    if (input == True):
        duty = 175 / 18 + 2
Oh, shoot! I forgot to remove that. I was experimenting if I could call on a separate python script to change the servo angle. It didn't work.
pcmanbob
Thu Apr 12, 2018 3:10 pm
    if (input == True):
        duty = 175 / 18 + 2
Then you may want to remove the second one as well that further down your code.
    else:
B.Goode
Thu Apr 12, 2018 3:12 pm
You could add some lines similar to:
print("Switch was True")
at appropriate places to track the execution of your script.
Or you could try running it with the Thonny IDE/editor which has some built in tracing to assist with debugging.
What is the intended purpose of the sleep(0) statements?
pcmanbob
Thu Apr 12, 2018 3:26 pm
So now I have had time to test your code I have removed all the errors including the lines that were not required or in error.
import time
pwm=GPIO.PWM(3, 50)
pwm.start(0)
while True:
    if (input == True):
        duty = 175 / 18 + 2
    else:
        duty = 60 / 18 + 2
    sleep (0.1)
the code now works in that you have 2 servo positions selected by pressing the switch.
by way of explanation.
pwm.ChangeDutyCycle(3, False) you only specify the new duty cycle with this command it has no true or false, removed lines.
GPIO.output(3, True) seeing as you are using this output for PWM you don't want to be setting it high or low as well as it will interfere with your servo pwm signal, lines removed.
sleep(0) pointless command so removed, but you do need a sleep to slow down your code so it does not run the processor to 100% usage, so added a single sleep (0.1) command in the while true loop.
pwm.stop(), GPIO.cleanup() removed these line as they would never be executed because you program had a while true loop.
lucasgg
Mon Apr 16, 2018 8:49 pm
Truly, I was experimenting with what affect they had on the code.
lucasgg
Mon Apr 16, 2018 8:57 pm
import time
pwm=GPIO.PWM(3, 50)
pwm.start(0)
while True:
    if (input == True):
        duty = 175 / 18 + 2
    else:
        duty = 60 / 18 + 2
    sleep (0.1)
I implemented your kind changes and the code is working exactly as desired. Now I will move into edge-detection to ease up on my processor. After all, I want this script to be running for long periods at a time.
Return to “Python”
