Parth1234
print the output using python
Thu Apr 05, 2018 7:07 pm
I am looking help with following python code.
# Main loop.
while True:
    # Read all the ADC channel values in a list.
    values = [0]*4
    for i in range(4):
        # Read the specified ADC channel using the previously set gain value.
        values[i] = adc.read_adc(i, gain=GAIN)
    # Print the ADC values.
    print('| {0:>6} | {1:>6} | {2:>6} | {3:>6} |'.format(*values))
    # Pause for half a second.
time.sleep(0.5
I want to replace below line
I want to print each output like value(0), value (1), value(2), value(3). like table of four variable. How to do that
paddyg
Re: print the output using python
Thu Apr 05, 2018 10:28 pm
The existing code looks to nearly do what you describe. Unless you mean you want to do something different?
see https://docs.python.org/3.5/library/str ... i-language for how format works
print('{}, {}, {}, {}'.format(values[0], values[1], values[2], values[3])) # *values is a curt way of doing this
elParaguayo
Fri Apr 06, 2018 6:03 am
What's the problem with your code? This line:
should work fine as paddyg says. You don't even have to use all the values in the same line. e.g. you can just do:
print('| {3:>6} |'.format(*values))
and the line is still valid.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Return to “Python”
