JanvE
Python & Matplotlib X Ax two hour time span from current time
Sat Mar 31, 2018 1:30 pm
Dear All,
I am looking for a solution to create a graph from the actual time + two hours ahead. So a graph with 20 points over a timespan of two hours. I don't understand how to configure the x ax in a way that it shows only the desired timeframe of two hours. Thanks for any help.
#Import modules
from xml.dom import minidom
import urllib.request
import csv
import matplotlib.pyplot as plt
from time import sleep
from random import shuffle
import datetime
from matplotlib.dates import DateFormatter
# create data
y = [ 2,4,6,8,10,12,14,16,18,20,18,16,14,12,10,8,6,4,2]
x = [datetime.datetime.now() + datetime.timedelta(hours=i) for i in range(len(y))]
# plot
form=DateFormatter('%H:%M')
plt.plot(x,y)
plt.gcf().axes[0].xaxis.set_major_formatter(form)
plt.show()
robbes
Re: Python & Matplotlib X Ax two hour time span from current time
Sat Mar 31, 2018 4:46 pm
I haven't looked at your program, but if you simply want to display a fixed number of data points, why not just
plt.plot(x[-20:], y[-20:])
robbes
Sat Mar 31, 2018 6:47 pm
After an interlude of profound thought, I expect I was not addressing the problem you were having. You probably need to read
https://matplotlib.org/api/_as_gen/matp ... ticks.html
Turn your datetime objects into strings first.
robbes
Sun Apr 01, 2018 4:41 pm
By default, matplotlib is inserting tick values where you don't want them, but these can be over-ridden with the MinuteLocator or HourLocator function.
Also, it is easier to see your data points if you suppress the default line style that matplotlib uses.
import datetime
from matplotlib.dates import MinuteLocator
x = [datetime.datetime.now() + datetime.timedelta(minutes=6*i) for i in range(len(y))]
fig = plt.figure()
ax = fig.add_axes([.1, .2, .8, .7])
ax.xaxis.set_major_locator(MinuteLocator(interval=6))
ax.xaxis.set_major_formatter(DateFormatter('%H:%M'))
ax.plot(x,y, marker='.', linestyle='None')
plt.xticks(rotation=90)
plt.show()
JanvE
Thu Apr 12, 2018 4:27 pm
import datetime
fig = plt.figure()
plt.show()
Ok, thank you!
Return to “Python”
