adrian5750
Python 3.5 & matplotlib - won't plot
Wed Mar 28, 2018 9:29 am
HI Folks
You know that feeling when something _used_ to work - and now it doesn't....?
I had a little Python program running quite nicely, reading temperature from a thermocouple and plotting in in real-time using matplotlib (application is monitoring the firing schedule on a glass-fusing kiln, temperature vs time)
The hardware was lashed together (literally) - and at some time something went wrong and the RPi stopped playing.
Long story short - new RPi (3b), new installation of o/s, trying to get back to a point where it all works again.
Running Python 3.5.3 and (apparently) matplotlib-2.2.0
PRETTY_NAME="Raspbian GNU/Linux 9 (stretch)"
NAME="Raspbian GNU/Linux"
My program runs (it produces text printout in the shell), but doesn't generate the desired graph (as it used to before the hiatus).
My notes in the program say that it was tested under Python 3.4.2, which I guess is what was installed when I created the system in the first place.
Error message is as follows :-
Warning (from warnings module):
File "/usr/local/lib/python3.5/dist-packages/matplotlib-2.2.0+617.g216441741-py3.5-linux-armv7l.egg/matplotlib/__init__.py", line 960
warnings.warn(message)
UserWarning: could not find rc file; returning defaults
This is probably significant.......<g> - but I don't know enough to fix the problem.
In desperation <g>, I'd looked at dumping matplotlib and using plotly instead - but (unless I'm reading it wrong) plotly no longer supports real-time web-based graphs on their free online service - so that turned out to be a bit of a dead end.
So - any ideas about where to go from here, please?
I'm reasonably clued up on computers generally, but new-ish to the RPi and not at all familiar with the Rasbian environment.
Adrian
B.Goode
Re: Python 3.5 & matplotlib - won't plot
Wed Mar 28, 2018 9:55 am
Taking a side-step from your own previously-working code...
There is Raspberry Pi Foundation resource describing simple use of matplotlib here: https://www.raspberrypi.org/learning/vi ... th-python/
Perhaps doing the first example from that would prove whether your python+matplotlib installation is functional? After that you could compare the scripts to see if you can find where your code is now failing.
adrian5750
Wed Mar 28, 2018 5:10 pm
HI
Thanks for the suggestion. Unfortunately, running the matlibplot test program
import matplotlib.pyplot as plt
y = [i for i in range(20,100,3)]
x = [i for i in range(len(y))]
plt.scatter(x,y)
plt.show()
Produces exactly the same error message.
So that suggests that there's something wrong with the matlibplot / python setup?
Adrian
B.Goode
Wed Mar 28, 2018 6:34 pm
Yes. And I can't replicate it on a fresh install, so it may be something local to your setup.
sudo apt install python3-matplotlib
installed v2.0.0, which is apparently behind the version you have?
Running the test routine produced a plot without error.
I regret I don't know enough about python library packaging to be able to make any suggestion about how to fix this.
adrian5750
Wed Mar 28, 2018 7:45 pm
Thanks.
The simple test program runs here under python2, but not under python 3.5.3 - where it produces the error message
Not sure why that should be?
Any ideas, anybody?
Adrian
robbes
Thu Mar 29, 2018 7:10 pm
You are just getting a warning, not an error. Where is your matplotlibrc file? It should be $HOME/.config/matplotlib/matplotlibrc You can check (using python3 interpreter) with
>>>import matplotlib
>>> matplotlib.matplotlib_fname()
Hopefully this file will have a line
backend : agg
which is the default backend. However I have seen comments that Raspbian needs the backend set to tkagg
Tkinter is the standard python GUI library, already installed in Raspbian, and tkagg will access it.
adrian5750
Thu Mar 29, 2018 7:51 pm
HI
Thanks for the reply.
>>> import matplotlib
'/usr/local/lib/python3.5/dist-packages/matplotlib-2.2.0+617.g216441741-py3.5-linux-armv7l.egg/matplotlib/mpl-data/matplotlibrc'
When I look in that folder, there is no file named matplotlibrc (which I guess is what the original error message was telling me)
Under
/home/pi/.config/matplotlib
there are no files - just an empty folder.
Searching for matplotlibrc - there's three of them in the following folders :-
/home/pi/Adafruit_Python_MAX31855/examples/matplotlib/lib/matplotlib/mpl-data/matplotlibrc
/home/pi/Adafruit_Python_MAX31855/examples/matplotlib/examples/pyplots/matplotlibrc
/home/pi/Adafruit_Python_MAX31855/examples/matplotlib/doc/matplotlibrc
OK - looking depper into this - I grabbed one of the matplotlibrc files, changed the
backend : agg
to
backend : tkagg
and saved it into the
/home/pi/.config/matplotlib folder.
And, lo and behold, the simple matplotlib test program now works under Python 3.5.3.
I guess that's a step in the right direction <g> - thanks
My 'proper' temperature plotting program (that used to work) still doesn't generate a graph.... so there must be something wrong there - but at least I now know that my Python 3.5.3 is capable of driving matplotlib to create a graph.
Now just need to find out what's broken with my program.....<g>
Adrian
robbes
Thu Mar 29, 2018 8:15 pm
You would have to restart the python interpreter after changing the rc file to pick up those changes.
Your program should certainly work if you include the line
matplotlib.use('tkagg')
right after the
import matplotlib
statement
adrian5750
Thu Mar 29, 2018 8:24 pm
HI
Thanks for that...
In case anybody else passes this way - it seems that running matplotlib to produce a real-time display requires the addition of
plt.pause(0.0001)
after the
plt.draw()
as described here
https://stackoverflow.com/questions/197 ... -in-a-loop
Adding this to my original temperature-logging program causes it to all burst into life!
Happy bunny!!
Not sure why the original program worked - but happy that I've got it working again....
Thanks!
Adrian
Return to “Python”
