multiple infinite loops running the same time
Posted: Thu Mar 15, 2018 5:52 am
by kune
I have a raspi project in which I have to create a function to let a LED blink with different parameters.
Here´s the code.
#!/usr/bin/python
import RPi.GPIO as GPIO
import time
from threading import Thread
GPIO.setmode(GPIO.BOARD)
def blink(port, hz):
    """ function let´s blink LEDs in variable speed and ports"""
    GPIO.setup(port, GPIO.OUT)
    while True:
        GPIO.output(port, GPIO.HIGH)
        time.sleep(0.5/hz)
        GPIO.output(port, GPIO.LOW)
        time.sleep(0.5/hz)
blink(16, 5)
This works as far. But now I have to call this function again with different parameters so that 2 LEDs can blink
I have tried it like this:
blink(16, 5)
blink(15, 10)
But it doesn´t work because with the first blink call the code enters a infinite loop.
Is there a way to start the second infinite loop, so both LEDs can blink?
Thank you.
Re: multiple infinite loops running the same time
Posted: Thu Mar 15, 2018 12:31 pm
by thagrol
Switch to gpiozero: https://gpiozero.readthedocs.io/en/stab ... t.html#led
Or put each call to your blink function in a seperate thread.
Posted: Thu Mar 15, 2018 12:37 pm
by PiGraham
Here´s the code.
Why is that line in the code?
Is it a hint at a solution?
Have a look at what the threading library does.
