ricardo.santos
how to name a class Thread
Sat Mar 10, 2018 11:03 pm
hi
i have a class using a thread as object i think
how can i give it a name. it will help the debugging in pycharm
temp.py
class WTemp(threading.Thread):
    def __init__(self, sleep):
        threading.Thread.__init__(self)
        self.sleep = sleep
        self.W_temp = 0
    def run(self):
        while True:
            # reads every sleep interval >0.8 (sensor response minimum delay)
            self.W_temp = W1ThermSensor().get_temperature()
            time.sleep(self.sleep)
    def read_temp(self):
        water_temp = self.W_temp
main.py
from temp import Wtemp
Wtemp.start()
how do i give a name to the thread .
in pycharm it appears as Thread7
thanks
Paeryn
Re: how to name a class Thread
Sun Mar 11, 2018 4:26 am
To name a threading object you just set its name property (or pass it a name when you initialise it). I assume pycharm uses that property as I have no knowledge of how pycharm works.
Your example main.py won't work as you gave it, wrong capitalisation of WTemp and you try calling the class function start() directly instead of creating an object of WTemp and calling its start() method.
# temperature_sensor.py
import threading
    threading.Thread.__init__(self, name = 'Default WTemp thread name')
    self.sleep = sleep
    self.W_temp = 0
# main.py
from temperature_sensor import WTemp
temperature_sensing_thread = WTemp(1)
temperature_sensing_thread.name = 'My temperature thread'
temperature_sensing_thread.start()
ricardo.santos
Sun Mar 11, 2018 9:14 am
:idea:
so simple. thanks a lot . that works like a charm in pycharm
why the 1 inside brackets? is that needed
Paeryn
Sun Mar 11, 2018 12:17 pm
:idea:
Your class constructor as you gave it requires a value for sleep, it won't work if you don't pass it a number :-
Return to “Python”
