threading using module EVENT
Posted: Thu Mar 08, 2018 4:56 pm
by ricardo.santos
I have a code with 3 functions running as threads
read() and read_write() should run alternatively (the two are never in parallel)
detect() function establish which one of the two above thread functions is running and pauses the other thread
I've used Event to do this
import threading
import numpy as np
from time import sleep
def read():
    event_rd.wait()
    print("read is running")
def read_write():
    event_rdw.wait()
    print("read_write is running")
def detect():
    while True:
          x= np.random.randint(1,100)
          if x > 50:
              event_rd.set()
          if x < 50:
              event_rdw.set()
          sleep(2)
event_rd = threading.Event  # restart read() and pause read_write()
event_rdw = threading.Event  # restart read_write ans pause read()
t_main = threading.Thread(target=detect, name="detect")
t_main.start()
t_rd = threading.Thread(target=read, name="read")
t_rdw = threading.Thread(target=read_write, name="read_write")
t_rd.start()
t_rdw.start()
Is not working why?
Re: threading using module EVENT
Posted: Thu Mar 08, 2018 5:14 pm
by ricardo.santos
the error log
Exception in thread read_write:
File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
self.run()
File "/usr/lib/python3.5/threading.py", line 862, in run
self._target(*self._args, **self._kwargs)
File "/home/pi/piwork/erosion-test/eventTest.py", line 10, in read_write
event_rdw.wait()
TypeError: wait() missing 1 required positional argument: 'self'
Posted: Thu Mar 08, 2018 6:30 pm
by Paeryn
import threading
import numpy as np
def read():
    event_rd.wait()
def read_write():
    event_rdw.wait()
def detect():
    while True:
          if x > 50:
              event_rd.set()
          if x < 50:
              event_rdw.set()
          sleep(2)
t_main.start()
t_rd.start()
t_rdw.start()
Is not working why?
You created event_rd and event_rdw as being the class threading.Event rather than being objects of that class. You need to put brackets after the class name to create an object of a class, e.g.
event_rd = threading.Event()  # restart read() and pause read_write()
event_rdw = threading.Event()  # restart read_write ans pause read()
You were getting the error because you were trying to call the function threading.Event.wait() directly with no object.
Posted: Thu Mar 08, 2018 10:22 pm
by ricardo.santos
:o
thanks a lot It works now
