IddoB
Reading Data From USB
Thu Mar 08, 2018 10:57 am
Hello guys!
I am working on my school project using the RPI and I am facing a small problem. I have bought a simple USB barcode reader and I am having trouble reading from it.
When I connect it to my PC on Windows it works completely fine. But when I go into the RPI I am not getting any input from it. (Its supposed to work like a regular keyboard I think)
When I run lsusb this is the Barcode scanner: Bus 001 Device 018: ID 6778:0112
I have looked online for solutions and I came across this, not sure if it can help me or not: http://pyserial.readthedocs.io/en/latest/index.html
Thank you!
topguy
Re: Reading Data From USB
Thu Mar 08, 2018 1:08 pm
Your first job is to verify that this is also the truth on Linux.
- Boot your Pi without the scanner plugged in..
- Open a terminal.
- Plug in your scanner and wait a couple of seconds.
- run the command "dmesg".
The last lines of output from "dmesg" then contain the kernel information related to your scanner. If you post those lines here we can usually see if it is in a working state or not.
If you think things are working ok you can install and run a program called "evtest" and if you run it without any parameters I belive it will let you choose from a list of "input" devices to test. Your scanner should be in that list, and if you select it and scan something, then evtest should print out every keystroke event.
IddoB
Fri Mar 09, 2018 10:18 am
- Open a terminal.
Thank you for your respond! I have downloaded Evdev for Python and managed to capture all the barcodes that I scan. My question is, is there a easier way to get that data? Becuase in evdev I get so much more information that I dont need (I need the value only)
topguy
Fri Mar 09, 2018 12:06 pm
I believe any easier way would be more dependent on what environment your program is running in. A method working in the Linux console might not work if a GUI environmnent with X and vice versa. I feel that using evdev is the only safe way if you have a HID scanner.
If you buy a scanner that is "serial" based you will get a serialport to read from, and that is simpler for software development than HID devices.
IddoB
Fri Mar 09, 2018 1:31 pm
Im pretty sure it is serial based. How could I read from it?
topguy
Sat Mar 10, 2018 10:11 pm
As long as the scanner is detected as a keyboard and not a serialport in Linux it doesnt matter what you think, but you should look at the documentation to see if there is a way to switch from HID mode to UART/Serial mode.
Since you have not said which make and model this is nor posted the output from dmesg, its not much more I can do to help.
IddoB
Mon Mar 12, 2018 6:10 am
I can configure the scanner to these modes:
RS-232
USB HID
RS484
topguy
Mon Mar 12, 2018 12:11 pm
Switch it to RS232 then and go back to my first answer in this thread.
( I'm now assuming that there isn't a seperate cable for the RS232 mode, but still working over USB. )
scruss
Mon Mar 12, 2018 12:57 pm
USB HID will (or at least should) make it appear as a keyboard. Anything you scan goes in as if you typed in the barcode. It's probably the easiest to support
Pronouns: he/him
IddoB
Mon Mar 12, 2018 2:35 pm
Ill try that. Thank you
IddoB
Mon Mar 12, 2018 2:37 pm
That is the case in Windows, but for some reason, it doesn't detect it in Raspbian.
Maybe I need to configure the system or download drivers? What are your thoughts?
scruss
Mon Mar 12, 2018 4:43 pm
It may need a udev rule for the system to accept it as a keyboard. Try searching for the usb vendor and ID codes along with "udev" and see if someone else has got it working. I couldn't work out your device from the one line you gave: we need the dmesg output too.
That vendor (0x6778) isn't recognized by any USB-IF list I can find
Pronouns: he/him
IddoB
Tue Mar 13, 2018 12:09 pm
I'll try to get more information and post it as soon as possible. Thank you anyway!
IddoB
Wed Mar 14, 2018 6:31 am
Here is the info info from dmesg:
[  923.047302] usb 1-1.2: Product: HID Keyboard Device
[  923.047310] usb 1-1.2: Manufacturer: HID Keyboard Device
[  923.047318] usb 1-1.2: SerialNumber: Keyboard Device
[  923.057155] usb 1-1.2: output irq status -32 received
[  923.057461] input: HID Keyboard Device HID Keyboard Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:6778:0112.0001/input/input0
[  923.121327] hid-generic 0003:6778:0112.0001: input,hidraw0: USB HID v1.10 Keyboard [HID Keyboard Device HID Keyboard Device] on usb-3f980000.usb-1.2/input0
[ 1207.891184] usb 1-1.2: USB disconnect, device number 4
[ 1210.130668] usb 1-1.2: new full-speed USB device number 5 using dwc_otg
[ 1210.266784] usb 1-1.2: New USB device found, idVendor=6778, idProduct=0112
[ 1210.266798] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1210.266806] usb 1-1.2: Product: HID Keyboard Device
[ 1210.266814] usb 1-1.2: Manufacturer: HID Keyboard Device
[ 1210.266821] usb 1-1.2: SerialNumber: Keyboard Device
[ 1210.277404] usb 1-1.2: output irq status -32 received
[ 1210.277546] input: HID Keyboard Device HID Keyboard Device as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:6778:0112.0002/input/input1
[ 1210.341496] hid-generic 0003:6778:0112.0002: input,hidraw0: USB HID v1.10 Keyboard [HID Keyboard Device HID Keyboard Device] on usb-3f980000.usb-1.2/input0
topguy
Wed Mar 14, 2018 1:28 pm
I feel this thread is going in circles, we already established in post number 3 that IddoB can read the keystrokes from the HID device using the evdev module in Python. I still will claim this method is the best solution because it will ignore input from other keyboards connected to the same device and also keystrokes being sent over SSH or Remote Desktop.
The dmesg output confirms that the device still is recognized as a HID-Keyboard and not a serialport.
IddoB
Wed Mar 14, 2018 2:00 pm
The thing is that with this method I am getting a huge output of system information that is not needed (Timestamps, type, and more).
topguy
Wed Mar 14, 2018 3:04 pm
You don't have to do anything with that extra data, just use the keystrokes as you need.
RS-232
USB HID
RS484
You haven't said how you were supposed to configure the scanner. And since Linux still thinks its a keyboard we cant conclude you have done it successfully either.
We have no make and model, no data sheet, no link to documentation or where you bought it from that could have helped us help you.
Return to “Python”
