can some one make this have 2 sliders
Posted: Wed Mar 07, 2018 10:25 pm
by jakerthegamer3
what this does i show a slider on screen to move a servo but it only shows one i want 2 for 2 servos
from Tkinter import *
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setup(18, GPIO.OUT)
pwm = GPIO.PWM(18, 100)
pwm.start(5)
class App:
    def __init__(self, master):
        frame = Frame(master)
        frame.pack()
        scale = Scale(frame, from_=0, to=180,
              orient=HORIZONTAL, command=self.update)
        scale.grid(row=0)
    def update(self, angle):
        duty = float(angle) / 10.0 + 2.5
        pwm.ChangeDutyCycle(duty)
root = Tk()
root.wm_title('Servo Control')
app = App(root)
root.geometry("200x50+0+0")
root.mainloop()
Re: help me with this problem i have
Posted: Thu Mar 08, 2018 9:57 am
by scotty101
Not very difficult. A simple hack to your existing code made below. There are much neater ways to do it but this should serve your purposes.
You'll just need to change the SERVO2 to be the number of the GPIO pin your second servo is connected to.
#https://www.raspberrypi.org/forums/viewtopic.php?f=32&t=207318
from tkinter import *
#import RPi.GPIO as GPIO
import time
SERVO1 = 18
SERVO2 = 18 #CHANGE ME!
GPIO.setup(SERVO1, GPIO.OUT)
pwm1 = GPIO.PWM(SERVO1, 100)
pwm1.start(5)
GPIO.setup(SERVO2, GPIO.OUT)
pwm2 = GPIO.PWM(SERVO2, 100)
pwm2.start(5)
class App:
        frame.grid()
        scale1 = Scale(frame, from_=0, to=180,
              orient=HORIZONTAL, command=self.updatePWM1)
        scale1.grid(column=0,row=1)
        scale2 = Scale(frame, from_=0, to=180,
              orient=HORIZONTAL, command=self.updatePWM2)
        scale2.grid(column=1,row=1)
    def updatePWM1(self, angle):
        print("PWM1: {}".format(duty))
        pwm1.ChangeDutyCycle(duty)
    def updatePWM2(self, angle):
        print("PWM2: {}".format(duty))
        pwm2.ChangeDutyCycle(duty)
root = Tk()
app = App(root)
root.mainloop()
(Note: I haven't tested this with the GPIO code on a raspberry pi nor have i tested it with a servo)
Posted: Thu Mar 08, 2018 4:39 pm
by jakerthegamer3
thanks a lot
