netromaster
Toggle 1602 lcd backlight on/off
Tue Jan 30, 2018 2:34 pm
I have a working library for my 1602 char lcd connected to an i2c adapter.
In the python code i see that there is a defined constant to turn off/on the lcd.
LCD_BACKLIGHT  = 0x08  # On
#LCD_BACKLIGHT = 0x00  # Off
But when i initiate the command to turn lcd off for 5 seconds it doesn't seem to work.
lcd_string(">Checking remote grid",LCD_LINE_1)
lcd_string("> ....ONLINE..",LCD_LINE_2)
time.sleep(5)
What am i doing wrong? Here's the code in :
import smbus
import time
# Define some device parameters
I2C_ADDR  = 0x3F
LCD_WIDTH = 16   # Maximum characters per line
# Define some device constants
LCD_CHR = 1 # Mode - Sending data
LCD_CMD = 0 # Mode - Sending command
LCD_LINE_1 = 0x80 # LCD RAM address for the 1st line
LCD_LINE_2 = 0xC0 # LCD RAM address for the 2nd line
LCD_LINE_3 = 0x94 # LCD RAM address for the 3rd line
LCD_LINE_4 = 0xD4 # LCD RAM address for the 4th line
ENABLE = 0b00000100 # Enable bit
# Timing constants
E_PULSE = 0.0005
E_DELAY = 0.0005
#Open I2C interface
bus = smbus.SMBus(1) # Rev 2 Pi uses 1
def lcd_init():
# Initialise display
lcd_byte(0x33,LCD_CMD) # 110011 Initialise
lcd_byte(0x32,LCD_CMD) # 110010 Initialise
lcd_byte(0x06,LCD_CMD) # 000110 Cursor move direction
lcd_byte(0x0C,LCD_CMD) # 001100 Display On,Cursor Off, Blink Off
lcd_byte(0x28,LCD_CMD) # 101000 Data length, number of lines, font size
lcd_byte(0x01,LCD_CMD) # 000001 Clear display
time.sleep(E_DELAY)
def lcd_byte(bits, mode):
# Send byte to data pins
# bits = the data
# mode = 1 for data
#        0 for command
bits_high = mode | (bits & 0xF0) | LCD_BACKLIGHT
bits_low = mode | ((bits<<4) & 0xF0) | LCD_BACKLIGHT
# High bits
bus.write_byte(I2C_ADDR, bits_high)
lcd_toggle_enable(bits_high)
# Low bits
bus.write_byte(I2C_ADDR, bits_low)
lcd_toggle_enable(bits_low)
def lcd_toggle_enable(bits):
# Toggle enable
time.sleep(E_DELAY)
bus.write_byte(I2C_ADDR, (bits | ENABLE))
time.sleep(E_PULSE)
bus.write_byte(I2C_ADDR,(bits & ~ENABLE))
time.sleep(E_DELAY)
def lcd_string(message,line):
# Send string to display
message = message.ljust(LCD_WIDTH," ")
lcd_byte(line, LCD_CMD)
for i in range(LCD_WIDTH):
lcd_byte(ord(message[i]),LCD_CHR)
def main():
# Main program block
lcd_init()
while True:
# Send some test
lcd_string("Initializing.....",LCD_LINE_1)
lcd_string("  ",LCD_LINE_2)
time.sleep(5)
# Send some more text
time.sleep(10)
lcd_string("Status: Active",LCD_LINE_1)
lcd_string("Grid Secure",LCD_LINE_2)
time.sleep(200000000000)
if __name__ == '__main__':
try:
main()
except KeyboardInterrupt:
pass
finally:
lcd_byte(0x01, LCD_CMD)
lcd_string("Shutting down..",LCD_LINE_1)
GPIO.cleanup()
pcmanbob
Re: Toggle 1602 lcd backlight on/off
Tue Jan 30, 2018 3:54 pm
So first are you sure your i2c adapter actually supports this function ?
all the i2c adapters I could find only seem to have a physical jumper to enable or disable the backlight.
secondly please when posting code use code tags
Add [code] at the top
code goes here
and [/code] at the bottom.
netromaster
Tue Jan 30, 2018 4:37 pm
Yes I'm sure my i2c supports it.
pcmanbob
Tue Jan 30, 2018 6:05 pm
Can you post a link to the i2c adapter you are using.
pcmanbob
Tue Jan 30, 2018 6:17 pm
Can't see any indication that it supports back light control, in fact it has the same physical jumper to turn off the back light as all the other examples I found.
netromaster
Tue Jan 30, 2018 6:23 pm
You mean to say where there is a physical jumper the backlight can't be toggled with code?
Tue Jan 30, 2018 6:31 pm
netromaster wrote:
Tue Jan 30, 2018 6:11 pm
here's the link http://www.famosastudio.com/i2c-lcd-backpack
You can toggle the backlight. The pins are
RS == P0
RW == P1
EN == P2
BL == P3
D4 == P4
D5 == P5
D6 == P6
D7 == P7
I think Richard Hull has support in his library at: https://github.com/rm-hull/luma.lcd but I've not checked (both of my PCF8574s are wired to Wemoses at the moment).
I've got some code at: https://github.com/DougieLawson/Raspber ... nified_LCD
This is a doctor free zone.
netromaster
Tue Jan 30, 2018 6:48 pm
RS == P0
RW == P1
EN == P2
BL == P3
D4 == P4
D5 == P5
D6 == P6
D7 == P7
I took a look at both repos and I can confidently say I didn't understand a thing looking at the code.
Is there no way to get it working with my code?
pcmanbob
Tue Jan 30, 2018 7:14 pm
Were this jumper existed on other adapters they stated that back light was on with jumper in place and off with jumper removed.
You could just remove the jumper and see if you can control the back light with you code then, you have nothing to loose trying it.
Tue Jan 30, 2018 7:38 pm
There's some python code here: http://www.recantha.co.uk/blog/?p=4849
And a forum thread here: viewtopic.php?f=32&t=34261&p=378524
netromaster
Wed Jan 31, 2018 5:58 am
I got it working now. Thanks everyone!
Now on to the next.
lnxusr
Sun Aug 18, 2019 4:24 am
Now on to the next.
I know it's been a while, but if you'd taken the time to tell us what you did, I may not have to continue looking for a solution.
Return to “Python”
