elfresno
very absurd problem with if
Mon Jan 29, 2018 3:34 pm
Hello everyone, I have a problem that I can not solve, I have the following part of code:
        if data1[0] == "LOOPSYNC":
                try:
                        sync()
                        print usb
                        if usb == "2":
                                print "in"
the console shows 2, so usb is equal to 2. but does not equal usb to 2 in the if. so it never returns "in".
thanks
piglet
Re: very absurd problem with if
Mon Jan 29, 2018 3:57 pm
Try print ">"+usb+"<" to see if there's anything else in there. I've been stung with leading or trailing spaces in the past...
edit: is usb a number or a string? You're comparing it to "2" which is a string...
shadetree01010100
Mon Jan 29, 2018 4:09 pm
I think piglet nailed it, since it's printing 2 but not evaluating to "2", what's probably happening is you're comparing a string to an integer.
>>> 2 == 2
True
>>> 2 == "2"
False
Remove the quotes around "2" and try again.
rant:
for any new projects, you should really be using Python3. https://www.dataquest.io/blog/python-2-or-3/
Why you should learn Python 2:
You shouldn't. Very soon there will be no future security or bug fixes for Python 2.x, and your time is better spent learning 3.x.
/rant
elfresno
Mon Jan 29, 2018 4:17 pm
ok. i try with
                try:
                        sync()
                        print ">"+usb+"<"
                        if usb == 2:
                                print "in"
and return
>2
elfresno
Mon Jan 29, 2018 4:39 pm
no , i want print in,
Paeryn
Mon Jan 29, 2018 4:42 pm
That looks like usb is a string of 2 (or more) characters where the first character is 2 and the last character is the newline (with possibly any number of spaces/tabs between them), e.g. "2\n"
You can strip whitespace from the front and end of a string with usb.strip() (strip() returns a string with the leading and trailing whitespace removed, it doesn't alter the original string).
if usb.strip() == "2":
  print("in")
elfresno
Mon Jan 29, 2018 5:23 pm
yes!! usb.strip work perfect thanks
Return to “Python”
