KingOfTheJungle
Trying to turn on motor nothing happens.
Tue Jan 23, 2018 2:05 pm
try:
	GPIO.setmode(GPIO.BOARD)
	GPIO.setup(12, GPIO.OUT)
	p = GPIO.PWM(12, 100)
	print("motor on")
	p.start(100)
except KeyboardInterrupt:
	p.stop()
	GPIO.cleanup()
	sys.exit()
except:
	print("other error occurred")
The python code prints "motor on" but the motor doesn't come on. Anyone able to help me out with this? Thanks.
Last edited by KingOfTheJungle on Tue Jan 23, 2018 3:07 pm, edited 1 time in total.
mattmiller
Re: Trying to turn on motor nothing happens.
Tue Jan 23, 2018 2:39 pm
You've not given speed a value
OP altered post
rpiMike
Tue Jan 23, 2018 2:46 pm
Have you got the correct pin ?
https://pinout.xyz/pinout/pin12_gpio18
Post a picture of your wiring.
KingOfTheJungle
Tue Jan 23, 2018 3:08 pm
I have, it was declared earlier in the script. Even if i give it a value nothing happens.
KingOfTheJungle
Tue Jan 23, 2018 3:11 pm
setup like this. http://javatutorial.net/wp-content/uplo ... ematic.png
pcmanbob
Tue Jan 23, 2018 3:38 pm
So looking at your code
your program just runs through the code once and then stops but it runs through and stops before it can actually complete the p.start(100) command.
so adding a simple sleep (0.5) allows time for p.start (100) to be setup.
import RPi.GPIO as GPIO
import time
import sys
GPIO.setwarnings(False)
try:
    print("motor on")
    p.start(100)
    time.sleep(0.5)
    p.stop()
    GPIO.cleanup()
    sys.exit()
except:
secondly you will never get to use the keyboard interrupt as your program is not looping and will end before you ever get to press the required keys so the stop and clean up will never be run.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
KingOfTheJungle
Tue Jan 23, 2018 4:18 pm
import time
import sys
try:
    print("motor on")
    p.start(100)
    time.sleep(0.5)
    p.stop()
    GPIO.cleanup()
    sys.exit()
except:
Thanks for your response! How do I keep the program looping? Also I need the motor running continuously until an interrupt arrives. So won't the time.sleep(0.5) line, make it stop and not run continuously?
KingOfTheJungle
Tue Jan 23, 2018 4:26 pm
Also when I run the script from using Thonny IDE it runs fine, but when I run it from the command line, it prints "motor on" but the motor doesn't come on.
pcmanbob
Tue Jan 23, 2018 4:33 pm
As your program stands with the time.sleep inserted, the motor will just keep running when the program stops because no pwm.stop was ever run, so you would need another program to run to stop the PWM.
if you want to loop your program you need to use a while loop, it can then check for you condition to be true and so exit.
https://www.tutorialspoint.com/python/p ... e_loop.htm
https://wiki.python.org/moin/WhileLoop
Return to “Python”
