This is the error I am getting when I connect to my mobile phone using the connect method in this documentation: https://gist.github.com/egorf/66d88056a9d703928f93,
raise TIMEOUT(msg)
pexpect.exceptions.TIMEOUT: Timeout exceeded.
<pexpect.pty_spawn.spawn object at 0xb62e3ab0>
command: /usr/bin/bluetoothctl
args: ['/usr/bin/bluetoothctl']
buffer (last 100 chars): 'mCHG\x1b[0m] Device 98:5F:D3:57:1A:BD RSSI: -47\r\n[\x 1b[0;93mCHG\x1b[0m] Device 98:5F:D3:57:1A:BD TxPower: 4\r\n'
before (last 100 chars): 'mCHG\x1b[0m] Device 98:5F:D3:57:1A:BD RSSI: -47\r\n[\x 1b[0;93mCHG\x1b[0m] Device 98:5F:D3:57:1A:BD TxPower: 4\r\n'
after: <class 'pexpect.exceptions.TIMEOUT'>
match: None
match_index: None
exitstatus: None
flag_eof: False
pid: 544
child_fd: 5
closed: False
timeout: 30
delimiter: <class 'pexpect.exceptions.EOF'>
logfile: None
logfile_read: None
logfile_send: None
maxread: 2000
ignorecase: False
searchwindowsize: None
delaybeforesend: 0.05
delayafterclose: 0.1
delayafterterminate: 0.1
searcher: searcher_re:
0: re.compile("Failed to connect")
1: re.compile("Connection successful")
2: EOF
The connection is supposed to fail since my phone is connected to another device, however it should return "failed to connect" and move on to the next paired-device that I have in my loop which calls the connect method. Unfortunately I cannot show my code. What should I do in the connect method to bypass the exception and return false for failed to connect?
