Thank you for reading. I've set up my RPi3 to communicate with an Allen Bradley L32 PLC. The goal is simply to take a picture using the RPiCamera after receiving a trigger from the PLC. It will save the file with a name assigned from the PLC, upload it to a remote computer using an FTP server, then delete the picture. I've got this part working, however after around 3 hours the two scripts that I've written will just disappear from the 'Services' window.
Here's the first script that's handling all of what I described above:
import ftplib
from picamera import PiCamera
import time
from Example_Program import *
import os
# Camera Settings
camera = PiCamera()
# Camera Factory Resolution Is 3280 x 2464
camera.resolution = (3280, 2464)
# camera.brightness = 45
# camera.contrast = 50
counter = 0
FileNameTag = 'Pi_Filename_With_JPG'
def doWork():
# Handshake To PLC To Confirm Connection
ex_write('Pi_Handshake', '1')
if ex_read('Trigger_Shutter') is True:
try:
# Starting Camera And Taking Picture
camera.start_preview()
time.sleep(2)
camera.capture(ex_read(FileNameTag))
camera.stop_preview()
# Logging Into FTP Server
print("Trying To Login To FTP...")
ftp = ftplib.FTP()
ftp.connect('192.168.1.4', '800')
ftp.login('scott', '')
ex_write('FTP_Logon_Successful', '1')
ftp.set_pasv(False)
# Sending File To FTP Server
fullname = ex_read(FileNameTag)
name = os.path.split(fullname)[1]
f = open(fullname, "rb")
ftp.storbinary('STOR ' + name, f)
f.close()
# Remove File From Pi
os.remove(fullname)
except Exception:
pass
while True:
try:
doWork()
except Exception:
doWork()
import time
import os
def restart():
if ex_read('HMI_Reset_Pb') == 1:
try:
os.system('sudo shutdown -r now')
except Exception:
pass
while True:
try:
restart()
except Exception:
restart()
I'm very new to Python, RPi's and the like, so if there's anything glaringly obvious in this code structure, please feel free to let me know!
