papous
Raspberry LX terminal odd behaviour
Sat Jan 13, 2018 7:43 pm
Below there is a fairly simple module to move the two engines that came with Camjam edukit#3.
When run from the Thonny platform it works ok.
When run fron thw LX terminal or IDLE the engines run erratically, stopping and turning back and forward for about 5 secbefore they resume a (almost) normal operation.
Does anyone have any idea why this happens? It is ruining my project.
Thank you
# CamJam EduKit 3 - Robotics # Worksheet 4 – Driving and Turning
try:
    import RPi.GPIO as GPIO
except RuntimeError:
    print("Error importing RPi.GPIO!  ")
#import RPi.GPIO as GPIO # Import the GPIO Library
from time import sleep # Import the Time library
# Set the GPIO modes
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
# Set variables for the GPIO motor pins
pinMotorAForwards = 10
pinMotorABackwards = 9
pinMotorBForwards = 8
pinMotorBBackwards = 7
Frequency = 80
# How long the pin stays on each cycle, as a percent (here, it's 30%)
DutyCycleA = 0
DutyCycleB = 0
# Setting the duty cycle to 0 means the motors will not turn
Stop = 0
# Set the GPIO Pin mode
GPIO.setup(pinMotorAForwards, GPIO.OUT)
GPIO.setup(pinMotorABackwards, GPIO.OUT)
GPIO.setup(pinMotorBForwards, GPIO.OUT)
GPIO.setup(pinMotorBBackwards, GPIO.OUT)
# Set the GPIO to software PWM at 'Frequency' Hertz
pwmMotorAForwards = GPIO.PWM(pinMotorAForwards, Frequency)
pwmMotorABackwards = GPIO.PWM(pinMotorABackwards, Frequency)
pwmMotorBForwards = GPIO.PWM(pinMotorBForwards, Frequency)
pwmMotorBBackwards = GPIO.PWM(pinMotorBBackwards, Frequency)
pwmMotorAForwards.start(0)
pwmMotorABackwards.start(0)
pwmMotorBForwards.start(0)
pwmMotorBBackwards.start(0)
def Motor_dc(a,b,c,d):
    pwmMotorAForwards.ChangeDutyCycle(a)
    pwmMotorABackwards.ChangeDutyCycle(b)
    pwmMotorBForwards.ChangeDutyCycle(c)
    pwmMotorBBackwards.ChangeDutyCycle(d)
Motor_dc(50,0,50,0) #forward
sleep(15)
Motor_dc(0,50,0,50) #back
sleep(3)
GPIO.cleanup()
davef21370
Re: Raspberry LX terminal odd behaviour
Mon Jan 15, 2018 5:52 pm
Try putting print statements after each chunk of code with a small delay afterwards to see where the problem is starting, eg.
print "Setting GPIO modes"
time.sleep(5)
(you'll need to import the time module of course).
Dave.
Apple say... Monkey do !!
papous
Mon Jan 15, 2018 6:33 pm
Dave thanks so much for your reply.
It actually worked. I even reduced the sleep period to 1 and it is ok
It sounds though that the engines 'initiate' at the point of
That's no problem but do you know why it happens?
davef21370
Mon Jan 15, 2018 7:25 pm
Unfortunately not, I've had problems running simple things from Idle. I now use PyCharm with Anaconda for developing, works for me.
Dave.
Return to “Python”
