Help with code weirdness
Posted: Mon Jan 08, 2018 8:44 pm
by papous
Why does this works (with the distance sensor)?
import RPi.GPIO as GPIO
import time
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
TRIG = 17
ECHO = 18
tdist=[]
dist=0
#print ("Distance Measurement In Progress")
GPIO.setup(TRIG,GPIO.OUT)
GPIO.setup(ECHO,GPIO.IN)
GPIO.output(TRIG, False)
#print ("Waiting For Sensor To Settle")
time.sleep(1)
#def distance():
for cntr in range(1, 10):
    try: # Repeat the next indented block forever
        GPIO.output(TRIG, True)
        time.sleep(0.00001)
        while GPIO.input(ECHO)==0:
          pulse_start = time.time()
          #print (pulse_start)
        while GPIO.input(ECHO)==1:
            pulse_end = time.time()
        pulse_duration = pulse_end - pulse_start
        tdist.append(pulse_duration * 34300/2)
        #return tdist
    except KeyboardInterrupt:
        GPIO.cleanup()
def median(thelist):
    sorted_list = sorted(thelist)
    length = len(sorted_list)
    center = length // 2
    print (length)
    if length == 1:
        return sorted_list[0]
    elif length % 2 == 0:
        return sum(sorted_list[center - 1: center + 1]) / 2.0
    else:
        return sorted_list[center]
print('Dist',median(tdist))
and this does not?
import time
TRIG = 17
ECHO = 18
tdist=[]
dist=0
time.sleep(1)
def distance():
            time.sleep(0.00001)
            return median(tdist)
            GPIO.cleanup()
    print ('length',length)
    if length == 1:
    else:
print('Dist',distance())
Re: Help with code weirdness
Posted: Mon Jan 08, 2018 9:17 pm
by pcmanbob
Saying the second code listing does not work is not giving us any information.
What happens when you run it. Do you get an error message if so try posting it in its entirety.
Remember people may not have the same hardware available to test your code.
Posted: Mon Jan 08, 2018 9:26 pm
by papous
You are right.
The first code will return the median of 10 values from the distance sensor.
I tried to 'convert' it to a function and I only get 1 reading. trying to unindent the RETURN keyword produces the syntax error: invalid syntax
thank you
Raspberry3B
Posted: Mon Jan 08, 2018 9:30 pm
by papous
solved it
removing try: loop makes the thing work
