mattyjb88
Running python script within a python script
Fri Dec 22, 2017 12:32 am
Hi
I am as new as can be to python.
I am trying to run one python script from within another.
The first script is drcontrol.py wich is a basic script for operating a USB 8 relay board.
An example of using this from the command line would be:
python drcontrol.py -d DAE003zi -r 1 -c on
the -d term is the serial number of the board
the -r term is the relay which is to be controlled
the -c term is the control action
So the above would turn relay 1 on.
The script works quite happily when run as above.
In order to interface the board with Cayenne, I am writing a parent script to run drcontrol.py. I'll call this parent script ircontrol.py.
All I want it to do is run the same as above, changing the -r and -c term depending on the Cayenne interface input.
Most of that I can figure out, however I am stuck at getting the ircontrol.py script to run the drcontrol.py script with the all the additional arguments (if this is the correct term for the -d, -r and -c terms?).
Can anyone give me a starter on this?
elParaguayo
Re: Running python script within a python script
Fri Dec 22, 2017 2:03 pm
Well you could use subprocess:
import subprocess
subprocess.call(["python", "drcontrol.py", "-d", "DAE003zi",  "-r",  "1",  "-c",  "on"])
However, it may be neater just to import drcontrol into your ircontrol.py script and then call the relevant functions from your script.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
Return to “Python”
