d3cka2d3pwood
Raspbian Jessie, Autostart Python Script after GUI
Wed Dec 13, 2017 10:36 am
I'm trying to autostart a python script, pygame file once Rasbian boots up. I have tried changing the autostart file in
/home/pi/.config/lxsession/LXDE-pi
to:
@lxpanel --profile LXDE-pi
@pcmanfm --desktop --profile LXDE-pi
@python /home/pi/faller/main.py
@xscreensaver -no-splash
@point-rpi
from
@point-rpi
But nothing happens. Although when I have tried autostarting lxterminal in this way it works using
@lxterminal
@point-rpi
I'm using 2017-04-10-raspbian-jessie as this is the latest version that the TFT screen i'm using works with.
Any help would be appreciated
klricks
Re: Raspbian Jessie, Autostart Python Script after GUI
Wed Dec 13, 2017 12:59 pm
Your entry should be like this:
@lxterminal -e python /home/pi/faller/main.py
Note that when/if your program terminates then the LXterminal will then immediately terminate as well.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
d3cka2d3pwood
Wed Dec 13, 2017 2:06 pm
Thank you very much for you fast reply, I'll give this a go tonight.
d3cka2d3pwood
Wed Dec 13, 2017 6:04 pm
Hi again,
It works for a second then shuts down.
when I run manually i.e typing python main.py the program runs fine.
see video here:
https://drive.google.com/file/d/1P0JpR2 ... sp=sharing
52 secs in the videos the traceback error says there is a pygame error, i.e. its unable open an image. Why does this work fine when I run the program manually but not when I run it automatically?
The particular file is unrestricted/all permissions open.
klricks
Wed Dec 13, 2017 6:14 pm
Hi again,
see video here:
Make sure the entry is typed exactly as shown above with spaces but with no extra spaces.
Note for testing it is much faster to log out then log back in rather than rebooting...
d3cka2d3pwood
Wed Dec 13, 2017 6:24 pm
it is exactly the same?
@point-rpi
d3cka2d3pwood
Wed Dec 13, 2017 6:30 pm
Its ok i've sussed it :)
I had to put the full file path for the image in my code
Thanks for your help klricks
Return to “Python”
Who is online
Users browsing this forum: No registered users and 20 guests
