hossein_rahimi
High frequency stepper motor
Sat Dec 09, 2017 2:36 pm
Hello everybody
I'm writing a program which controls 3 steppers motors. I tried to use time.delay to control the speed of my steppers. My problem is that one of my motors need a delay less than 15us and from what I've calculated with a timer, it seems the delay function itself has a delay around 70us. Is there any way I can achieve the speed I want for stepper? I tried to use PWM functions but they also seem to have a limit for frequency.
joan
Re: High frequency stepper motor
Sat Dec 09, 2017 4:04 pm
The hardware PWM (there are two channels) can certainly generate much higher frequencies (down to pulses a few tens of nanoseconds long).
pigpio waves can work in that region (1µs resolution) and can keep count of the pulses transmitted if you use a wave chain.
Have a look at http://abyz.me.uk/rpi/pigpio/examples.h ... wavePWM_py for a Python example of using waves.
p.torabi
Wed Dec 13, 2017 3:01 pm
I also have the same problem, I tested the pigpio library with python, I monitored the output with an oscilloscope, it seems this library is slower than gpio. the delay was around 125 us.
joan
Wed Dec 13, 2017 3:39 pm
Were you using waves?
p.torabi
Thu Dec 14, 2017 6:37 am
I just used PWM.
p.torabi
Thu Dec 14, 2017 7:42 am
I used PWM, with even 1 us wave and it helped. Thank you very much.
This link also helped me:
https://raspberrypi.stackexchange.com/q ... -generator
p.torabi
Sun Dec 17, 2017 8:28 am
It seems wave chain, counter is an integer so it has a limit of 65535. Is there a way to break this limit so I can repeat my wave longer or should I create a wave and repeat it?
Return to “Python”
Who is online
Users browsing this forum: No registered users and 7 guests
