delucaide
Control an IP camera Onvif compliant
Mon Nov 20, 2017 3:03 pm
Hi guys,
i'm trying to control an ip camera using the Python libraries https://github.com/quatanium/python-onvif
I'm able to connect to the camera and change his name using the example:
Interactive mode
$ onvif-cli -u 'admin' -a '12345' --host '192.168.0.112' --port 80 --wsdl /etc/onvif/wsdl/
ONVIF >>> cmd
analytics devicemgmt events imaging media ptz
ONVIF >>> cmd devicemgmt GetWsdlUrl
True: http://www.onvif.org/
ONVIF >>> cmd devicemgmt SetHostname {'Name': 'NewHostname'}
ONVIF >>> cmd devicemgmt GetHostname
True: {'Name': 'NewHostName'}
but when i try to control the camera PTZ i'm not sure on how can i give the right command. For example to control the zoom in/Out.
I tried to understand the onvif manual but without success after a week of tests.
Anybody can please help me?
delucaide
Re: Control an IP camera Onvif compliant
Mon Nov 20, 2017 8:53 pm
Nobody can help me?
elParaguayo
Tue Nov 21, 2017 8:02 am
Go easy on the bumping. It hasn't even been 24 hours since your first post. Everyone here is a volunteer who answers questions whenever they can so please give people a chance to read your post in their own time.
One comment: your example isn't really python related (other than the tool being written in python). Your question is more about using the tool itself and I wonder if you may have more luck in a different subforum (maybe "Graphics, Sound and Multimedia").
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
delucaide
Tue Nov 21, 2017 9:09 am
Thanks for your reply.
I’m sorry but i’m playing on it for 2 weeks now without any solution.
elParaguayo
Tue Nov 21, 2017 12:21 pm
I've just noticed you posted your question in a different subforum a couple of weeks ago so I understand your anxiety. Unfortunately, I would guess that the lack of response means that (so far) no one who has seen your post is familiar with onvif camera and the relevant python library.
I note that you've also posted a question on the project's Github page. I think that's a very sensible idea and hopefully you'll have more luck there.
Lastly, the code on this issue on the project page seems to include some zoom commands so you may be able to work something out from that.
Good luck.
delucaide
Tue Nov 21, 2017 9:50 pm
I'm tryng to give this kind of xml soap request:
[codes:
Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl">
<ProfileToken>defaultPrimary</ProfileToken>
<Velocity>
<Zoom x="0.5" xmlns="http://www.onvif.org/ver10/schema"/>
</Velocity>
</ContinuousMove>
</s:Body>][/code]
that should be like a tree as per soap request form .
I'm trying with this CMD Python code:
[ONVIF >>> [b]cmd ptz ContinuousMove {'ProfileToken': 'defaultPrimary' , 'Velocity' [ 'Zoom' : 'x="0.5"']}[/b]
  File "/usr/local/bin/onvif-cli", line 11, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.5/dist-packages/onvif/cli.py", line 165, in main
    cli.cmdloop()
  File "/usr/lib/python3.5/cmd.py", line 138, in cmdloop
    stop = self.onecmd(line)
  File "/usr/lib/python3.5/cmd.py", line 217, in onecmd
    return func(arg)
  File "/usr/local/lib/python3.5/dist-packages/onvif/cli.py", line 75, in do_cmd
    args.params = dict(literal_eval(match.group(1)))
  File "/usr/lib/python3.5/ast.py", line 46, in literal_eval
    node_or_string = parse(node_or_string, mode='eval')
  File "/usr/lib/python3.5/ast.py", line 35, in parse
    return compile(source, filename, mode, PyCF_ONLY_AST)
  File "<unknown>", line 1
    {'ProfileToken':'defaultPrimary','Velocity'['Zoom':'x="0.5"']}
but the terminal show me something wrong, highlighting the last parenthesis.
elParaguayo
Wed Nov 22, 2017 10:11 am
Well, if you're doing a ContinuousMove operation, you should look at the example in Github.
Having looked at that, here's a guess for doing it from python:
from onvif import ONVIFCamera
def perform_move(ptz, request, timeout):
    # Start continuous move
    ptz.ContinuousMove(request)
    # Wait a certain time
    sleep(timeout)
    # Stop continuous move
    ptz.Stop({'ProfileToken': request.ProfileToken})
# Set up camera - you'll need to change these as necessary
mycam = ONVIFCamera('192.168.0.112', 80, 'admin', '12345')
# Create media service object
media = mycam.create_media_service()
# Create ptz service object
ptz = mycam.create_ptz_service()
# Get target profile
media_profile = media.GetProfiles()[0];
# Get PTZ configuration options for getting continuous move range
request = ptz.create_type('GetConfigurationOptions')
request.ConfigurationToken = media_profile.PTZConfiguration._token
ptz_configuration_options = ptz.GetConfigurationOptions(request)
request = ptz.create_type('ContinuousMove')
request.ProfileToken = media_profile._token
ptz.Stop({'ProfileToken': media_profile._token})
# THIS BIT IS MY GUESS!
request.Velocity.Zoom._x = 0.5
perform_move(ptz, request, 1)
delucaide
Wed Nov 22, 2017 11:29 am
    sleep(timeout)
Hi elParaguayo and man thanks for your reply,
i tried that code including the right ip address , username and password but this is what i get:
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 24, in wrapped
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 180, in wrapped
    return call(params, callback)
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 167, in call
    ret = func(**params)
  File "/usr/local/lib/python3.5/dist-packages/zeep/client.py", line 41, in __call__
    self._op_name, args, kwargs)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/bindings/soap.py", line 121, in send
    return self.process_reply(client, operation_obj, response)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/bindings/soap.py", line 185, in process_reply
    result = operation.process_reply(doc)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/bindings/soap.py", line 366, in process_reply
    return self.output.deserialize(envelope)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/messages/soap.py", line 90, in deserialize
    body_result = self._deserialize_body(body)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/messages/soap.py", line 411, in _deserialize_body
    result = self.body.parse(xmlelement, self.wsdl.types)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/element.py", line 114, in parse
    schema_type=self.type)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/types/complex.py", line 169, in parse_xmlelement
    elements, schema, name, context=context)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/indicators.py", line 600, in parse_xmlelements
    xmlelements, schema, name, context=context)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/element.py", line 160, in parse_xmlelements
    xmlelement, schema, allow_none=True, context=context)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/types/complex.py", line 189, in parse_xmlelement
    init_kwargs[name] = attribute.parse(value)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/attribute.py", line 22, in parse
    return self.type.pythonvalue(value)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/types/simple.py", line 68, in pythonvalue
    '%s.pytonvalue() not implemented' % self.__class__.__name__)
NotImplementedError: AnySimpleType.pytonvalue() not implemented
During handling of the above exception, another exception occurred:
  File "/home/pi/Desktop/post.py", line 19, in <module>
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 28, in wrapped
    raise ONVIFError(err)
onvif.exceptions.ONVIFError: Unknown error: AnySimpleType.pytonvalue() not implemented
There-s something wrong that i really don't understand :O
elParaguayo
Wed Nov 22, 2017 12:10 pm
That's disappointing (but I would have been amazed if it had worked).
I'm out of ideas and, without a camera of my own, there's little else I can do.
You may want to paste that error onto the Github issues page given that it's an error that arises from a line in their own example code.
delucaide
Wed Nov 22, 2017 12:27 pm
Thanks anyway for your help.
As per your suggestion i’ll try to paste the error code there.
Hope somebody can give me help here too.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 12 guests
