delucaide
Control an IP camera Onvif compliant
Mon Nov 20, 2017 3:03 pm
Hi guys,
i'm trying to control an ip camera using the Python libraries https://github.com/quatanium/python-onvif
I'm able to connect to the camera and change his name using the example:
Interactive mode
$ onvif-cli -u 'admin' -a '12345' --host '192.168.0.112' --port 80 --wsdl /etc/onvif/wsdl/
ONVIF >>> cmd
analytics devicemgmt events imaging media ptz
ONVIF >>> cmd devicemgmt GetWsdlUrl
True: http://www.onvif.org/
ONVIF >>> cmd devicemgmt SetHostname {'Name': 'NewHostname'}
ONVIF >>> cmd devicemgmt GetHostname
True: {'Name': 'NewHostName'}
but when i try to control the camera PTZ i'm not sure on how can i give the right command. For example to control the zoom in/Out.
I tried to understand the onvif manual but without success after a week of tests.
Anybody can please help me?
delucaide
Re: Control an IP camera Onvif compliant
Mon Nov 20, 2017 8:53 pm
Nobody can help me?
elParaguayo
Tue Nov 21, 2017 8:02 am
Go easy on the bumping. It hasn't even been 24 hours since your first post. Everyone here is a volunteer who answers questions whenever they can so please give people a chance to read your post in their own time.
One comment: your example isn't really python related (other than the tool being written in python). Your question is more about using the tool itself and I wonder if you may have more luck in a different subforum (maybe "Graphics, Sound and Multimedia").
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
delucaide
Tue Nov 21, 2017 9:09 am
Thanks for your reply.
I’m sorry but i’m playing on it for 2 weeks now without any solution.
elParaguayo
Tue Nov 21, 2017 12:21 pm
I've just noticed you posted your question in a different subforum a couple of weeks ago so I understand your anxiety. Unfortunately, I would guess that the lack of response means that (so far) no one who has seen your post is familiar with onvif camera and the relevant python library.
I note that you've also posted a question on the project's Github page. I think that's a very sensible idea and hopefully you'll have more luck there.
Lastly, the code on this issue on the project page seems to include some zoom commands so you may be able to work something out from that.
Good luck.
delucaide
Tue Nov 21, 2017 9:50 pm
I'm tryng to give this kind of xml soap request:
[codes:
Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<ContinuousMove xmlns="http://www.onvif.org/ver20/ptz/wsdl">
<ProfileToken>defaultPrimary</ProfileToken>
<Velocity>
<Zoom x="0.5" xmlns="http://www.onvif.org/ver10/schema"/>
</Velocity>
</ContinuousMove>
</s:Body>][/code]
that should be like a tree as per soap request form .
I'm trying with this CMD Python code:
[ONVIF >>> [b]cmd ptz ContinuousMove {'ProfileToken': 'defaultPrimary' , 'Velocity' [ 'Zoom' : 'x="0.5"']}[/b]
  File "/usr/local/bin/onvif-cli", line 11, in <module>
    sys.exit(main())
  File "/usr/local/lib/python3.5/dist-packages/onvif/cli.py", line 165, in main
    cli.cmdloop()
  File "/usr/lib/python3.5/cmd.py", line 138, in cmdloop
    stop = self.onecmd(line)
  File "/usr/lib/python3.5/cmd.py", line 217, in onecmd
    return func(arg)
  File "/usr/local/lib/python3.5/dist-packages/onvif/cli.py", line 75, in do_cmd
    args.params = dict(literal_eval(match.group(1)))
  File "/usr/lib/python3.5/ast.py", line 46, in literal_eval
    node_or_string = parse(node_or_string, mode='eval')
  File "/usr/lib/python3.5/ast.py", line 35, in parse
    return compile(source, filename, mode, PyCF_ONLY_AST)
  File "<unknown>", line 1
    {'ProfileToken':'defaultPrimary','Velocity'['Zoom':'x="0.5"']}
but the terminal show me something wrong, highlighting the last parenthesis.
elParaguayo
Wed Nov 22, 2017 10:11 am
Well, if you're doing a ContinuousMove operation, you should look at the example in Github.
Having looked at that, here's a guess for doing it from python:
from onvif import ONVIFCamera
def perform_move(ptz, request, timeout):
    # Start continuous move
    ptz.ContinuousMove(request)
    # Wait a certain time
    sleep(timeout)
    # Stop continuous move
    ptz.Stop({'ProfileToken': request.ProfileToken})
# Set up camera - you'll need to change these as necessary
mycam = ONVIFCamera('192.168.0.112', 80, 'admin', '12345')
# Create media service object
media = mycam.create_media_service()
# Create ptz service object
ptz = mycam.create_ptz_service()
# Get target profile
media_profile = media.GetProfiles()[0];
# Get PTZ configuration options for getting continuous move range
request = ptz.create_type('GetConfigurationOptions')
request.ConfigurationToken = media_profile.PTZConfiguration._token
ptz_configuration_options = ptz.GetConfigurationOptions(request)
request = ptz.create_type('ContinuousMove')
request.ProfileToken = media_profile._token
ptz.Stop({'ProfileToken': media_profile._token})
# THIS BIT IS MY GUESS!
request.Velocity.Zoom._x = 0.5
perform_move(ptz, request, 1)
delucaide
Wed Nov 22, 2017 11:29 am
    sleep(timeout)
Hi elParaguayo and man thanks for your reply,
i tried that code including the right ip address , username and password but this is what i get:
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 24, in wrapped
    return func(*args, **kwargs)
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 180, in wrapped
    return call(params, callback)
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 167, in call
    ret = func(**params)
  File "/usr/local/lib/python3.5/dist-packages/zeep/client.py", line 41, in __call__
    self._op_name, args, kwargs)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/bindings/soap.py", line 121, in send
    return self.process_reply(client, operation_obj, response)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/bindings/soap.py", line 185, in process_reply
    result = operation.process_reply(doc)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/bindings/soap.py", line 366, in process_reply
    return self.output.deserialize(envelope)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/messages/soap.py", line 90, in deserialize
    body_result = self._deserialize_body(body)
  File "/usr/local/lib/python3.5/dist-packages/zeep/wsdl/messages/soap.py", line 411, in _deserialize_body
    result = self.body.parse(xmlelement, self.wsdl.types)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/element.py", line 114, in parse
    schema_type=self.type)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/types/complex.py", line 169, in parse_xmlelement
    elements, schema, name, context=context)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/indicators.py", line 600, in parse_xmlelements
    xmlelements, schema, name, context=context)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/element.py", line 160, in parse_xmlelements
    xmlelement, schema, allow_none=True, context=context)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/types/complex.py", line 189, in parse_xmlelement
    init_kwargs[name] = attribute.parse(value)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/elements/attribute.py", line 22, in parse
    return self.type.pythonvalue(value)
  File "/usr/local/lib/python3.5/dist-packages/zeep/xsd/types/simple.py", line 68, in pythonvalue
    '%s.pytonvalue() not implemented' % self.__class__.__name__)
NotImplementedError: AnySimpleType.pytonvalue() not implemented
During handling of the above exception, another exception occurred:
  File "/home/pi/Desktop/post.py", line 19, in <module>
  File "/usr/local/lib/python3.5/dist-packages/onvif/client.py", line 28, in wrapped
    raise ONVIFError(err)
onvif.exceptions.ONVIFError: Unknown error: AnySimpleType.pytonvalue() not implemented
There-s something wrong that i really don't understand :O
elParaguayo
Wed Nov 22, 2017 12:10 pm
That's disappointing (but I would have been amazed if it had worked).
I'm out of ideas and, without a camera of my own, there's little else I can do.
You may want to paste that error onto the Github issues page given that it's an error that arises from a line in their own example code.
delucaide
Wed Nov 22, 2017 12:27 pm
Thanks anyway for your help.
As per your suggestion i’ll try to paste the error code there.
Hope somebody can give me help here too.
xidahs
Sun Aug 26, 2018 1:39 pm
Hi there not sure if this will help but did have some success getting my ptz cameras to move to presets through the command line. My ultimate hope is that I can get alarm triggers on gpio inputs to get the camera to move the certain preset on a sensor trigger i.e. when gate opens camera will move to gate. I did have limited success with this but as i'm no programmer and information on this topic is sparse I am now at a dead end.The problem I have specifically is if I run the command
onvif-cli ptz GotoPreset "{'ProfileToken': '000', 'PresetToken': '3'}" -u 'admin' -a '' --host '192.168.1.10' --port 8899
the camera will go to preset 3 but the time take to respond is way too long ....of the order of 20seconds
however with onvif-cli running
onvif-cli -u 'admin' -a '' --host '192.168.1.10' --port 8899 --wsdl /home/pi/python-onvif/wsdl/
if I then execute
cmd ptz GotoPreset "{'ProfileToken': '000', 'PresetToken': '3'}"
the camera will move instantaneously
Just for reference I cannot remember how I found the profile token and this may be different for different cameras, it was found through onvif-cli
though.
My reason for posting is maybe someone can advise on how I can inject commands into a running onvif-cli instance using the gpio as triggers and hopefully the information Ive found can help someone else
xidahs
Mon Aug 27, 2018 9:37 am
Just as a follow up, haven't tried this in a while but upon trying the command
the camera does now seem to respond within a few seconds now, maybe somthing has changes in the code that allowed for quicker login to the camera.
xidahs
Mon Aug 27, 2018 3:52 pm
Scrap that, using laptop to issue commands the time taken is a few seconds but using my pi zero Im back to 30s between execution and movement. Maybe its a lack of CPU power any advice on speeding this up would be appreciated.
carlrowan
Sun Jan 06, 2019 4:35 pm
It took me almost my whole day to control my Onvif compliant IP cam.
Major issue I encountered are the ptz.stop error and the wsdl path error.
Too much detail to share in a post. All details are in this link.
https://carlrowan.wordpress.com/2018/12 ... rocessing/
Return to “Python”
