astirfreak
Using XPT2046 Touch in Python without X-Window
Sat Nov 18, 2017 4:22 pm
I have setup a Raspberry Pi 2 with a cheap 3.5" touch display with XPT2046 touch controller. I use Raspbian Stretch Lite without an X-Window-System.
With the waveshare drivers I got the display working. To draw graphics with python, I use pygame, which works perfektly. Also I can see a mouse pointer on the screen, but it doesn't move, when touching the screen.
Here the questions (maybe off topic)
- How to check, if touch works in general?
- How to readout touch coordinates with python?
Because I have no X-Windows, I cannot use
DISPLAY=:0.0 xinput_calibrator
Any ideas?
Michael
astirfreak
Re: Using XPT2046 Touch in Python without X-Window
Sat Nov 18, 2017 9:57 pm
Meanwhile I got it working by calling
event = pygame.event.poll()
periodically. But the XY-axes are swapped and the normal method by modifying
/etc/X11/xorg.conf.d/99-calibration.conf
doesn't work for me. Any change doesnt have an effect.
Michael
DirkS
Sat Nov 18, 2017 10:10 pm
Pygame doesn't use the X11 calibration.
From my notes:
Install:
sudo apt-get install evtest tslib libts-bin
Test:
sudo evtest /dev/input/touchscreen
Calibrate:
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_calibrate
Test:
sudo TSLIB_FBDEVICE=/dev/fb1 TSLIB_TSDEVICE=/dev/input/touchscreen ts_test
astirfreak
Sun Nov 19, 2017 7:37 am
Good Morning,
by replacing "touchscreen" by "event0" I could calibrate. The test works successfull. But in pygame I still have swapped axes.
Any Ideas?
Michael
astirfreak
Sun Nov 19, 2017 8:53 am
After a lot of googeling, it seems to be a general problem to get the touchpad working in pygame with the current raspbian version.
I only want to develop a simple alarm clock with ability to set the alarm times with the touchscreen. For the graphical output I'm using pygame. Because I don't need the mousepointer, I'm free to use other python modules to get the touchpad events.
Any idea, which module to use?
Michael
OutoftheBOTS
Sun Nov 19, 2017 9:03 am
I wrote my own driver for the touch chip. It is a simple SPI interface. I wrote it as part of a ili9341 screen driver for myself.
If you don't find anything then let me know and I will share my work with you
astirfreak
Sun Nov 19, 2017 11:01 am
thank you for your offer. The touchpad shares the SPI with the display. So if I use the already installed drivers, that will come in conflict with your touchpad driver?
Did you wrote it in python?
Michael
OutoftheBOTS
Sun Nov 19, 2017 8:22 pm
Unsure if it will cause conflictions with your display but hopefully not as even tough it is on the same SPI bus it has a different CS (chip select line).
It is all written in Python.
I will share all the code it runs a 340 x 200 ili9341 screen on SPI CS0 and the touch on SPI CS1. You should only need the 3 touch functions off memory all the rest of the code is just code for running the screen but it was awhile ago I wrote this. [edit] there maybe some some stuff that is needed for touch in the __init__ fuction too can't remeber
import spidev
import RPi.GPIO as GPIO
import time
from PIL import Image
import numbers
import numpy as np
ILI9341_TFTWIDTH    = 240
ILI9341_TFTHEIGHT   = 320
ILI9341_NOP         = 0x00
ILI9341_SWRESET     = 0x01
ILI9341_RDDID       = 0x04
ILI9341_RDDST       = 0x09
ILI9341_SLPIN       = 0x10
ILI9341_SLPOUT      = 0x11
ILI9341_PTLON       = 0x12
ILI9341_NORON       = 0x13
ILI9341_RDMODE      = 0x0A
ILI9341_RDMADCTL    = 0x0B
ILI9341_RDPIXFMT    = 0x0C
ILI9341_RDIMGFMT    = 0x0A
ILI9341_RDSELFDIAG  = 0x0F
ILI9341_INVOFF      = 0x20
ILI9341_INVON       = 0x21
ILI9341_GAMMASET    = 0x26
ILI9341_DISPOFF     = 0x28
ILI9341_DISPON      = 0x29
ILI9341_CASET       = 0x2A
ILI9341_PASET       = 0x2B
ILI9341_RAMWR       = 0x2C
ILI9341_RAMRD       = 0x2E
ILI9341_PTLAR       = 0x30
ILI9341_MADCTL      = 0x36
ILI9341_PIXFMT      = 0x3A
ILI9341_FRMCTR1     = 0xB1
ILI9341_FRMCTR2     = 0xB2
ILI9341_FRMCTR3     = 0xB3
ILI9341_INVCTR      = 0xB4
ILI9341_DFUNCTR     = 0xB6
ILI9341_PWCTR1      = 0xC0
ILI9341_PWCTR2      = 0xC1
ILI9341_PWCTR3      = 0xC2
ILI9341_PWCTR4      = 0xC3
ILI9341_PWCTR5      = 0xC4
ILI9341_VMCTR1      = 0xC5
ILI9341_VMCTR2      = 0xC7
ILI9341_RDID1       = 0xDA
ILI9341_RDID2       = 0xDB
ILI9341_RDID3       = 0xDC
ILI9341_RDID4       = 0xDD
ILI9341_GMCTRP1     = 0xE0
ILI9341_GMCTRN1     = 0xE1
ILI9341_PWCTR6      = 0xFC
ILI9341_BLACK       = 0x0000
ILI9341_BLUE        = 0x001F
ILI9341_RED         = 0xF800
ILI9341_GREEN       = 0x07E0
ILI9341_CYAN        = 0x07FF
ILI9341_MAGENTA     = 0xF81F
ILI9341_YELLOW      = 0xFFE0
ILI9341_WHITE       = 0xFFFF
button_register = [(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0),(0,0,0,0,0)]
spi = spidev.SpiDev()
spi.open(0, 0)
spi.max_speed_hz = 64000000
spi1 = spidev.SpiDev()
spi1.open(0, 1)
DC = 24
RST = 25
LED = 18
class Touch_Screen_320_240:
  def __init__(self):
	global backlight
	global current_screen
	GPIO.setmode(GPIO.BCM)
	GPIO.setup(DC, GPIO.OUT) #DC
	GPIO.setup(RST, GPIO.OUT) #RST
	GPIO.setup(LED, GPIO.OUT)
	backlight = GPIO.PWM(LED, 200)
	backlight.start(0)
	GPIO.output(RST,True)
	time.sleep(0.005)
	GPIO.output(RST,False)
	time.sleep(0.02)
	time.sleep(0.150)
	self.send(0xEF,False)
	self.send(0x03,True)
	self.send(0x80,True)
	self.send(0x02,True)
	self.send(0xCF,False)
	self.send(0x00,True)
	self.send(0XC1,True)
	self.send(0X30,True)
	self.send(0xED,False)
	self.send(0x64,True)
	self.send(0X12,True)
	self.send(0X81,True)
	self.send(0xE8,False)
	self.send(0x85,True)
	self.send(0x78,True)
	self.send(0xCB,False)
	self.send(0x39,True)
	self.send(0x2C,True)
	self.send(0x34,True)
	self.send(0xF7,False)
	self.send(0x20,True)
	self.send(0xEA,False)
	self.send(ILI9341_PWCTR1,False)    # Power control
	self.send(0x23,True)                    # VRH[5:0]
	self.send(ILI9341_PWCTR2,False)    # Power control
	self.send(0x10,True)                    # SAP[2:0];BT[3:0]
	self.send(ILI9341_VMCTR1,False)    # VCM control
	self.send(0x3e,True)
	self.send(0x28,True)
	self.send(ILI9341_VMCTR2,False)    # VCM control2
	self.send(0x86,True)                   # --
	self.send(ILI9341_MADCTL,False)    #  Memory Access Control
	self.send(0x48,True)
	self.send(ILI9341_PIXFMT,False)
	self.send(0x55,True)
	self.send(ILI9341_FRMCTR1,False)
	self.send(0x18,True)
	self.send(ILI9341_DFUNCTR,False)    #  Display Function Control
	self.send(0x08,True)
	self.send(0x82,True)
	self.send(0x27,True)
	self.send(0xF2,False)                #  3Gamma Function Disable
	self.send(ILI9341_GAMMASET,False)    # Gamma curve selected
	self.send(0x01,True)
	self.send(ILI9341_GMCTRP1,False)    # Set Gamma
	self.send(0x0F,True)
	self.send(0x31,True)
	self.send(0x2B,True)
	self.send(0x0C,True)
	self.send(0x0E,True)
	self.send(0x4E,True)
	self.send(0xF1,True)
	self.send(0x37,True)
	self.send(0x07,True)
	self.send(0x09,True)
	self.send(ILI9341_GMCTRN1,False)    # Set Gamma
	self.send(0x14,True)
	self.send(0x11,True)
	self.send(0xC1,True)
	self.send(0x36,True)
	self.send(ILI9341_SLPOUT,False)    # Exit Sleep
	time.sleep(0.120)
	self.send(ILI9341_DISPON,False)    # Display on
	current_screen = [0] * 153600
	self.touch_calibration()
	self.display_background(current_screen)
	#self.touch_calibration()
  def convert_16bit(self,image):
    #convert 24bit colours to 16bit colours code from
    #Keith (https://www.blogger.com/profile/02555547344016007163)
    pb = np.array(image.convert('RGB')).astype('uint16')
    color = ((pb[:,:,0] & 0xF8) << 8) | ((pb[:,:,1] & 0xFC) << 3) | (pb[:,:,2] >> 3)
    return np.dstack(((color >> 8) & 0xFF, color & 0xFF)).flatten().tolist()
  def send(self,data, is_data=True, chunk_size=4096):
        # Set DC low for command, high for data.
		GPIO.output(DC, is_data)
        # Convert scalar argument to list so either can be passed as parameter.
		if isinstance(data, numbers.Number):
			data = [data & 0xFF]
        # Write data a chunk at a time.
		for start in range(0, len(data), chunk_size):
			end = min(start+chunk_size, len(data))
			temp_data = spi.xfer(data[start:end])
  def set_window(self, x0=0, y0=0, width=320, height=240):
		x1=x0+width-1
		y1=y0+height-1
		self.send(ILI9341_CASET,False)        # set Column addr command
		self.send(y0 >> 8,True)
		self.send(y0,True)                    # x_start
		self.send(y1 >> 8,True)
		self.send(y1,True)                    # x_end
		self.send(ILI9341_PASET,False)        # set Row addr command
		self.send(x0 >> 8,True)
		self.send(x0,True)                    # y_start
		self.send(x1 >> 8,True)
		self.send(x1,True)                    # y_end
		self.send(ILI9341_RAMWR,False)        # set to write to RAM
  def back_light(self,brightness):
    backlight.ChangeDutyCycle(brightness)
  def load_image(self,image_file,xsize,ysize):
	image = Image.open(image_file)
	image = image.rotate(270).resize((ysize, xsize))
	image = list(self.convert_16bit(image))
	return image
  def load_background_image(self,image_file):
	background_image = self.load_image(image_file, 320,240)
	return background_image
  def load_button_image(self, image_file, xsize, ysize):
	button_image = self.load_image(image_file, xsize,ysize)
	return [xsize, ysize, button_image]
  def display_background(self,image):
	current_screen = image
	self.set_window()
	self.send(image,True)
  def scroll (self, start):
	while start > 319 : start -= 320
	self.send(0x37,False)
	self.send(start >> 8, True)
	self.send (start & 0b0000000011111111, True)
  def touch_calibration (self,touch_xoffset=170, touch_yoffset=280, touch_xscale=10.8, touch_yscale=15) :
	global xoffset
	global yoffset
	global xscale
	global yscale
	xoffset = touch_xoffset
	yoffset = touch_yoffset
	xscale = touch_xscale
	yscale = touch_yscale
  def touched (self,touch_sensitivity =245):
    readarry =  spi1.xfer2([0b10111000,0b00000000,0b00000000])
    z1 = readarry[2] >> 7 | readarry[1] << 1
    readarry =  spi1.xfer2([0b11001000,0b00000000,0b00000000])
    z2 = readarry[2] >> 7 | readarry[1] << 1
    if z2-z1 < touch_sensitivity : return True
    else : return False
  def get_touch_position (self) :
	if self.touched() :
	  readarry =  spi1.xfer2([0b11010000,0b00000000,0b00000000])
	  y = int((4095- (readarry[1] << 5 | readarry [2] >> 3) - yoffset)// yscale)
	  if y < 0 : y = 0
	  if y > 239 : y = 239
	  readarry =  spi1.xfer2([0b10010000,0b00000000,0b00000000])
	  x = ( ( (readarry[1] << 5 | readarry [2] >> 3) - xoffset)// xscale )
	  x = int(x)
	  if x < 0 : x=0
	  if x > 319 : x = 319
	else :
	  x = 0
	  y = 0
	return [x,y]
  def get_block(self,x,y,width,height):
    block=[]
    for x_pos in range((x) * 480, (x*480) + ((width) * 480), 480):
  	  for y_pos in range((y * 2), (y*2) + (height*2),1):
	     block.append(current_screen[x_pos+y_pos])
    return block
  def put_button(self, button_data ,button_number, x, y):
	if x < 0 or y < 0 or x+button_data[0] > 319 or y+button_data[1] > 239 : raise "Button outside screen"
	else:
	  global button_register
	  button_register[button_number] = [x,y,button_data[0],button_data[1],True]
	  self.set_window(x, y, button_data[0], button_data[1])
	  self.send(button_data[2],True)
  def remove_button(self, button_number):
	button = button_register[button_number]
	self.set_window(button[0],button[1],button[2],button[3])
	blocks = self.get_block(button[0],button[1],button[2],button[3])
	self.send(blocks,True)
	button_register[button_number] = [0,0,0,0,0]
  def button_pressed(self,button_number):
    if self.touched() :
  	  position = self.get_touch_position()
	  if position[0] > button[0] and position[0] < button[0] + button[2] and position[1] > button[1] and position[1] < button[1] + button[3] : return True
	  else : return False
  def shutdown(self,GPIO_clean=True):
	self.back_light(0)
	GPIO.output(DC,False)
	if GPIO_clean == True : GPIO.cleanup()
astirfreak
Mon Nov 20, 2017 8:38 pm
Thank you for the code. But primarily I will try to get it work without own drivers.
The tslib calibration works and it must be possible to use tslib to get the touchscreen state. The big problem ist, that I'm a linux noob and I have only weak ideas how to interface tslib.
Also I don't understand the syntax of
Michael
astirfreak
Mon Nov 20, 2017 9:15 pm
it seems that I'm approaching the solution.
http://python-evdev.readthedocs.io/en/l ... orial.html
With evdev I can read directly the events from event0
Within this event, the uncalibrated touch values are accessible. I tested it in thy python console. There it works
To continue, I only have to fight with the syntax to readout the events continuously. But this should be the smallest part of the problem.
Michael
astirfreak
Tue Nov 21, 2017 5:55 pm
For all others with a similar problem:
Readout of a XPT2046-Touchscreen with Python using evdev.
This code reads uncalibrated values.
import os
from evdev import InputDevice
class PyTouch:
	def __init__(self):
		self.dev = InputDevice('/dev/input/event0')
		print self.dev.capabilities(verbose=True)
		self.touch_x = 0
		self.touch_y = 0
		self.pressed = 0
		self.press_force = 0
	def poll(self):
		event = self.dev.read_one()
		if (event != None):
			if (event.code==0 and event.type==3):	# Y-Axis
				self.touch_y = event.value
			if (event.code==1 and event.type==3):	# X-Axis
				self.touch_x = event.value
			if (event.code==24 and event.type==3):	# Touch Pressure Force
				self.press_force = event.value
			if (event.code==330 and event.type==1):	# Touch Pressed
				self.pressed = event.value
			print (self.touch_x),
			print (self.touch_y),
			print (self.press_force),
			print (self.pressed),
# Main
touch = PyTouch()
while True:
	touch.poll()
The use of read_one() is not very efficient but good for demonstrating, how it works.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 23 guests
