Bat64
Paho-MQTT: NameError: name 'Client" is not defined
Fri Nov 17, 2017 9:49 am
I am running a short python test script to publish to an MQTT topic, my code is as follows:
import paho.mqtt.client as client
Client(client_id="Pi")
client=mqtt.Client("Sensors")
username_pw_set("censored", password="censored")
client.connect("hostname")
client.publish("/temp", "369")
I receive the following error:
File "mqtttest.py", line 3, in <module>
NameError: name 'Client' is not defined
B.Goode
Re: Paho-MQTT: NameError: name 'Client" is not defined
Fri Nov 17, 2017 10:10 am
Welcome to the Raspberry Pi forums.
The opinion of the Python interpreter is always correct, even when you think it is wrong.
Do you have a reference to any documentation or tutorial that might be misleading you into thinking that your script is correct?
Bat64
Fri Nov 17, 2017 11:03 am
Thank you for your response. I understand that, I did not mean to imply that it is wrong.
Here are my sources:
http://www.steves-internet-guide.com/in ... on-client/
https://pypi.python.org/pypi/paho-mqtt/
I suspect it may be an incorrect installation or my script is in the wrong directory since it seems like it is not picking up the method "Client"
I am using python3 so I installed it with
pip3 install paho-mqtt
It is in the directory /etc/openhab2/scripts
However, there are other scripts in there that returned a "connection refused" error which I believe may nullify my above theory.
Fri Nov 17, 2017 11:07 am
client <> Client
Python is case sensitive.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
Bat64
Fri Nov 17, 2017 11:23 am
Well I guess I'm not copy-pasting from Steve's internet guide anymore... Thank you so much! Anyway I now have the following error:
    client(client_id="Pi")
TypeError: 'module' object is not callable
Sat Nov 18, 2017 1:27 am
You didn't read the whole article.
import paho.mqtt.client as mqtt #import the client1
broker_address="localhost"
#broker_address="iot.eclipse.org" #use external broker
client = mqtt.Client("P1") #create new instance
client.connect(broker_address) #connect to broker
client.publish("house/main-light","OFF")#publish
MQTT Evangelist
Return to “Python”
Who is online
Users browsing this forum: njsss and 8 guests
