Code for LED matrix with shift registers.
Posted: Thu Nov 16, 2017 12:55 pm
by Ageir
I'm trying to run a 8x8 led matrix via 2x 74hc595 shift registers.
I got it working with this code.
https://www.sunfounder.com/learn/Super_ ... rrypi.html
But trying to write text or graphics with that code is rather difficult. It's using only two bytes to write to the shift registers.
I found several editors that generate text and graphic code. This seems to be the best.
https://xantorohara.github.io/led-matrix-editor/
But the problem is how to use it! The python code I'm using is using a 2 byte system, 1 byte for rows and the other byte for columns.
And all editors/code generators are generating 8 bytes, one byte for each row.
How do i adapt or write code for that? Have been googling for hours for examples but no luck.
All code I'm finding is using max7219/21 and not the shift registers.
Anyone got any idea how to solve this? Any help appreciated!
Edit: I'm aware that the generator is creating c code, but converting it to python is a minor issue. The problem is how to convert the 8 byte data and send it to the shift registers.
Re: Code for LED matrix with shift registers.
Posted: Fri Nov 17, 2017 12:52 pm
by Ageir
Basically anything really. Just using two bytes, 0x00, 0xff etc is a pain to draw any shape.
Posted: Fri Nov 17, 2017 3:59 pm
by BitHead
Use that 8x8 matrix code and 'pretend' it is going to LED matrix - but really write it to an 8x8 array in ram.
Then, using a timer-interrupt, write a routine that reads that array and turns bit positions into 'Y' register columns for each of your 8 'X' register rows.
20mS human eye flicker perception limit / 8 -> about 2mS timer timeout time.
Good luck!
Posted: Sat Nov 18, 2017 3:14 pm
by Ageir
Thanks BitHead. Will try it.
What's the best way to convert/store this in python? Array? Tuple? List? Matrix?
const byte IMAGES[][8] = {
  B00000000,
  B00011000,
  B00011000,
  B00111000,
  B00011000,
  B00011000,
  B00011000,
  B01111110
  B00000000,
  B00111100,
  B01100110,
  B00000110,
  B00001100,
  B00110000,
  B01100000,
  B01111110
  B00000000,
  B00111100,
  B01100110,
  B00000110,
  B00011100,
  B00000110,
  B01100110,
  B00111100
  B00000000,
  B00001100,
  B00011100,
  B00101100,
  B01001100,
  B01111110,
  B00001100,
  B00001100
  B00000000,
  B01111110,
  B01100000,
  B01111100,
  B00000110,
  B00000110,
  B01100110,
  B00111100
  B00000000,
  B00111100,
  B01100110,
  B01100000,
  B01111100,
  B01100110,
  B01100110,
  B00111100
  B00000000,
  B01111110,
  B01100110,
  B00001100,
  B00001100,
  B00011000,
  B00011000,
  B00011000
  B00000000,
  B00111100,
  B01100110,
  B01100110,
  B00111100,
  B01100110,
  B01100110,
  B00111100
  B00000000,
  B00111100,
  B01100110,
  B01100110,
  B00111110,
  B00000110,
  B01100110,
  B00111100
  B00000000,
  B00111100,
  B01100110,
  B01101110,
  B01110110,
  B01100110,
  B01100110,
  B00111100
Edit: When I think of it, it would be better to store the character/number etc with the data so that it could be found more easily.
'1', {
  B00000000,
  B00011000,
  B00011000,
  B00111000,
  B00011000,
  B00011000,
  B00011000,
  B01111110
Not sure what's the best way to do this.
Posted: Sat Nov 18, 2017 4:04 pm
by Ageir
Looking into it I'm guessing a dictionary containing tuples would be a good choice.
num= {'1': (0b00000000,
  	            0b00011000,
                    0b00011000,
                    0b00111000,
                    0b00011000,
                    0b00011000,
                    0b00011000,
                    0b01111110),
              '2':(0b00000000,
                     0b00111100,
                     0b01100110,
                     0b00000110,
                     0b00001100,
                     0b00110000,
                     0b01100000,
                     0b01111110)
Something like this. Am I right? Any better solution?
Posted: Sat Nov 18, 2017 6:37 pm
by Ageir
That's working just fine. But it's all inversed on my display.
How do i rotate the bitmap in python?
This is the number two how it should look like.
             '2':(0b00000000,
                     0b00111100,
                     0b01100110,
                     0b00000110,
                     0b00001100,
                     0b00110000,
                     0b01100000,
                     0b01111110)
And this is what my display is showing. It's backwards.
             '2':(0b00000000,
                     0b00111100,
                     0b01100110,
                     0b01100000,
                     0b00110000,
                     0b00001100,
                     0b00000110,
                     0b01111110)
What's the easiest way to rotate it? Any build it function for this?
Posted: Thu Apr 25, 2019 10:23 am
by monochromaticmau
I'm going through the same thing right now. Can you share the altered code that made it work?
Did you put resistors in your system? The instructions don't include it, but most content online have current limiting resistors, and I'm noticing some weird behavior when I try to Multiplex. Not what I would expect. I found this great article https://circuitdigest.com/microcontroll ... spberry-pi that helps explain what needs to get done to get unique shapes without lighting unwanted LEDs.
When I slow down the cycles it's what I expect, but when I speed it up to attempt to Multiplex, more lights than what I turn on light up, etc.
Posted: Thu May 23, 2019 7:26 pm
by monochromaticmau
Posted: Thu May 23, 2019 7:42 pm
by Andyroo
Please be aware the the original poster has not been here since Nov 18, 2017 7:52 pm and it’s unlikely a mail notification on the post would get any reply.
It’s best to create a new topic referencing this old one with a simple link and explain what you have so far. Often old topics require out of date or unavailable software, OS or websites.
