Ace Rimmer
Finding a Line of GPS data
Fri Nov 10, 2017 3:33 am
Hi, I'm able to read all the lines of data from a GPS module connected via usb, but I only want to see one or two of the lines..
 import serial
 ser=serial.Serial('dev/ttyUSB0',9600)
 textln=ser.readline()
 while 1:
 	print (textln )
All lines ( and there are many :o ) start with "$GP". How do I pick out the particular line I require ( $GPGGA) and print it? :?
There must be an easier way!!!!!
I hope there is.....I haven't found it yet.
Re: Finding a Line of GPS data
Fri Nov 10, 2017 6:32 am
That code is wrong. It will read a line of text from the serial port, then print the same line over and over again for ever.
Try putting the ser.readline inside the while loop
import serial
while 1:
    print (textln)
That's still a bit messy as it will keep trying to read lines forever. I don't use python much, it may be possible to do a "while(textln = ser.readline()):"
ghp
Fri Nov 10, 2017 6:39 am
you can check a line of code with string method startswith:
import serial
while 1:
    if textln.startswith( '$GPGGA'):
        print (textln)
Good luck with your project !
Ace Rimmer
Fri Nov 10, 2017 10:11 pm
Thanks for the replies,
Long time no "see" Dom. ;)
ghp - I'll try that code, it looks like it might do what I want. I'll let you know. :)
Fri Nov 10, 2017 10:17 pm
Hi Ace :-)
We have more spiders now. Some gone, some new ones.
Ace Rimmer
Fri Nov 10, 2017 11:17 pm
Thanks ghp that code does just what I wanted it to. I was a bit worried at first as I ran it from the Python shell and it returned an error (something to do with tuples or bytes) however when the py file was run from the command line it worked 8-)
So tell me Dom, what is the count now - reply in octal.
Sat Nov 11, 2017 5:31 am
In octal :lol: the current count is 50. We're not adding to the collection at the moment, just concentrating on looking after the current ones.
We've got two old men who must be on their last (many) legs. They've lived a lot longer than expected for a mature male of those types.
Typically they get 6 to 18 months after reaching adulthood. These two have both survived over 3 years as adults so far.
Ace Rimmer
Sat Nov 11, 2017 6:06 am
That's a lot of legs Dom. I think I know how the old ones feel! Just had great success with the above line of code that ghp supplied. I'm now able to pick out whichever NMEA sentence I require, turn it into a list and then pick out different elements (altitude etc).
Thanks again ghp
Ace Rimmer
Sun Nov 12, 2017 11:16 pm
OK, my next problem, this code works great
 import serial
ser=serial.Serial(' /dev/ttyUSB0',9600)
while 1:
    if ( '$GPGGA' ) in textln:
        listba=textln.split( ' , ')
        print ' your altitude is ',listba[9], ' metres above sealevel'
but instead of printing line after line I would like it to erase the line just printed and print it again with the updated value on the same line.
I'm using Python 2.7.* Any ideas?
Mon Nov 13, 2017 2:27 am
Try this technique to overwriting python output
#!/usr/bin/python
import sys
import time
for i in range(0,101,10):
 sys.stdout.write("\r[%3d%%]" % i)
 sys.stdout.flush()
 time.sleep(1)
sys.stdout.write("\n")
sys.stdout.flush()
for i in range(0,10):
 sys.stdout.write("\rBlinking ...")
 sys.stdout.flush()
 time.sleep(0.5)
 sys.stdout.write("\r         ...")
 sys.stdout.flush()
 time.sleep(0.5)
sys.stdout.flush()
The \r returns to the start of the line, the flush ensures the line is written to stdout.
This is a doctor free zone.
Ace Rimmer
Mon Nov 13, 2017 3:42 am
Thanks Dougie, I'll give it a try this arvo if the boss doesn't catch me. I gather I just use "sys.stdout.write" instead of "print", I haven't used that method before. Cheers.
Ace Rimmer
Tue Nov 14, 2017 4:58 am
Yep, that worked - once I'd figured out how to concanate the components of the string - "print" is much easier! But oh for days of Qbasic with -
locate (row,column)
:roll:
Return to “Python”
