lambcutlet
[solved ]Warning **: Error retrieving accessibility bus address:
Tue Oct 24, 2017 8:23 pm
One issue I have always had was an error warning each time I started a python program from the commandline, for example 'python test.py'.
the warning
** (test.py:3047): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
to solve I installed 'at-spi2-core'
sudo apt-get install at-spi2-core
i found the answer in this thread https://github.com/NixOS/nixpkgs/issues/16327
jbeale
Re: [solved ]Warning **: Error retrieving accessibility bus address:
Sun Feb 25, 2018 5:09 am
Thanks! That got rid of the annoying message whenever I started a python program.
EdjeElectronics
Wed Apr 04, 2018 3:30 am
You the man! This worked for me too. Thanks for posting the solution here!
Check out my Raspberry Pi projects at www.youtube.com/c/EdjeElectronics !
PeterO
Wed Apr 04, 2018 5:21 am
at-spi2-core is on the list of "extra packages" I always install when building a new Raspbian disk.
That warning is not just a Python problem. For me it happens with all GTK+ applications (be they in Python or in C).
PeterO
bonzadog
Mon Jun 04, 2018 11:26 am
Using Debians STRETCH on the raspberry pi I received this error:
sudo apt-get update && apt-get dist-upgrade.....
[email protected]:~ $ sudo apt-get install at-spi2-core
Reading package lists... Done
Building dependency tree
The following NEW packages will be installed:
at-spi2-core
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/63.4 kB of archives.
After this operation, 402 kB of additional disk space will be used.
Selecting previously unselected package at-spi2-core.
dpkg: unrecoverable fatal error, aborting:
files list file for package 'libapt-inst2.0:armhf' is missing final newline
E: Sub-process /usr/bin/dpkg returned an error code (2)
So probably the at-spi2-core in not valid for the RPi - but I cannot find an alternative.
Any help on this please.
billybangleballs
Mon Nov 05, 2018 8:20 pm
[email protected]:~# uname -a
Linux sane 4.14.69-v7+ #1141 SMP Mon Sep 10 15:26:29 BST 2018 armv7l GNU/Linux
[email protected]:~# apt-get install at-spi2-core
at-spi2-core
0 upgraded, 1 newly installed, 0 to remove and 17 not upgraded.
Need to get 63.4 kB of archives.
Get:1 http://raspbian.mirror.uk.sargasso.net/raspbian stretch/main armhf at-spi2-core armhf 2.22.0-6+deb9u1 [63.4 kB]
Fetched 63.4 kB in 0s (209 kB/s)
(Reading database ... 164657 files and directories currently installed.)
Preparing to unpack .../at-spi2-core_2.22.0-6+deb9u1_armhf.deb ...
Unpacking at-spi2-core (2.22.0-6+deb9u1) ...
Setting up at-spi2-core (2.22.0-6+deb9u1) ...
Installed Ok here, and stopped the :- ** (java:16042): WARNING **: Error retrieving accessibility bus address: org.freedesktop.DBus.Error.ServiceUnknown: The name org.a11y.Bus was not provided by any .service files
that I was getting after building angryip.
It is a fairly recent version of Raspbian.
Grumpy old man.
Ex-G0KAP - I'd rather be doing it than talking about it.
"When found, make a note of." - Captain Cuttle
Return to “Python”
