ksharindam
pi3d - merge shapes of two different colors
Mon Oct 16, 2017 7:27 am
I want to create a project to view ball and stick model using pi3d. I want balls to be grey and sticks white.
but when I merge balls and sticks using MergeShape , balls and sticks become same colored.
import pi3d
display = pi3d.Display.create()
camera = pi3d.Camera(eye=(0, 0, -8))  # move camera back
ball = pi3d.Sphere()
cylinder = pi3d.Cylinder(height=3, radius=0.2)
cylinder.set_material((1.0,1.0,1.0))   # Set sticks color white
mol = pi3d.MergeShape(name="merge balls and sticks")
mol.add(ball, -2,0,0)
mol.add(ball, 2,0,0)
mol..add(cylinder, 0, 0, 0, rz=90)
while display.loop_running():
    mol.draw()
How can I do that.
PiGraham
Re: pi3d - merge shapes of two different colors
Mon Oct 16, 2017 9:09 am
I don't much about Pi3D but maybe you can apply a texture to the merged shape to colour it. Alternatively keep the parts as separate meshes with their own colours. There is an AddChild function. Would that allow you to add the ball as a child of a stick so that you can move both as a unit?
The Tiger Tank example might be relevant.
paddyg
Mon Oct 16, 2017 11:26 am
Hi, @PiGraham is right that one way getting different material colours would be to 'trick' it by using a texture, but it's a bit non-standard, see below. I suspect that you might be hoping to have a large number of balls and sticks (as for a molecule model) which means that the simple parent child option is not an option, but a merged parent to a merged child might be.
The benefit of the MergeShape is that it consolidates all the vertex info into one large Buffer so only one draw() with associated slow python transformation matrix generation has to be done for all the different components. However each Buffer object only has one RGB material slot so each MergeShape is one colour.
a) The texture option. Here the UV coordinates for each component are moved so they only sample a part of the texture. This involves hacking into the numpy array of the Buffer object of the Shape so a bit low level
b) Two MergeShapes one a child of the other. This is probably more in line with your original idea.
import pi3d
# 1. Textures
shader = pi3d.Shader('uv_light')
tex = pi3d.Texture('textures/molecule.jpg')
ball.buf[0].array_buffer[:,6:8] *= 0.5 # map UV 0 to 0.5 instead of 0 to 1.0
cylinder.buf[0].array_buffer[:,6:8] = 0.5 + cylinder.buf[0].array_buffer[:,6:8] * 0.5 # map UV 0.5 to 1.0 instead of 0 to 1.0
mol.add(cylinder, 0, 0, 0, rz=90)
mol.set_draw_details(shader, [tex])
# 2. Materials
balls = pi3d.MergeShape(name="merge balls")
balls.add(ball, -2,0,0)
balls.add(ball, 2,0,0)
balls.set_material((1.0, 1.0, 0.0))
mol = pi3d.MergeShape(name="merge sticks")
mol.set_material((1.0, 1.0, 1.0))
mol.add_child(balls)
    mol.draw()
    mol.rotateIncY(0.5)
Screenshot from 2017-10-16 12-12-44.jpg (22.15 KiB) Viewed 820 times
Screenshot from 2017-10-16 12-07-04.jpg (52.23 KiB) Viewed 820 times
P.S. I think I will add a demo along the lines of the following, showing a multi material merge shape. (Figuring out the cylinders is rather non-trivial so I've scaled up the atoms!)
import pi3d
''' ADP-glucose C16H25N5O15P2 from pubchem.ncbi.nlm.nih.gov
 in form of atomic number then x,y,z locations '''
data = [[15, -0.3572, 3.4667, 1.1986], # phosphorus
        [15, -2.6623, 1.6752, 1.5647],
        [8, 3.0375, 1.6867, -0.7958], # oxygen
        [8, -1.7977, -0.8219, -0.8898],
        [8, 3.0649, 2.0131, -3.8274],
        [8, 2.8223, -0.6735, -3.4983],
        [8, 0.9316, 3.2251, 0.2511],
        [8, -2.945, 0.2338, 0.8963],
        [8, -5.6128, -2.2109, -1.6422],
        [8, -3.6312, -4.0059, -0.5918],
        [8, -5.2209, 0.5051, -0.7228],
        [8, -1.1971, 2.0963, 1.0268],
        [8, 0.2199, -2.7404, 0.0502],
        [8, -1.2455, 4.5426, 0.3799],
        [8, -3.6502, 2.6889, 0.7814],
        [8, -0.0588, 3.8423, 2.6206],
        [8, -2.8016, 1.7059, 3.0593],
        [7, 3.4839, -0.6076, -0.3869], # nitrogen
        [7, 4.1899, -2.4453, 0.6593],
        [7, 1.7782, 0.1326, 1.1761],
        [7, 1.6092, -1.3788, 3.0848],
        [7, 2.9886, -3.3212, 3.3116],
        [6, 2.0293, 1.572, -2.9492], # carbon
        [6, 2.3367, 0.1666, -2.4712],
        [6, 2.1037, 2.3788, -1.6567],
        [6, 3.3925, 0.4325, -1.4091],
        [6, -4.5157, -1.7951, -0.8256],
        [6, -3.3273, -2.7146, -1.1141],
        [6, -4.1665, -0.3458, -1.1584],
        [6, -2.0394, -2.1726, -0.4795],
        [6, 0.7655, 2.4714, -0.9372],
        [6, -2.8438, 0.078, -0.5179],
        [6, -0.814, -2.9872, -0.8848],
        [6, 2.7408, -0.7016, 0.7552],
        [6, 4.3393, -1.6774, -0.3998],
        [6, 3.194, -1.8471, 1.3898],
        [6, 2.5901, -2.1771, 2.5989],
        [6, 1.2692, -0.2895, 2.3539],
        [1, 1.0792, 1.6507, -3.4853], # hydrogen
        [1, 1.4367, -0.2875, -2.0386],
        [1, 2.5103, 3.3838, -1.8158],
        [1, 4.3958, 0.5377, -1.8407],
        [1, -4.8518, -1.8892, 0.2135],
        [1, -3.1984, -2.8228, -2.198],
        [1, -4.0919, -0.2444, -2.2487],
        [1, -2.1202, -2.1969, 0.6158],
        [1, 0.0254, 2.9639, -1.5758],
        [1, 0.4013, 1.4726, -0.6824],
        [1, -2.5686, 1.0477, -0.9476],
        [1, -0.4554, -2.7034, -1.8798],
        [1, -1.022, -4.0612, -0.8668],
        [1, 2.862, 2.931, -4.0768],
        [1, 3.0455, -1.5303, -3.0967],
        [1, 5.0439, -1.8453, -1.2029],
        [1, -5.3466, -2.1268, -2.5736],
        [1, -3.712, -3.9276, 0.3741],
        [1, -4.9662, 1.4192, -0.935],
        [1, 0.9902, -3.264, -0.2292],
        [1, 0.4798, 0.3259, 2.7721],
        [1, -3.7445, 3.6079, 1.111],
        [1, -1.5239, 4.3358, -0.5374],
        [1, 3.7202, -3.9185, 2.951],
        [1, 2.5345, -3.5398, 4.188]]
atoms = {1:['hydrogen', 0.5, (1.0, 0.0, 0.0)],
         6:['carbon', 0.8, (0.1, 0.1, 0.1)],
         7:['nitrogen', 0.9, (0.1, 0.9, 1.0)],
         8:['oxygen', 0.9, (1.0, 1.0, 1.0)],
         15:['phosphorus', 1.5, (1.0, 0.0, 1.0)]}
camera = pi3d.Camera()
ball = pi3d.Sphere(radius=atoms[6][1])
carbon = pi3d.MergeShape(z=15)
for a in data:
  if a[0] == 6:
    carbon.add(ball, a[1], a[2], a[3])
carbon.set_material(atoms[6][2])
for e in atoms:
  if e != 6: # don't do carbon again
    ball = pi3d.Sphere(radius=atoms[e][1])
    elem = pi3d.MergeShape()
    for a in data:
      if a[0] == e:
        elem.add(ball, a[1], a[2], a[3])
    elem.set_material(atoms[e][2])
    carbon.add_child(elem)
    carbon.draw()
    carbon.rotateIncY(0.5)
    carbon.rotateIncZ(0.1)
also https://groups.google.com/forum/?hl=en-GB&fromgroups=#!forum/pi3d
ksharindam
Mon Oct 16, 2017 2:15 pm
Thanks to both PiGraham and paddyg.
Special thanks to paddyg for giving this elaborate answer.
Return to “Python”
