joseplaselva
Sending by mail image files from a folder
Sun Oct 15, 2017 2:44 pm
Hi, I have a folder ( USB stick ) containing jpg files , I want, if it is possible do the folowing actions.
Select a file from this folder ( the oldest )
Send it by mail
and after succes eliminate it
take the folowing one amd make the same procedure until there is no file left...
Exist a way to do it inside a python script?
Thanks in advance for your allways valuable answerds
MrYsLab
Re: Sending by mail image files from a folder
Sun Oct 15, 2017 7:17 pm
Step 1. Sort the files in your directory so that the oldest shows first
import os
search_dir = "PUT YOUR FULL DIRECTORY PATH HERE"
os.chdir(search_dir)
files = filter(os.path.isfile, os.listdir(search_dir))
files = [os.path.join(search_dir, f) for f in files] # add path to each file
files.sort(key=lambda x: os.path.getmtime(x))
for f in files:
    print(f)
Step 2. In the for loop, send out each file as an attachment
You can find information on how to do this here: https://stackoverflow.com/questions/336 ... ttachments
Step 3. Remove the file from the directory
def remove(path):
    """ param <path> could either be relative or absolute. """
    if os.path.isfile(path):
        os.remove(path)  # remove the file
    elif os.path.isdir(path):
        shutil.rmtree(path)  # remove dir and all contains
    else:
        raise ValueError("file {} is not a file or dir.".format(path))
joseplaselva
Tue Oct 17, 2017 1:15 pm
Thanks a lot for your early reply, it helps me a lot , for the first part to read folder runs perfect , but when I try to send by mail something rare occurr. Give a look at this code
for f in files:
    missedpic = missedpic + 1
    timenu= str(time.strftime("%A %y-%b-%d"))
    texmed = "Missed Pics " + timenu + " (pic " + str(missedpic) + "/" + str(nrpics) + ")"
    datum = f[16:26]
    tid =  f[26:32]
    time = tid[0:3]
    minut = tid[3:6]
    jpgnam = datum + time +":"+minut
    texte= "picture : " + jpgnam
    mail = MIMEMultipart()
    mail['Subject'] = str(texmed) # "Pictures from home"
    mail['From'] = fromaddr
    mail['To'] = toaddr
    mail.attach(MIMEText(texte, 'plain'))
    jpg_file=f
    attachment = open(jpg_file, 'rb')
    image=MIMEImage(attachment.read())
    attachment.close()
    mail.attach(image)
    server = smtplib.SMTP('smtp.gmail.com', 587)
    server.starttls()
    server.login(fromaddr, "pasword")
    text = mail.as_string()
    server.sendmail(fromaddr, toaddr, text)
    server.quit()
the first mail goes well but when prepare the second a Error happens :
AttributeError: 'str' object has no attribute 'strftime'
Why runs well the first time and not the second ??????
I have ben testing in a external editor as:
for x in xrange(4):
    timenu = str(time.strftime("%A %y-%b-%d "))
#dagtid = str(time.strftime("%y-%b-%d_(%H:%M)"))
    texmed = "Missed Pics "+ timenu
    print texmed
and it runs perfectly, why not inside the script in the Raspi
joseplaselva
Tue Oct 17, 2017 1:39 pm
Sorry forget the last reply , it was my fault because somewhere before in the script I was assigning a string to a variable time... thats why.
I folow testing.
Thanks for your valuable help
joseplaselva
Tue Oct 17, 2017 1:44 pm
Its works perfectly folowing your valuable indications.
Thaks a lot
MrYsLab
Tue Oct 17, 2017 2:17 pm
My pleasure.
joseplaselva
Wed Oct 18, 2017 11:02 am
Hi, here I am again with a question for a new problem.
In my python script I use the folowing code to write in a text file all the procedures of the script to check logical errors:
with open('./log.txt', 'a') as log_txt:
    timenow = str(time.strftime("%H:%M:%S"))
    log_txt.write(timenow + "FILES IN PENDRIVE = " + str(nrpics))
When I use the code you told me for read the Pendrive content:
search_dir = "/media/pendrive"
nrpics = 0
files = [os.path.join(search_dir, fil) for fil in files] # add path to each file
for fil in files:
    nrpics = nrpics + 1
It happens that a copy of the text file appears inside the pendrive folder and nothing is writed in the original text file in home directory....
Why thuis rare behaviour? I'm doing somethig wrong ?
Thanks for some help
MrYsLab
Wed Oct 18, 2017 1:20 pm
I am not sure I totally understand your problem, but perhaps you should call log_txt.close() to flush the file.
joseplaselva
Wed Oct 18, 2017 2:00 pm
Hi, thanks again for your fast reply. I found a solution at this problem. It seems that when I declare :
os.chdir(search_dir
it change the main directory, that's why it creates a new text file inside the pendrive because does not exist...
So the solution I found is to redirect again the main directory to the original path just declaring again the original path after running the read pendrive procedures :
 path = "/home/pi/"
 os.chdir(path)
elParaguayo
Wed Oct 18, 2017 2:02 pm
There's no need to use ".close()" when using a "with" context manager structure. The close happens at the end of the block (or if there's an exception in the block).
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
joseplaselva
Wed Oct 18, 2017 3:01 pm
Hereby part of the script that get mi crazy, may be you can find the error. After a loop that looks the real time to chek if the determinated stop_time has arrived, it stops capturing interval images and send those by mail.
Starts the final procediures :
1/ Send the log.txt file where are registered all the procedures of the day .
2/ Check if the pendrive folder has images files (moved when no network access)
3/ Send the images stored in the pendrive by mail and delete them.
path = "/home/pi/"
moveto = "/media/pendrive/"
data=""
dagtid=""
texte=""
texmed =""
netflag = 1
nrpics = 1
#----------------------------------------------------------- STARTING SHUTDOWN PROCEDURES......
def Shutdown():
    global nrpics
        timenu = str(time.strftime("%H:%M:%S"))
        log_txt.write(timenu + "====================================STARTING FINAL PROCEDURES" + os.linesep)
        log_txt.write(timenu + "...CHECKING PENDRIVE..." + os.linesep)
    if nrpics ==1:
        check_pendrive()
    else:
        try:
            SendMailLog()
        except Exception as err:
                log_txt.write(timenu + "=!=SHUTDOWN: ERROR SENDING LOG.TXT FILE BY MAIL.......ERROR" +  os.linesep)
        turnoff()
def SendMailLog():
    os.chdir(path)
        log_txt.write(timenu + "...SHUTDOWN: SENDING LOG.TXT FILE BY MAIL-" +  os.linesep)
        log_txt.write(timenu + "...TURNING RASPBERRY PI OFF IN 5 minutes  ...." +  os.linesep)
        log_txt.write(timenu + "================================== FINAL PROCEDURES ACCOMPLISHED" + os.linesep)
    filename = "log.txt"
    f = file(filename)
    attachment = MIMEText(f.read())
    attachment.add_header('Content-Disposition', 'attachment', filename=filename)
    mail['Subject'] = "LaSelvaPiZW-TEST-SHUTDOWN-LOG" + str(time.strftime("%y-%b-%d (%H:%M)"))
    mail['To'] = toaddr
    mail.attach(attachment)
    server.starttls()
    server.login(fromaddr, "laselva56")
    server.quit()
    f = open('log.txt', 'w')
    f.close()
    turnoff()
def check_pendrive():
    global nrpics
    nrpics=0
    for fil in files:
        nrpics = nrpics + 1
    if nrpics==0:
        try:
            SendMailLog()
            os.chdir(path)
                log_txt.write(timenu + "=!=SHUTDOWN: ERROR SENDING LOG.TXT BY MAIL.....ERROR" +  os.linesep)
            turnoff()
    else:
        try:
            sendmissedpics()
            os.chdir(path)
                log_txt.write(timenu + "=!=SHUTDOWN: ERROR SENDING MISSED PICS BY MAIL..ERROR" +  os.linesep)
            turnoff()
def sendmissedpics():
    global nrpics
    nrpics=0
    for fil in files:
        nrpics = nrpics + 1
    print "nrpics", nrpics
    print "fil" , fil
    print "files ", files
    for fil in files:
        datum = fil[16:26]
        tid =  fil[26:32]
        timer = tid[0:3]
        minut = tid[3:6]
        jpgnam = datum + timer +":"+minut
        timenu = str(time.strftime("%A %y-%b-%d"))
        os.chdir(path)
        mail['To'] = toaddr
        jpg_file=fil
        attachment.close()
        mail.attach(image)
        server.starttls()
        server.quit()
    nrpics = 0
    os.chdir(path)
        log_txt.write(timenu + "...SUCCEED SENDING " + str(nrpics) +" MISSED PICS BY MAIL" +  os.linesep)
    turnoff()
def turnoff():
        log_txt.write(timenu + "..TURNING OFF THE RASPBERRY IN 5 SECONDS" +  os.linesep)
    time.sleep(5)
    os.system("sudo halt")
#----INTERVAL CHECKING PROCEDURES--------------------------------
# EACH MINUTE -------------------------------------------------------------
while True:
   time_now = datetime.datetime.now().time().strftime('%H:%M:%S')
   if time_now  > stoptime:
       if netflag == 0:
            stoptime = "10:59:00"
            time.sleep(60)
       else:
                log_txt.write(timenu + "...STOP TIME ATTEMPTED ...." +  os.linesep)
            Shutdown()
   elif str(datetime.datetime.now().time())[6:8]== interval :
        while str(datetime.datetime.now().time())[6:8]== interval:
            time.sleep(.1)
        if time_now > startcapture:
            capture_image()
Return to “Python”
Who is online
Users browsing this forum: No registered users and 8 guests
