sayhello
headstart with python - using the overpass-api-python wrapper
Sat Oct 14, 2017 9:00 am
hello dear community
i am pretty new to this great site.
currently want to dive into Python with some real world projects +
connecting to the endpoint of Overpass.
(BTW - this is what i want to let to do the Raspi - automatically - with cron jobs. )
one question:
is this the same https://github.com/DinoTools/python-overpy like this- https://github.com/mvexel/overpass-api-python-wrapper
guess no:
with the overpass-api-python wrapper i want to do the first steps today:
the examples that are shown here: https://github.com/mvexel/overpass-api-python-wrapper - they are written in Python version 2xy
so they do not work with the Version 3 xy
well this example code here:
import overpass
api = overpass.API()
response = api.Get('node["name"="Salt Lake City"]')
should give with this command #
print [(feature['tags']['name'], feature['id']) for feature in response['elements']]
[(u'Salt Lake City', 150935219), (u'Salt Lake City', 585370637), (u'Salt Lake City', 1615721573)]
a list of comma seperated values - is this correct.... ?
any idea !?
DirkS
Re: headstart with python - using the overpass-api-python wrapper
Sat Oct 14, 2017 9:20 am
The only example I see there is written for Python 3
https://github.com/mvexel/overpass-api- ... list.py#L1
scruss
Mon Oct 16, 2017 12:02 am
(posted from duplicate thread - please don't do that)
Can you fix up what's supposed to be in the code bits and what's supposed to be in text mode, please?
I'm fairly well acquainted with OpenStreetMap's Overpass servers, but never used the Python module. Until now …
Looks like the docs are incorrect, as the example query
print( [(feature['tags']['name'], feature['id']) for feature in response['elements']] )
doesn't work, under python3 at least. This works as expected, however:
print( [(feature['properties']['name'], feature['id']) for feature in response['features']] )
[('Salt Lake City', 150935219), ('Salt Lake City', 585370637)]
The output isn't CSV, but GeoJSON. The result above is a list of lists, so is a special case that could easily be represented as CSV:
Name,ID
By the looks of things (aka my many errors), the wrapper simply takes whatever you pass to Get() and wraps it in:
[out:json];
 /* *** YOUR QUERY HERE *** */
out body geom;
So you wouldn't specify the output format, the fields you want, or the out command at the end. You'd have to iterate through the response structure, pulling out the name, postcode, city, etc as in the Salt Lake City example.
OpenStreetMap Help Forum might be a better place to ask, or ask Martijn (the author) directly.
Return to “Python”
