Joker56
python astral raspberry pi
Fri Oct 13, 2017 9:39 pm
Hello all,
I made a python script who is calculating the sunrise and sunset for an certain date.
When i run that script in the terminal (putty) it works fine.
But i want to run that scrip at startup on my raspberry. Thats when it goes wrong.
I get this error:
  File "/home/pi/calculate_light.py", line 6, in <module>
    from astral import Astral
ImportError: No module named astral
Does anybody knows why my script "calculate_light.py" runs fine in the terminal but not when booting my pi?
This is the code I'm talking about
import datetime
import time
import RPi.GPIO as GPIO
GPIO.setmode(GPIO.BOARD)
#GPIO.setwarnings(False)
import subprocess
city_name = 'Brussels'
a = Astral()
a.solar_depression = 'civil'
city = a[city_name]
timezone = city.timezone
sun = city.sun(date=datetime.date.today(), local=True)
tzinfo = sun['dawn'].tzinfo
print('Dawn:    %s' % str(sun['dawn']))
print('Sunrise: %s' % str(sun['sunrise']))
print('Noon:    %s' % str(sun['noon']))
print('Sunset:  %s' % str(sun['sunset']))
print('Dusk:    %s' % str(sun['dusk']))
Thanks in advance
asavah
Re: python astral raspberry pi
Sat Oct 14, 2017 12:39 am
How exactly you are starting your script?
You get the error because because python doesn't know where to find your astral module because it not in python's sys.path
Two ways to fix this:
1) In your start script first
cd /home/pi/
or if it's systemd service add
WorkingDirectory=/home/pi
2) Add /home/pi to sys.path in the script itself before importing astral
import sys
sys.path.insert(0, "/home/pi")
Here I assume that astral module is located in "/home/pi"
Joker56
Sat Oct 14, 2017 7:11 am
It still doesn't work.
this is the code from my launcher.sh script.
cd /
cd /home/pi
sudo python calculate_light.py
cd /
added /home/pi to sys.path.
import datetime
import time
import sys
import subprocess
a = Astral()
city = a[city_name]
now = datetime.datetime.now(tzinfo)
mydate =  datetime.datetime(2017, 10, 12, 5, 5, 5, 78915, tzinfo)
Maybe the astral module isn't located in the /home/pi folder?
I installed the astral module like this .
pip install astral
DirkS
Sat Oct 14, 2017 9:41 am
pip install astral
You need admin permissions to install modules with pip, so you may need to use 'sudo pip'
BTW: I don't think you need sudo to run your script.
Joker56
Sat Oct 14, 2017 10:17 am
The problem is that my script runs fine in the terminal but won't run automatically when booting my rpi.
Thi is the error description:
asavah
Sat Oct 14, 2017 2:06 pm
My assumption was wrong, because you did not provide enough information to get help.
Want help ? Provide info. We don't have psychic powers here.
You still didn't answer the question "How exactly you are starting your script?"
contents of your launcher.sh is not enough, how is it hooked? where? is it in rc.local? or is it a systemd service? or wahtever?
If you installed astral as user it will be available only to your user, not systemwide.
To reinstall it systemwide do:
pip uninstall astral
sudo pip install astral
Joker56
Sat Oct 14, 2017 7:14 pm
Yes this solved this issue.
My script runs fine when my pi boots.
Thanks!
Return to “Python”
