gintonik
ImportError: No module named sh
Tue Oct 03, 2017 5:13 pm
i have a problem and doesn´t find a solution. I try to cotrol a canon powershot by using a rpi. the programm gphoto2 brings everything i need to go. the single commands executed from bash works fine. Then i want to build a python script for controlling the cam. i saw a Video on https://www.youtube.com/watch?v=1eAYxnS ... 42&list=WL and copied everything he told, thats the basement of my own project.
After executing python script this Message will be shown:
File "capture.py", line 3, in <module>
from sh import gphoto2
I start project with installing rasbian strech to a new SD-Card on a Rpi Zero W.
Update and upgrade, installing "sudo apt-get install python3-pip" and "sudo pip3 install sh"
already done. I tried for searching a solution but doesn´t get a result.
Here´s my used Script:
from time import sleep
from datetime import datetime
from sh import gphoto2 as gp
import os, signal, subprocess
#kill gphoto2 process
#starts whenever camera connect
#def killgphoto2process():
#    p = subprocess.Popen(['ps', '-A'], stdout=subprocess.PIPE)
#    put, err = p.communicate()
# search for the line that the process we want to kill
#    for line in out.spitlines():
#        if b'gvfsd-gphoto2' in line:
            # kill the process!
#            pid = int(line.split(NONE, 1) [0])
#            os.kill(pid, signal.SIGKILL)
shot_date = datetime.now().strftime("%Y-%m-%d-")
shot_time = datetime.now().strftime("%Y-%m-%d %h:%m:%s")
picID = "PiShots"
clearCommand = ["--folder", "/store_00010001/DCIM/100CANON", \
                "-R", "--delete-all-files"]
triggercommand = ["--trigger-capture"]
downloadCommand = ["--get-all-files"]
foldername = shot_date + picID
save_location = "/home/pi/Pictures/gphoto" + foldername
def createSaveFolder():
    try:
        os.makedirs(save_location)
    except:
        print ("Failed to create new directory.")
    os.chdire(save_location)
def captureImages():
    gphoto2(triggercommand)
    sleep(3)
    gphoto2(downloadCommand)
    gphoto2(clearCommand)
def renameFiles(ID):
    for filename in os.listdir("."):
        if len(filename) < 13:
            if filename.endswith(".JPG"):
                os.rename(filename, (shot_time + ID + ".JPG"))
                print("renamed the JPG")
            elif filename.endswith(".CR2"):
                os.rename(filename, (shot_time + ID + ".CR2"))
                print ("renamed the CR2")
#killgphoto2Process()
createSaveFolder()
captureImages()
renameFiles(picID)
Don´t know what can i do anything...
elParaguayo
Re: ImportError: No module named sh
Tue Oct 03, 2017 5:49 pm
You've installed the module for python 3 but I suspect you're running your script with python 2. Have you tried running your script with python3 e.g. "python3 capture.py"?
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
gintonik
Tue Oct 03, 2017 6:09 pm
Hi elParaguayo,
you damm crazy guy!
Thats it!
Brilliant!
It´s a long time ago last time a written a script and i never used the version-number behind python else.
No i start it with and it works !!!
 SUDO PYTHON3 SCRIPT.PY
THANKS THANKS THANKS !!!!
learned something again...
sameenashaikh29
Thu Jan 18, 2018 12:38 pm
How can i install sh for pip2 or python 2 as i wan to work with python 2 itself for rest part of the code. As my dronekit should be done with python2 itself..
Thanks & Regards
Sameena Shaikh
Return to “Python”
