not all arguments converted during string formatting
Posted: Thu Aug 31, 2017 12:35 am
by whowantspi
I'm trying to read data from a VEML 6075 UV sensor. My code is ...
#!/usr/bin/env python3
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# VEML6075 address, 0x10(16)
bus.write_word_data(0x10, 0x00, 0x0040)
time.sleep(1.0)
uva = bus.read_word_data(0x10, 0x07)
uvb = bus.read_word_data(0x10, 0x09)
uvcomp1 = bus.read_word_data(0x10, 0x0A)
uvcomp2 = bus.read_word_data(0x10, 0x0B)
UVA = uva * 1  # Added this just to see what would happen, no error
# Output data to screen
print ("Raw UVA is :" %uva)
I get the error...
./veml6075.py
File "./veml6075.py", line 22, in <module>
TypeError: not all arguments converted during string formatting
The data sheet can be found here https://www.vishay.com/docs/84304/veml6075.pdf
At the top of page 6 it says...
"The VEML6075 contains a CONF register (00h) used for operation control and parameter setup. Measurement results are stored in four separate registers, one each for UVA, UVD, UVB, UVcomp1, and UVcomp2 (07h to 0Bh respectively). All registers are accessible via I2C communication. Fig. 7 shows the basic I2C communication with the VEML6075. Each of the registers in the VEML6075 are 16 bit wide, so 16 bit should be written when a write command is sent, and 16 bit should be read when a read command is sent."
And this why I'm having to use "bus.write_word_data" and "bus.read_word_data". So far I haven't been able to print anything. I've Googled and found the error message but none of the solutions seemed to make any difference. This is the first device I've used that had 16 bit vs. 8 bit registers. Any help would be welcomed.
Max
Re: not all arguments converted during string formatting
Posted: Thu Aug 31, 2017 5:54 am
by elParaguayo
That's not a string formatting command, it looks like you just wanted to append the value of uva to the end of the string.
Try this:
print ("Raw UVA is : {}".format(uva))
Or
print ("Raw UVA is : %s" % uva)
Posted: Thu Aug 31, 2017 2:36 pm
by whowantspi
I tried the second example and it worked. But it must have something to do with the variable created by the "bus.read_word_data" because my other sensors that use "bus.read_byte_data" can print without the "%s". I'm new at programming and this really had me confused.
Thanks, now I can get on with the rest of the program.
Max
Posted: Fri Sep 01, 2017 2:25 pm
by paddyg
It seems to be a function of passing a variable that is iterable which seems to bypass the error catching. You get the same effect with string.format() (which imho is a better system)
>>> x = 9
>>> a = 9
>>> b = bytes(9)
>>> c = bytes([9])
>>> d = '9'
>>> for i in (a, b, c, d):
...   print('type(i): ', type(i))
...   try:
...     print('worked after a fasion', 'Raw UVA: ' % i)
...   except Exception as e:
...     print('failed with: ', e)
type(i):  <class 'int'>
failed with:  not all arguments converted during string formatting
type(i):  <class 'bytes'>
worked after a fasion Raw UVA:
type(i):  <class 'list'>
type(i):  <class 'str'>
Posted: Mon Dec 18, 2017 7:36 pm
by yv1hx
[...snip ....]
Max
Just in case you don't have catch this document: https://www.vishay.ru/docs/84339/designingveml6075.pdf
BR,
