pumpkinpi
Sharing data between python scripts through a LAN
Thu Aug 31, 2017 12:34 am
Hi Python Masters,
I have a bunch of Pi's running various python scripts in my house. They do a whole bunch of fun house monitoring jobs.
For quite a while, I was passing data between them via a simple NFS server and just writing the information to text files. I have had issues with the number of writes in those drives (USB thumb drives) and want to elevate my code a bit and have the scripts talk to themselves directly.
I think what I want to do is use socketserver:
https://docs.python.org/3/library/socketserver.html
to allow the simple passage of information from one Pi to the next and back.
Looking at this page, there are a whole lot of other options that may be too involved:
https://stackoverflow.com/questions/936 ... -in-python
I am not worried about security for my computers as they are all on a LAN and not communicating to the wider world (ie. behind a firewall).
Just looking for direction on what would be the simplest to implement and master.
Any advice appreciated.
PPi
asandford
Re: Sharing data between python scripts through a LAN
Thu Aug 31, 2017 12:50 am
Use MQTT. The python programs that currently write data would publish that to topics and the programs reading data will subscribe to those topics to receive the latest info.
Here's a tutorial that explains message queues, example 3 is relevant (the RabbitMQ package is conceptually the same as MQTT, but has more funtionality).
MrYsLab
Thu Aug 31, 2017 1:43 am
Take a look at python banyan https://github.com/MrYsLab/python_banyan. It is simple to use and has much better performance than MQTT.
pumpkinpi
Thu Aug 31, 2017 2:29 am
Both look like they would work. Doing some reading. Thanks for the help so far.
Thu Aug 31, 2017 10:44 am
(the RabbitMQ package is conceptually the same as MQTT Mosquitto, but has more funtionality).
MQTT is the protocol.
RabbitMQ is one broker.
Mosquitto is another broker.
RabbitMQ does more than Mosquitto.
This is a doctor free zone.
asandford
Thu Aug 31, 2017 9:09 pm
If you want to have a play around, an MQTT client is supplied with the in-built Node-Red, all you need is a broker.
asandford
Thu Aug 31, 2017 9:15 pm
And only works with python 3.4 (and above) :lol:
MrYsLab
Fri Sep 01, 2017 12:37 pm
Python banyan is now python2 and 3 compatible :D :D :D . It also allows for numpy matrix transfers as a single payload. And streaming messages on a single Rpi 3 is twice as fast as Mosquitto MQTT (test code is available in github).
pumpkinpi
Fri Sep 01, 2017 11:53 pm
I am going to give banyan a try. Problem is I get a ton of compilation errors when I run:
sudo pip install python-banyan
A couple of the errors that flew past my screen are:
    arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -DZMQ_HAVE_CURVE=1 -DZMQ_USE_TWEETNACL=1 -DZMQ_USE_EPOLL=1 -Ibundled/zeromq/include -Ibundled/zeromq/tweetnacl/src -Ibundled/zeromq/tweetnacl/contrib/randombytes -Ibundled -I/usr/include/python2.7 -c buildutils/initlibzmq.c -o build/temp.linux-armv6l-2.7/buildutils/initlibzmq.o
    buildutils/initlibzmq.c:10:20: fatal error: Python.h: No such file or directory
     #include "Python.h"
    compilation terminated.
    error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
    Complete output from command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-xK0ONM/pyzmq/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-fmwbE0-record/install-record.txt --single-version-externally-managed --compile:
    running install
And:
 #include "Python.h"
Cleaning up...
Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-xK0ONM/pyzmq/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-fmwbE0-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-xK0ONM/pyzmq
  File "/usr/bin/pip", line 9, in <module>
    load_entry_point('pip==1.5.6', 'console_scripts', 'pip')()
  File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 248, in main
    return command.main(cmd_args)
  File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 161, in main
    text = '\n'.join(complete_log)
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe2 in position 68: ordinal not in range(128)
Not sure what I am missing.
PPi
MrYsLab
Sat Sep 02, 2017 12:24 am
I just loaded this on the stretch distribution and here is my output:
[email protected]:~ $ sudo pip install python-banyan
Collecting python-banyan
  Using cached python-banyan-2.0.tar.gz
Collecting msgpack-numpy (from python-banyan)
  Using cached msgpack_numpy-0.4.1-py2.py3-none-any.whl
Collecting msgpack-python (from python-banyan)
  Using cached msgpack-python-0.4.8.tar.gz
Requirement already satisfied: numpy in /usr/lib/python2.7/dist-packages (from python-banyan)
Requirement already satisfied: psutil in /usr/local/lib/python2.7/dist-packages (from python-banyan)
Collecting pyzmq (from python-banyan)
  Using cached pyzmq-16.0.2.tar.gz
Collecting u-msgpack-python (from python-banyan)
  Using cached u_msgpack_python-2.4.1-py2.py3-none-any.whl
Building wheels for collected packages: python-banyan, msgpack-python, pyzmq
  Running setup.py bdist_wheel for python-banyan ... done
  Stored in directory: /root/.cache/pip/wheels/03/af/57/67a7478bf20c79a1b427c378a579c29fe879fd03c01b821397
  Running setup.py bdist_wheel for msgpack-python ... done
  Stored in directory: /root/.cache/pip/wheels/2c/e7/e7/9031652a69d594665c5ca25e41d0fb3faa024e730b590e4402
  Running setup.py bdist_wheel for pyzmq ... done
  Stored in directory: /root/.cache/pip/wheels/c8/68/e5/a747dfb649857b6e4f954ef922f41ac50d12142aefa58656a6
Successfully built python-banyan msgpack-python pyzmq
Installing collected packages: msgpack-python, msgpack-numpy, pyzmq, u-msgpack-python, python-banyan
Successfully installed msgpack-numpy-0.4.1 msgpack-python-0.4.8 python-banyan-2.0 pyzmq-16.0.2 u-msgpack-python-2.4.1
All packages loaded without error.
Which version of Raspbian are you using?
It looks like things are bombing in the load of pyzmq. Could you try typing:
sudo pip install pyzmq
and let me know if that succeeds.
pumpkinpi
Sat Sep 02, 2017 12:29 am
Running a fully updated version of Raspbian Jessie.
Tried this:
Get this (buffer does not hold everything):
    timer_createXLUUXL.c:(.text+0x14): undefined reference to `timer_create'
    collect2: error: ld returned 1 exit status
    no timer_create, linking librt
    building 'zmq.libzmq' extension
     #include "Python.h"
    Complete output from command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-vfKpE0/pyzmq/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-wwXCX8-record/install-record.txt --single-version-externally-managed --compile:
    running install
running build
running build_py
creating build
creating build/lib.linux-armv6l-2.7
creating build/lib.linux-armv6l-2.7/zmq
copying zmq/error.py -> build/lib.linux-armv6l-2.7/zmq
copying zmq/decorators.py -> build/lib.linux-armv6l-2.7/zmq
copying zmq/__init__.py -> build/lib.linux-armv6l-2.7/zmq
creating build/lib.linux-armv6l-2.7/zmq/auth
copying zmq/auth/certs.py -> build/lib.linux-armv6l-2.7/zmq/auth
copying zmq/auth/thread.py -> build/lib.linux-armv6l-2.7/zmq/auth
copying zmq/auth/__init__.py -> build/lib.linux-armv6l-2.7/zmq/auth
copying zmq/auth/ioloop.py -> build/lib.linux-armv6l-2.7/zmq/auth
copying zmq/auth/base.py -> build/lib.linux-armv6l-2.7/zmq/auth
creating build/lib.linux-armv6l-2.7/zmq/devices
copying zmq/devices/monitoredqueue.py -> build/lib.linux-armv6l-2.7/zmq/devices
copying zmq/devices/__init__.py -> build/lib.linux-armv6l-2.7/zmq/devices
copying zmq/devices/monitoredqueuedevice.py -> build/lib.linux-armv6l-2.7/zmq/devices
copying zmq/devices/basedevice.py -> build/lib.linux-armv6l-2.7/zmq/devices
copying zmq/devices/proxydevice.py -> build/lib.linux-armv6l-2.7/zmq/devices
creating build/lib.linux-armv6l-2.7/zmq/log
copying zmq/log/__init__.py -> build/lib.linux-armv6l-2.7/zmq/log
copying zmq/log/handlers.py -> build/lib.linux-armv6l-2.7/zmq/log
creating build/lib.linux-armv6l-2.7/zmq/green
copying zmq/green/poll.py -> build/lib.linux-armv6l-2.7/zmq/green
copying zmq/green/device.py -> build/lib.linux-armv6l-2.7/zmq/green
copying zmq/green/core.py -> build/lib.linux-armv6l-2.7/zmq/green
copying zmq/green/__init__.py -> build/lib.linux-armv6l-2.7/zmq/green
creating build/lib.linux-armv6l-2.7/zmq/green/eventloop
copying zmq/green/eventloop/__init__.py -> build/lib.linux-armv6l-2.7/zmq/green/eventloop
copying zmq/green/eventloop/ioloop.py -> build/lib.linux-armv6l-2.7/zmq/green/eventloop
copying zmq/green/eventloop/zmqstream.py -> build/lib.linux-armv6l-2.7/zmq/green/eventloop
creating build/lib.linux-armv6l-2.7/zmq/backend
copying zmq/backend/__init__.py -> build/lib.linux-armv6l-2.7/zmq/backend
copying zmq/backend/select.py -> build/lib.linux-armv6l-2.7/zmq/backend
creating build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/__init__.py -> build/lib.linux-armv6l-2.7/zmq/backend/cython
creating build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/utils.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/_poll.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/error.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/socket.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/__init__.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/constants.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/message.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/_cffi.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/context.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/devices.py -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
creating build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/version.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/frame.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/poll.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/socket.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/attrsettr.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/__init__.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/constants.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/tracker.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/context.py -> build/lib.linux-armv6l-2.7/zmq/sugar
copying zmq/sugar/stopwatch.py -> build/lib.linux-armv6l-2.7/zmq/sugar
creating build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_win32_shim.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_imports.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_error.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_auth.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_ssh.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_pair.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_ioloop.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_version.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_retry_eintr.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_device.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_z85.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_monitor.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_constants.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_context.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/__init__.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_poll.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_socket.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_etc.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_decorators.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_multipart.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_reqrep.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_message.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_log.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_zmqstream.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_pubsub.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_cffi_backend.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_monqueue.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_includes.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_security.py -> build/lib.linux-armv6l-2.7/zmq/tests
copying zmq/tests/test_future.py -> build/lib.linux-armv6l-2.7/zmq/tests
creating build/lib.linux-armv6l-2.7/zmq/eventloop
copying zmq/eventloop/future.py -> build/lib.linux-armv6l-2.7/zmq/eventloop
copying zmq/eventloop/__init__.py -> build/lib.linux-armv6l-2.7/zmq/eventloop
copying zmq/eventloop/ioloop.py -> build/lib.linux-armv6l-2.7/zmq/eventloop
copying zmq/eventloop/zmqstream.py -> build/lib.linux-armv6l-2.7/zmq/eventloop
creating build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
copying zmq/eventloop/minitornado/util.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
copying zmq/eventloop/minitornado/__init__.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
copying zmq/eventloop/minitornado/log.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
copying zmq/eventloop/minitornado/concurrent.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
copying zmq/eventloop/minitornado/ioloop.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
copying zmq/eventloop/minitornado/stack_context.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado
creating build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
copying zmq/eventloop/minitornado/platform/posix.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
copying zmq/eventloop/minitornado/platform/auto.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
copying zmq/eventloop/minitornado/platform/__init__.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
copying zmq/eventloop/minitornado/platform/interface.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
copying zmq/eventloop/minitornado/platform/windows.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
copying zmq/eventloop/minitornado/platform/common.py -> build/lib.linux-armv6l-2.7/zmq/eventloop/minitornado/platform
creating build/lib.linux-armv6l-2.7/zmq/ssh
copying zmq/ssh/__init__.py -> build/lib.linux-armv6l-2.7/zmq/ssh
copying zmq/ssh/tunnel.py -> build/lib.linux-armv6l-2.7/zmq/ssh
copying zmq/ssh/forward.py -> build/lib.linux-armv6l-2.7/zmq/ssh
creating build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/garbage.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/sixcerpt.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/strtypes.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/__init__.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/interop.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/jsonapi.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/constant_names.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/z85.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/monitor.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/win32.py -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/devices/monitoredqueue.pxd -> build/lib.linux-armv6l-2.7/zmq/devices
copying zmq/backend/cython/checkrc.pxd -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/libzmq.pxd -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/message.pxd -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/context.pxd -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/socket.pxd -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/constants.pxi -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cython/constant_enums.pxi -> build/lib.linux-armv6l-2.7/zmq/backend/cython
copying zmq/backend/cffi/_cdefs.h -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/backend/cffi/_verify.c -> build/lib.linux-armv6l-2.7/zmq/backend/cffi
copying zmq/utils/buffers.pxd -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/pyversion_compat.h -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/zmq_compat.h -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/getpid_compat.h -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/zmq_constants.h -> build/lib.linux-armv6l-2.7/zmq/utils
copying zmq/utils/ipcmaxlen.h -> build/lib.linux-armv6l-2.7/zmq/utils
running build_ext
running configure
Did not find libzmq via pkg-config.
{'libraries': ['zmq'], 'extra_link_args': [], 'runtime_library_dirs': [], 'library_dirs': [], 'include_dirs': []}
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -c build/temp.linux-armv6l-2.7/scratch/check_sys_un.c -o build/temp.linux-armv6l-2.7/scratch/check_sys_un.o
build/temp.linux-armv6l-2.7/scratch/check_sys_un.c: In function ‘main’:
build/temp.linux-armv6l-2.7/scratch/check_sys_un.c:6:5: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘unsigned int’ [-Wformat=]
     printf("%lu\n", sizeof(dummy->sun_path) - 1);
arm-linux-gnueabihf-gcc -pthread build/temp.linux-armv6l-2.7/scratch/check_sys_un.o -o build/temp.linux-armv6l-2.7/scratch/check_sys_un
Configure: Autodetecting ZMQ settings...
    Custom ZMQ dir:
creating build/temp.linux-armv6l-2.7/scratch/tmp
cc -c /tmp/timer_create7wCR4A.c -o build/temp.linux-armv6l-2.7/scratch/tmp/timer_create7wCR4A.o
cc build/temp.linux-armv6l-2.7/scratch/tmp/timer_create7wCR4A.o -o build/temp.linux-armv6l-2.7/scratch/a.out
build/temp.linux-armv6l-2.7/scratch/tmp/timer_create7wCR4A.o: In function `main':
timer_create7wCR4A.c:(.text+0x14): undefined reference to `timer_create'
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -Izmq/utils -Izmq/backend/cython -Izmq/devices -c build/temp.linux-armv6l-2.7/scratch/vers.c -o build/temp.linux-armv6l-2.7/scratch/vers.o
build/temp.linux-armv6l-2.7/scratch/vers.c:4:17: fatal error: zmq.h: No such file or directory
 #include "zmq.h"
Failed with default libzmq, trying again with /usr/local
{'libraries': ['zmq'], 'extra_link_args': [], 'runtime_library_dirs': [], 'library_dirs': ['/usr/local/lib'], 'include_dirs': ['/usr/local/include']}
    Custom ZMQ dir:       /usr/local
cc -c /tmp/timer_createEh3fU0.c -o build/temp.linux-armv6l-2.7/scratch/tmp/timer_createEh3fU0.o
Assembler messages:
Fatal error: can't create build/temp.linux-armv6l-2.7/scratch/tmp/timer_createEh3fU0.o: No such file or directory
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/local/include -Izmq/utils -Izmq/backend/cython -Izmq/devices -c build/temp.linux-armv6l-2.7/scratch/vers.c -o build/temp.linux-armv6l-2.7/scratch/vers.o
 #include "zmq.h"
Warning: Couldn't find an acceptable libzmq on the system.
If you expected pyzmq to link against an installed libzmq, please check to make sure:
    * You have a C compiler installed
    * A development version of Python is installed (including headers)
    * A development version of ZMQ >= 3.2 is installed (including headers)
    * If ZMQ is not in a default location, supply the argument --zmq=<path>
    * If you did recently install ZMQ to a default location,
      try rebuilding the ld cache with `sudo ldconfig`
      or specify zmq's location with `--zmq=/usr/local`
You can skip all this detection/waiting nonsense if you know
you want pyzmq to bundle libzmq as an extension by passing:
    `--zmq=bundled`
I will now try to build libzmq as a Python extension
unless you interrupt me (^C) in the next 10 seconds...
 1...
Using bundled libzmq
already have bundled/zeromq
attempting ./configure to generate platform.hpp
Warning: failed to configure libzmq:
/bin/sh: 1: ./configure: not found
staging platform.hpp from: buildutils/include_linux
checking for timer_create
creating build/temp.linux-armv6l-2.7/tmp
cc -c /tmp/timer_createXLUUXL.c -o build/temp.linux-armv6l-2.7/tmp/timer_createXLUUXL.o
cc build/temp.linux-armv6l-2.7/tmp/timer_createXLUUXL.o -o build/temp.linux-armv6l-2.7/a.out
build/temp.linux-armv6l-2.7/tmp/timer_createXLUUXL.o: In function `main':
creating build/temp.linux-armv6l-2.7/buildutils
creating build/temp.linux-armv6l-2.7/bundled
creating build/temp.linux-armv6l-2.7/bundled/zeromq
creating build/temp.linux-armv6l-2.7/bundled/zeromq/src
creating build/temp.linux-armv6l-2.7/bundled/zeromq/tweetnacl
creating build/temp.linux-armv6l-2.7/bundled/zeromq/tweetnacl/src
creating build/temp.linux-armv6l-2.7/bundled/zeromq/tweetnacl/contrib
creating build/temp.linux-armv6l-2.7/bundled/zeromq/tweetnacl/contrib/randombytes
 #include "Python.h"
Cleaning up...
Command /usr/bin/python -c "import setuptools, tokenize;__file__='/tmp/pip-build-vfKpE0/pyzmq/setup.py';exec(compile(getattr(tokenize, 'open', open)(__file__).read().replace('\r\n', '\n'), __file__, 'exec'))" install --record /tmp/pip-wwXCX8-record/install-record.txt --single-version-externally-managed --compile failed with error code 1 in /tmp/pip-build-vfKpE0/pyzmq
Bombs out again.
Ideas?
MrYsLab
Sat Sep 02, 2017 12:37 am
I will create a Jessie image and test, but in the meantime, if you to want to try building zeromq I am including a link to the instructions. Just substitute pip for pip3 in that last line of the instructions. Here is the link:
https://github.com/MrYsLab/razmq/wiki/Z ... structions
This will probably take about a half an hour to build (on a RPi 3).
pumpkinpi
Sat Sep 02, 2017 1:14 am
I think I will try a new build as well. I have a spare Pi3 here.
PPi
MrYsLab
Sat Sep 02, 2017 1:18 am
I am seeing an issue on Jessie as well. I am going to try the whole zeromq build process and let you know if that works.
MrYsLab
Sat Sep 02, 2017 1:43 am
It looks like pyzmq is requiring a newer version of zeromq. I will download and build that version and get back to you on status. The build instructions I provided are for an older version zeromq.
MrYsLab
Sat Sep 02, 2017 3:09 am
Ok, I think I have it working now. Here are the steps to get things installed and working.
1. Type:
sudo apt-get install python-dev
This will install python.h
2. Update numpy to latest version:
sudo pip install numpy --upgrade
This is very slow. It will probably take about a half hour to update
3. There is a "bug" in pip in installing executables for python 2(this was introduced with the latest updates to pypi) and so the backplane and monitor utilities will not function if you install using pip. To get around this do the following:
a. Download the distribution from github. Go to https://github.com/MrYsLab/python_banyan and press the green download button and unzip the file.
b. go into the directory python_banyan-master and make sure you see setup.py
c. type:
sudo setup.py install
Please let me know if you still have issues.
pumpkinpi
Sat Sep 02, 2017 3:18 am
Ok! Will do. Thanks.
asandford
Sun Sep 03, 2017 12:21 am
As there is no mention of how this test was run, the results are meaningless.
Encryption and authentication?
Last will and testament?
QoS?
Support for Javascript / Java / C / C++ / Pascal / <pick a language>
Can I run it on my Arduino?
If the answer is "No" to any of the above, then it isn't a replacement for MQTT
Also, if you remove the following from the mqpub (as it isn't in the banyan_pub), what are the results then?
packed = umsgpack.packb(payload)  <== why?
And this :
if x == 45000:
                timex = time.asctime(time.localtime(time.time()))
                payload2 = {'modulo': x, 'time': timex}
                packed2 = umsgpack.packb(payload2)
                self.publish("m2", packed2)
                print('m2 message: ' + str(x) + ' ' + timex)
If it isn't tested every loop cycle, then it's pointless. If it is then you've hobbled the code as you don't perform the same test in the banyan code.
[edit]
The subscribe code is even more devious:
The depack adds more time:
mg = umsgpack.unpackb(msg.payload)
data = mg['msg']
And why is it testing for things on another topic?:
self.subscribe("m2", 0)
And then testing messages?
if msg.topic == 'test':
elif msg.topic == 'm2':
            if mg['modulo'] == 45000:
print(msg.payload)
None of that appears in your banyan code.
Nice way to rig rsults.
[edit 2] In case things change:
banyan_sub.py
import sys
import time
from python_banyan.banyan_base import BanyanBase
class BanyanSub(BanyanBase):
    This class subscribes to the "test" topic, and sits in a loop
    receiving messages. When 100000 messages have been received,
    it shuts down the loop and prints both the elapsed time taken
    to receive all messages as well as the current time.
    def __init__(self):
        Subscribe to the "test" topic, initialize the message count
        and enter the receive loop.
        super(BanyanSub, self).__init__(process_name='Banyan Subscriber')
        # allow time for connections to be established
        time.sleep(.3)
        # the start time
        self.start = None
        # the end time
        self.end = None
        print('Expecting 100000 messages.')
        self.set_subscriber_topic('test')
        self.message_count = 0
        self.receive_loop()
    def incoming_message_processing(self, topic, payload):
        When a message is received, extract the message number, bump the
        message count by 1.
        On the first message, start the elapsed time timer.
        On the last message determine the elapsed time, and print it
        and the current time. Finally exit
        :param topic: Message Topic string
        :param payload: Message Data
        :return:
        data = payload['msg']
        self.message_count += 1
        # time.sleep(.001)
        # if not self.message_count % 100:
        #     print(self.message_count)
        if data == 0:
            self.start = time.time()
        if data == 99999:
            self.end = time.time()
            localtime = time.asctime(time.localtime(time.time()))
            print('Task completed at: ', localtime)
            print('{} Total messages received in {} seconds.'.format(self.message_count, self.end - self.start))
            super(BanyanSub, self).clean_up()
            sys.exit(0)
# instantiate this class
BanyanSub()
banyan pub
import sys
import time
class BanyanPub(BanyanBase):
    This class publishes 100000 "test" topic messages as fast as it can.
    It then prints the current time and exits.
    def __init__(self):
        super(BanyanPub, self).__init__(process_name='Banyan publisher')
        print('Publishing 100000 messages.')
        time.sleep(.3)
        for x in range(0, 100000):
            payload = {'msg': x}
            self.publish_payload(payload, 'test')
        super(BanyanPub, self).clean_up()
        sys.exit(0)
BanyanPub()
[code]mqtt sub
import sys
import time
import paho.mqtt.client as mqtt
import umsgpack
class MQSUB(mqtt.Client):
    def __init__(self):
        Start the client, subscribe to "test" and start the loop
        super(MQSUB, self).__init__()
        # super().on_connect = self.on_connect
        # super().on_message = self.on_message
        self.start = 0
        self.end = 0
        self.connect('192.168.2.192', 1883, 60)
        self.subscribe("test", 0)
        self.loop_forever()
    def on_connect(self, mqttc, obj, flags, rc):
        Let the use know we are connected
        :param mqttc: unused
        :param obj: unused
        :param flags: unused
        :param rc: unused
        :return: unused
        print('MQSUB Connected - Expecting 100000 Messages')
    def on_message(self, mqttc, obj, msg):
        :param mqttc: the client
        :param obj: unused
        :param msg: the message containing the payload
        :return:
        # unpack the messagepack message
            data = mg['msg']
            # update the count of messages received and start the
            # elapsed time timer
            if data == 0:
            # wait for the last message, then print out the current time
            # and an elapsed time message.
            # finally stop the loop and exit.
            if data == 99999:
                print('Task completed on: ', localtime)
                time.sleep(1)
                self.loop_stop()
                sys.exit(0)
                print(msg.payload)
        else:
            print('unkown topic' + msg.topic)
MQSUB()
[code][code]
mqtt pub
import sys
import time
import umsgpack
class MQPUB(mqtt.Client):
    def __init__(self):
        This method connects, starts the loop and then publishes
        all the messages until complete.
        It then prints the current time before stopping the loop and exiting.
        super(MQPUB, self).__init__()
        print("MQPUB Connected - Sending 100000 messages")
        time.sleep(2)
            self.publish("test", packed)
            if x == 45000:
        time.sleep(1)
        self.loop_stop()
        sys.exit(0)
# instantiate the class
MQPUB()
Not a level playing field is it?
pumpkinpi
Sun Sep 03, 2017 12:25 am
I think you meant:
sudo python setup.py install
I tried that and got:
zip_safe flag not set; analyzing archive contents...
creating dist
creating 'dist/python_banyan-2.1-py2.7.egg' and adding 'build/bdist.linux-armv6l/egg' to it
removing 'build/bdist.linux-armv6l/egg' (and everything under it)
Processing python_banyan-2.1-py2.7.egg
Copying python_banyan-2.1-py2.7.egg to /usr/local/lib/python2.7/dist-packages
Adding python-banyan 2.1 to easy-install.pth file
Installing backplane script to /usr/local/bin
Installing monitor script to /usr/local/bin
Installed /usr/local/lib/python2.7/dist-packages/python_banyan-2.1-py2.7.egg
Processing dependencies for python-banyan==2.1
Searching for psutil
Reading https://pypi.python.org/simple/psutil/
Best match: psutil 5.3.0
Downloading https://pypi.python.org/packages/1c/da/555e3ad3cad30f30bcf0d539cdeae5c8e7ef9e2a6078af645c70aa81e418/psutil-5.3.0.tar.gz#md5=2ff7b2030b3bb786594d6276f32b6699
Processing psutil-5.3.0.tar.gz
Writing /tmp/easy_install-N4RB8T/psutil-5.3.0/setup.cfg
Running psutil-5.3.0/setup.py -q bdist_egg --dist-dir /tmp/easy_install-N4RB8T/psutil-5.3.0/egg-dist-tmp-dEIkFJ
psutil/_psutil_common.c:9:20: fatal error: Python.h: No such file or directory
 #include <Python.h>
error: Setup script exited with error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
So, randomly I tried:
sudo python3 setup.py install
It got further, but spat out this:
Writing /tmp/easy_install-xxxae3li/numpy-1.13.1/setup.cfg
Running numpy-1.13.1/setup.py -q bdist_egg --dist-dir /tmp/easy_install-xxxae3li/numpy-1.13.1/egg-dist-tmp-iboxq3q7
Running from numpy source directory.
/tmp/easy_install-xxxae3li/numpy-1.13.1/setup.py:367: UserWarning: Unrecognized setuptools command, proceeding with generating Cython sources and expanding templates
  run_build = parse_setuppy_commands()
Warning: Can't read registry to find the necessary compiler setting
Make sure that Python modules winreg, win32api or win32con are installed.
/usr/lib/python3.4/distutils/dist.py:260: UserWarning: Unknown distribution option: 'python_requires'
  warnings.warn(msg)
Warning: distutils distribution has been initialized, it may be too late to add a subpackage compatWarning: distutils distribution has been initialized, it may be too late to add an extension _dummyWarning: distutils distribution has been initialized, it may be too late to add a library npysort/tmp/easy_install-xxxae3li/numpy-1.13.1/numpy/distutils/system_info.py:572: UserWarning:
    Atlas (http://math-atlas.sourceforge.net/) libraries not found.
    Directories to search for the libraries can be specified in the
    numpy/distutils/site.cfg file (section [atlas]) or by setting
    the ATLAS environment variable.
  self.calc_info()
    Blas (http://www.netlib.org/blas/) libraries not found.
    numpy/distutils/site.cfg file (section [blas]) or by setting
    the BLAS environment variable.
  self.calc_info()
    Blas (http://www.netlib.org/blas/) sources not found.
    Directories to search for the sources can be specified in the
    numpy/distutils/site.cfg file (section [blas_src]) or by setting
    the BLAS_SRC environment variable.
  self.calc_info()
/bin/sh: 1: svnversion: not found
non-existing path in 'numpy/distutils': 'site.cfg'
Warning: distutils distribution has been initialized, it may be too late to add an extension multiarrayWarning: distutils distribution has been initialized, it may be too late to add an extension umathWarning: distutils distribution has been initialized, it may be too late to add an extension umath_testsWarning: distutils distribution has been initialized, it may be too late to add an extension test_rationalWarning: distutils distribution has been initialized, it may be too late to add an extension struct_ufunc_testWarning: distutils distribution has been initialized, it may be too late to add an extension multiarray_testsWarning: distutils distribution has been initialized, it may be too late to add an extension operand_flag_testsWarning: distutils distribution has been initialized, it may be too late to add a subpackage coreWarning: distutils distribution has been initialized, it may be too late to add a subpackage commandWarning: distutils distribution has been initialized, it may be too late to add a subpackage fcompilerWarning: distutils distribution has been initialized, it may be too late to add a subpackage distutilsWarning: distutils distribution has been initialized, it may be too late to add a subpackage docWarning: distutils distribution has been initialized, it may be too late to add a subpackage f2pyWarning: distutils distribution has been initialized, it may be too late to add an extension fftpack_liteWarning: distutils distribution has been initialized, it may be too late to add a subpackage fftWarning: distutils distribution has been initialized, it may be too late to add a subpackage lib/tmp/easy_install-xxxae3li/numpy-1.13.1/numpy/distutils/system_info.py:572: UserWarning:
    Lapack (http://www.netlib.org/lapack/) libraries not found.
    numpy/distutils/site.cfg file (section [lapack]) or by setting
    the LAPACK environment variable.
  self.calc_info()
    Lapack (http://www.netlib.org/lapack/) sources not found.
    numpy/distutils/site.cfg file (section [lapack_src]) or by setting
    the LAPACK_SRC environment variable.
  self.calc_info()
Warning: distutils distribution has been initialized, it may be too late to add an extension lapack_liteWarning: distutils distribution has been initialized, it may be too late to add an extension _umath_linalgWarning: distutils distribution has been initialized, it may be too late to add a subpackage linalgWarning: distutils distribution has been initialized, it may be too late to add a subpackage maWarning: distutils distribution has been initialized, it may be too late to add a subpackage matrixlibWarning: distutils distribution has been initialized, it may be too late to add a subpackage polynomialWarning: distutils distribution has been initialized, it may be too late to add an extension mtrandWarning: distutils distribution has been initialized, it may be too late to add a subpackage randomWarning: distutils distribution has been initialized, it may be too late to add a subpackage testingWarning: distutils distribution has been initialized, it may be too late to add a subpackage numpy/usr/lib/python3.4/distutils/dist.py:260: UserWarning: Unknown distribution option: 'python_requires'
  warnings.warn(msg)
Could not locate executable gfortran
Could not locate executable f95
Could not locate executable ifort
Could not locate executable ifc
Could not locate executable lf95
Could not locate executable pgfortran
Could not locate executable f90
Could not locate executable f77
Could not locate executable fort
Could not locate executable efort
Could not locate executable efc
Could not locate executable g77
Could not locate executable g95
Could not locate executable pathf95
don't know how to compile Fortran code on platform 'posix'
_configtest.c:1:5: warning: conflicting types for built-in function ‘exp’
 int exp (void);
_configtest.o: In function `main':
/tmp/easy_install-xxxae3li/numpy-1.13.1/_configtest.c:6: undefined reference to `exp'
 int exp (void);
_configtest.c:1:24: fatal error: sys/endian.h: No such file or directory
 #include <sys/endian.h>
_configtest.c: In function ‘main’:
_configtest.c:5:16: warning: variable ‘test_array’ set but not used [-Wunused-but-set-variable]
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) >= 0)];
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 4)];
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 8)];
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 16)];
_configtest.c:7:12: error: ‘SIZEOF_LONGDOUBLE’ undeclared (first use in this function)
     (void) SIZEOF_LONGDOUBLE;
_configtest.c:7:12: note: each undeclared identifier is reported only once for each function it appears in
_configtest.c:5:16: error: size of array ‘test_array’ is negative
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 12)];
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 32)];
     static int test_array [1 - 2 * !(((long) (sizeof (npy_check_sizeof_type))) == 24)];
_configtest.c:7:16: warning: variable ‘test_array’ set but not used [-Wunused-but-set-variable]
_configtest.c:7:16: error: size of array ‘test_array’ is negative
 int exp (void);
 int exp (void);
_configtest.c:1:5: warning: conflicting types for built-in function ‘floor’
 int floor (void);
_configtest.c:2:5: warning: conflicting types for built-in function ‘ldexp’
 int ldexp (void);
_configtest.c:3:5: warning: conflicting types for built-in function ‘atan’
 int atan (void);
_configtest.c:4:5: warning: conflicting types for built-in function ‘fabs’
 int fabs (void);
_configtest.c:5:5: warning: conflicting types for built-in function ‘acos’
 int acos (void);
_configtest.c:6:5: warning: conflicting types for built-in function ‘tanh’
 int tanh (void);
_configtest.c:7:5: warning: conflicting types for built-in function ‘log10’
 int log10 (void);
_configtest.c:8:5: warning: conflicting types for built-in function ‘fmod’
 int fmod (void);
_configtest.c:9:5: warning: conflicting types for built-in function ‘sinh’
 int sinh (void);
_configtest.c:10:5: warning: conflicting types for built-in function ‘ceil’
 int ceil (void);
_configtest.c:11:5: warning: conflicting types for built-in function ‘frexp’
 int frexp (void);
_configtest.c:12:5: warning: conflicting types for built-in function ‘modf’
 int modf (void);
_configtest.c:13:5: warning: conflicting types for built-in function ‘tan’
 int tan (void);
_configtest.c:14:5: warning: conflicting types for built-in function ‘asin’
 int asin (void);
_configtest.c:15:5: warning: conflicting types for built-in function ‘cos’
 int cos (void);
_configtest.c:16:5: warning: conflicting types for built-in function ‘cosh’
 int cosh (void);
_configtest.c:17:5: warning: conflicting types for built-in function ‘exp’
 int exp (void);
_configtest.c:18:5: warning: conflicting types for built-in function ‘log’
 int log (void);
_configtest.c:19:5: warning: conflicting types for built-in function ‘sqrt’
 int sqrt (void);
_configtest.c:20:5: warning: conflicting types for built-in function ‘sin’
 int sin (void);
Kept going with other errors.
No dice yet.
asandford
Sun Sep 03, 2017 1:01 am
No dice yet.
Or you could just use the industry standard which is supported by just about everything.
MrYsLab
Sun Sep 03, 2017 2:06 am
I just did installs for both python 2 and 3 on a clean jessie image.
1. I installed jessie 2017-07-05 on an sd card.
2. I am running headless and ssh'ed into the PI.
3. I ran raspi-config and expanded memory and set the boot options for Desktop/CLI to desktop gui requiring login.
4. I rebooted the Rpi.
5. I did a sudo apt-get update and sudo apt-get upgrade.
Installing for python 3:
1. I did a sudo pip3 install python-banyan
This built several of the packages and install took about 20 mins.
Installing for python 2:
1. I uninstalled for python 3 using sudo pip3 uninstall python-banyan.
2. I did a sudo apt-get install python-dev.
3.Download this file:
https://github.com/MrYsLab/python_banya ... ne-any.whl
4. Type:
sudo pip install ./python_banyan-2.1-py2-none-any.whl
Again this will take about 20 minutes or so for all the required packages to compile.
In both cases the installations were successful.
Again, let me know if this works.
pumpkinpi
Sun Sep 03, 2017 10:52 pm
I misread your instructions. Will try again.
pumpkinpi
Mon Sep 04, 2017 3:48 am
In the meantime, I tried asandford's recommendation. I did this:
sudo apt-get install mosquitto
sudo pip install paho-mqtt
And these two things installed no probs.
I did some reading here:
https://pypi.python.org/pypi/paho-mqtt/1.3.0
but quickly got lost. Have not yet found a tutorial for dummies on how to make this work on my raspberry pi's running simple python scripts. I am just looking to pass strings and simple numbers between them.
If anybody knows of guides, I would appreciate direction.
I think I just need to see a few examples. To late to keep googling...
PPi.
mattmiller
Mon Sep 04, 2017 6:44 am
I found this one got me started
http://www.hivemq.com/blog/mqtt-client- ... aho-python
Just to note - MQTT is an established protocol and can be run on practically any IoT device (pi/Arduino/ESP8266 etc) so learning how to implement it is well worth it
Mon Sep 04, 2017 4:47 pm
Learn MQTT is a few hours with http://www.hivemq.com/mqtt-essentials/
Return to “Python”
