KanoMaster22
Control-C in Python
Fri Aug 11, 2017 10:06 am
I am currently creating a simple (well it was supposed to be) python script that makes a recording with the stereo mirophone on the voice hat. Everything is working apart from I can not end the recording as I don't know how to simulate ctrl-c with os. Here is my script:
from os import system
system('arecord -c2 -f S32_LE -r 48000 /home/pi/voice-recognizer-raspi/src/music/test_record.wav')
input("Press enter to finish recording")
system('???') #control c needs to go here
Thanks in advance for any help,
KanoMaster22
MrYsLab
Re: Control-C in Python
Fri Aug 11, 2017 1:30 pm
Do actually need a Control C or do you simply wish to exit. If you just want to exit, then
import sys
sys.exit(0)
KanoMaster22
Fri Aug 11, 2017 2:56 pm
I need to use control-c to finish the recording. I've tried exiting and it didn't work.
elParaguayo
Fri Aug 11, 2017 3:24 pm
Then you might want to try using the subprocess module and use Popen to start the process. You can then send signals to the process. However, I have read that this doesn't always work so you may want to try and report back:
Option 1:
import subprocess
cmd = ['arecord', '-c2', '-f', 'S32_LE', '-r', '48000', '/home/pi/voice-recognizer-raspi/src/music/test_record.wav']
proc = subprocess.Popen(cmd)
proc.terminate()
Option 2:
import subprocess
import signal
import os
os.kill(proc.pid, signal.SIGINT)
Edit: Option 3 (bit of a hack)
import subprocess
subprocess.call(["killall", "arecord"])
Hopefully one of these will work.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
KanoMaster22
Fri Aug 11, 2017 3:54 pm
I will try these thanks for the help.
elParaguayo
Fri Aug 11, 2017 3:58 pm
Don't thank me yet. They may not work!
KanoMaster22
Wed Sep 20, 2017 5:09 pm
Finally got round to trying the code and when I used the first option it worked with no problems. Thanks elParaguayo
KanoMaster22
Wed Sep 20, 2017 5:32 pm
Now, all that is working but I need to move and rename a file before I record something. Here is my code:
import subprocess
cmd_two = ['mv /home/pi/voice-recognizer-raspi/src/music/test_record.wav /home/pi/voice-recognizer-raspi/src/music/test_record_old.wav']
proc_two = subprocess.Popen(cmd_two)
proc_two.terminate()
proc.terminate()
The idea is that first my old test record file (test_record.wav) needs to be renamed (to test_record_old) so I can record a new test_record. I don't already have a file called test_record_old.wav just in case anyone wants to know. Here is the error message I get when I run the code:
  File "/home/pi/voice-recognizer-raspi/src/record.py", line 8, in <module>
  File "/usr/lib/python3.4/subprocess.py", line 859, in __init__
    restore_signals, start_new_session)
  File "/usr/lib/python3.4/subprocess.py", line 1457, in _execute_child
    raise child_exception_type(errno_num, err_msg)
FileNotFoundError: [Errno 2] No such file or directory: 'mv /home/pi/voice-recognizer-raspi/src/music/test_record.wav /home/pi/voice-recognizer-raspi/src/music/test_record_old.wav'
LouisP
elParaguayo
Wed Sep 20, 2017 7:45 pm
Try changing cmd_two as follows:
cmd_two = ['mv', '/home/pi/voice-recognizer-raspi/src/music/test_record.wav', '/home/pi/voice-recognizer-raspi/src/music/test_record_old.wav']
You also don't need to terminate cmd_two as it will complete instantly.
However, it's worth noting that you can use the os module to rename files. See the docs for more.
The equivalent would be
import os
os.rename('/home/pi/voice-recognizer-raspi/src/music/test_record.wav', '/home/pi/voice-recognizer-raspi/src/music/test_record_old.wav')
KanoMaster22
Thu Sep 21, 2017 6:16 pm
Thank you elParaguayo. It works perfectly now!
Return to “Python”
Who is online
Users browsing this forum: No registered users and 14 guests
