gray_farz
print a persian file by thermal printer and python-escpos mnodule
Thu Aug 10, 2017 5:14 am
hello friends...
i want to print a persian file by thermal printer..
i can print an english file esily..but i face the proble while printing persian text..
i think i don't do some principles...i have studied about unicode encodeand decode in python..but it seems it isn't enough
please guide me
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Print an Arabic string to a printer.
# Based on example from escpos-php
# Dependencies-
# - pip install wand python-bidi python-escpos
# - sudo apt-get install fonts-hosny-thabit
# - download arabic_reshaper and place in arabic_reshaper/ subfolder
import arabic_reshaper
#from escpos import printer
from escpos.printer import Usb
from bidi.algorithm import get_display
from wand.image import Image as wImage
from wand.drawing import Drawing as wDrawing
from wand.color import Color as wColor
p = Usb(0x04b8,0x0e15,0)
p.codepage="cp720"   #设置解码的类型
# Some variables
#fontPath = "/usr/share/fonts/opentype/fonts-hosny-thabit/Thabit.ttf"
textUtf8 = u"بعض النصوص من جوجل ترجمة"
tmpImage = 'my-text.png'
printWidth = 550
# Get the characters in order
textReshaped = arabic_reshaper.reshape(textUtf8)
textDisplay = get_display(textReshaped)
# PIL can't do this correctly, need to use 'wand'.
# Based on
# https://stackoverflow.com/questions/5732408/printing-bidi-text-to-an-image
im = wImage(width=printWidth, height=36, background=wColor('#ffffff'))
draw = wDrawing()
draw.text_alignment = 'right';
draw.text_antialias = False
draw.text_encoding = 'utf-8'
draw.text_kerning = 0.0
draw.font_size = 36
draw.text(printWidth, 22, textDisplay)
draw(im)
im.save(filename=tmpImage)
# Print an image with your printer library
p.set(align="right")
p.image(tmpImage)
p.cut()
in the above code, i used the different codepages, but my output from the printer is just question mark ""?"" instead of the persian words
i tried the following code,too:
""" Seiko Epson Corp. Receipt Printer M129 Definitions (EPSON TM-T88IV) """
p.codepage="iso8859_6"
# Print text
p.text(u"سلام\n")
p.cut()
but the printer prints the obscure letters...
i tried the different codepages..but it wasn't usefull
topguy
Re: print a persian file by thermal printer and python-escpos mnodule
Sun Aug 13, 2017 1:30 pm
It doesnt matter what encoding you use unless you have a font in the printer with the correct symbols. Have you verified this ?
The printer have a pretty complex menu system you can access with holding in line-feed while turning it on. ( if I recall correctly )
scruss
Sun Aug 13, 2017 2:18 pm
Does the my-text.png file generated by your first script look correct to you? If so, the problem is more that your printer isn't printing bitmaps correctly.
Your second codepage example might need some conversion from utf-8 to 8859-6. It will also need the right font in the printer.
I find that Python 3 is much more consistent in handling Unicode than Python 2. Check that there are Py3-compatible versions of your modules, and change the first line to
#!/usr/bin/env python3
gray_farz
Mon Aug 14, 2017 4:22 am
i have printed jpg and gif images by my printer.so i don't think my printer has prooblem in printing bitmaps
i have choosen 8859-6 as a test(accidently)..i don't really know what codepage i must choose?? and how i can understand it
python-escpos was installed on python3,too..i now work by python3...what module is compatible by python3????
gray_farz
Mon Aug 14, 2017 5:32 am
my printer is TM-T20...I don't my printer's fonts...i couldn't it from its manual..
i turned the printer on and then holded the line feed button but it prints blank..i don't know how i can access this menu
topguy
Mon Aug 14, 2017 9:13 am
You have to hold the button in while turning it on.
scruss
Re: print a persian file by thermal printer and python-escpos module
Mon Aug 14, 2017 3:56 pm
i have printed jpg and gif images by my printer.so i don't think my printer has problem in printing bitmaps
Okay, that's a start, but your first example code at line 46 says:
and tmpImage is defined as my-text.png (line 27). So what I'm asking is:
  1. Does the file my-text.png get created?
  2. Does the image look at all like the text "بعض النصوص من جوجل ترجمة"?
I see you've asked a couple of other places like Python Forum and Stack Overflow.
gray_farz
Tue Aug 15, 2017 4:17 am
[*]Does the file my-text.png get created?
[*]Does the image look at all like the text "بعض النصوص من جوجل ترجمة"?
i think it is created...because it prints the question mark '?' exactly the same number of letters of "بعض النصوص من جوجل ترجمة"
the space of between the letters is preserved,too...
as the following :
gray_farz
Tue Aug 15, 2017 4:29 am
holding 'feed' button gave me the following contents:
contents of feed button
Return to “Python”
Who is online
Users browsing this forum: No registered users and 4 guests
