oskaaaR
Problem using serial port with python (HDMI interference)
Wed Aug 09, 2017 9:38 am
Hi everybody,
I'm developing a sensor based on Raspberry Pi 3 and I write the code in Python. To communicate with another peripheral I need to use Serial Port because the other peripheral only has this possibility. To configure the system I'm working with an auxiliar screen and I have established well serial communication. I've follow this tutorial to setup the communications --> https://spellfoundry.com/2016/05/29/con ... ding-pi-3/
But when I unplug the HDMI port I have a lot of interferences in the serial port communications. I try disabling the HDMI output editing /etc/rc.local file and adding /usr/bin/tvservice -o but it doesn't works.
Are there another way to avoid the HDMI interferences?
Thanks for your help!! :) :)
Óscar.
klricks
Re: Problem using serial port with python (HDMI interference)
Wed Aug 09, 2017 12:45 pm
Do you have a ground wire between the RPi and the serial peripheral?
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
oskaaaR
Thu Aug 10, 2017 8:15 am
Hi klricks, in order to test the behaviour of the system I'm simulating the other peripheric with another Raspberry by the moment. Is for this because I don't have wired the Raspberrys grounds, is it necessary?
Thanks for all!!
Óscar.
RaTTuS
Thu Aug 10, 2017 8:25 am
yes - both should share the ground
Covfefe
Return to “Python”
Who is online
Users browsing this forum: gkreidl and 14 guests
