rpiboy
Noob lost been reading this code for hours
Wed Aug 09, 2017 2:32 am
Hi, Please, Hoping for a kind person that can help me understand this code. I've been trying to understand this code for hours on end. I understand what it is trying to do when I run it, but still would appreciate someone who will explain it thanks!
import random
from urllib.request import urlopen
import sys
WORD_URL = "http://learncodethehardway.org/words.txt"
WORDS = []
PHRASES = {
    "class %%%(%%%):":
     "Make a class named %%% that is-a %%%.",
    "class %%%(object):\n\tdef __init__(self, ***)" :
     "class %%% has-a __init__ that takes self and *** params.",
    "class %%% (object):\ntdef ***(self, @@@)":
     "class %%% has-a function *** that takes self and @@@ params.",
     "Set *** to an instance of class %%%.",
     "From *** get the *** function, call it with params self, @@@.",
     "From *** get the *** attribute and set it to '***'."
if len(sys.argv) == 2 and sys.argv[1] == "english":
    PHRASE_FIRST =True
else:
    PHRASE_FIRST = False
for word in urlopen(WORD_URL).readlines():
    WORDS.append(str(word.strip(), encoding="utf-8"))
def convert(snippet, phrase):
    class_names = [w.capitalize() for w in
                   random.sample(WORDS, snippet.count("%%%"))]
    other_names = random.sample(WORDS, snippet.count("***"))
    results = []
    param_names = []
    for i in range(0, snippet.count("@@@")):
        param_count = random.randint(1,3)
        param_names.append(', '.join(
            random.sample(WORDS, param_count)))
    for sentence in snippet, phrase:
        result = sentence[:]
        for word in class_names:
            result = result.replace("%%%", word, 1)
        for word in other_names:
            result = result.replace("***", word, 1)
        for word in param_names:
            result = result.replace("@@@", word, 1)
        results.append(result)
    return results
try:
    while True:
        snippets = list(PHRASES.keys())
        random.shuffle(snippets)
        for snippet in snippets:
            phrase = PHRASES[snippet]
            question, answer = convert(snippet, phrase)
            if PHRASE_FIRST:
                question, answer = answer, question
            print(question)
            input("> ")
            print("ANSWER: {}\n\n".format(answer))
except EOFError:
    print("\nBye")
bensimmo
Re: Noob lost been reading this code for hours
Wed Aug 09, 2017 7:12 am
Run it using Thonny (the new Python3 IDE for Raspbian) and follow it step by step seeing what happens as you go.
See if that helps.
rpiboy
Wed Aug 09, 2017 6:59 pm
OK, so I am trying to debug it.
I have this
     print(phrase)
Now what I don't understand is this I see that it is printing out the key values but how is that doing it?
I know in a dict you get the values by doing variable[key] but isn't it converting it to a list? I thought a list gets it value by variable[number]. :?
Wed Aug 09, 2017 7:13 pm
Look at what the "for" statement is doing.
bensimmo
Thu Aug 10, 2017 5:24 am
It's early, pre-coffee and so not check completely but see if it's doing this ?
variable={"stuff":"things", }
list_of_keys = list(variable.keys())
for key in list_of_keys:
    phrase = variable[key]
    print(phrase)
elParaguayo
Thu Aug 10, 2017 9:35 am
I'm not sure the "list" line is necessary. Have a look at this:
my_dict = {"key1": "value1", "key2": "value2"}
list_of_keys = list(my_dict.keys())
    print(my_dict[key])
outputs
value2
value1
Simpler version:
for key in my_dict:
    print(my_dict[key])
outputs
value2
value1
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
bensimmo
Thu Aug 10, 2017 11:00 am
I think it's used as they shuffle the keys before proceeding in the full code in the original post.
elParaguayo
Thu Aug 10, 2017 11:03 am
Fair enough.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 27 guests
