California
Simple script optimisation and starting at boot
Sun Aug 06, 2017 8:53 am
Hello, here is a very simple script for controlling CPU fan and generating square pulses for hardware watchdog circuit. It consumes ~2% of CPU time and it works as expected.
The question 1: is possible to optimise it somehow, to spend less CPU time?
The question 2: how to make it run automatically at start?
Thanks in advance.
Vlado
simple_script.py
import RPi.GPIO as GPIO
from subprocess import call
import os
from sys import exit
import time
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)   #Stevilka dejanskega pina se uporabi v kodi
GPIO.setup(13, GPIO.OUT)  # WatchDog
GPIO.setup(15,GPIO.OUT)  # CPU cooler
# WATCHDOG pulse
def dig_out_13():
    GPIO.output(13, not GPIO.input(13))
# Return CPU temperature as float
def getCPUtemp():
    cTemp = os.popen('vcgencmd measure_temp').readline()
    return float(cTemp.replace("temp=","").replace("'C\n",""))
# Command for CPU cooler
def set_cooler():
    CPU_temp = getCPUtemp()
    if CPU_temp > 47.0:
        GPIO.output(15, GPIO.HIGH)
    elif CPU_temp < 45.0:
        GPIO.output(15, GPIO.LOW)
while True:
    set_cooler()
    dig_out_13()
    time.sleep(0.5)
Re: Simple script optimisation and starting at boot
Sun Aug 06, 2017 9:13 am
1. Make the sleep longer, or don't bother running it as it does nothing useful except make the CPU run ever hotter.
2. Write a systemd service file.
viewtopic.php?f=63&t=138861#p921354
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
California
Mon Aug 07, 2017 10:31 am
Thanks for your help.
Vlado
Massi
Mon Aug 07, 2017 11:40 am
I'd try using pigpio's waves for the watchdog square wave.
for temperature, i'm with dougie. Not really useful, but if you are doing that for testing.. well half a second is ridicously too fast for this kind of checks, and since we are only learning something new, you could drive the fan with a pwm output depending on temperature (always with pigpio)
California
Tue Aug 08, 2017 9:06 am
With time sleep 0,8s only 1% of CPU time is used, so it's ok. I can increase this time if needed with correction of watchdog circuit. I am taking care about temperature because I am not the only one which will use RPi, that's why small colling fan is added to housing responsible for non overheating of the RPi.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 4 guests
