pravinyouwin
Stacking Piface Relay Plus boards on Raspberry PI??
Sat Aug 05, 2017 4:16 am
Hello Guys,
I hope i will find a solution for this question:
"PiFace Relay documentation" (see attached) i see up to 8 RELAY PLUS boards can be stacked on PI.
But never found one example on web.
It mentioned how to assign addresses for different boards using address bits JP1, JP2, JP3. But really I couldn't find any documentation/examples how to do for multiple boards. (using Python)
I tried different python commands to access the second piface relay plus, but not successful. I hope Some one should have tried this.
pfr.relays[0].toggle() --------> "1st piface 1st relay "
please help me how can i do for the second PiFace relay plus.
Shows the address bits for multiple boards
piface relay 2.png (59.2 KiB) Viewed 563 times
Address bits JP1,JP2, JP3
piface realy1.png (101.66 KiB) Viewed 563 times
pcmanbob
Re: Stacking Piface Relay Plus boards on Raspberry PI??
Sat Aug 05, 2017 7:46 pm
Hi.
Having looked at the documentation nothing jumped out at me about controlling multiple boards apart from how to programme the board addresses which you already posted as this is a commercial product you might be better asking the people who make it.
it looks like the only way to contact them is via facebook or twitter, could find no email address for them.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
klricks
Sat Aug 05, 2017 10:02 pm
Have a look at this YT https://www.youtube.com/watch?v=9RrOVivCcAU
Go full screen and pause the video at at ~0:30 to 0:32 showing code on the laptop screen.
Look at the syntax at the end of the pfr2. statement.
I think is says: pfr2 = ........RELAY, hardware_addr = 1)
Looks like you would use pfr2. for the second board etc.......
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
pravinyouwin
Tue Aug 08, 2017 4:02 am
Great!! I watched this video couple of days back. But I barely Looked at this.
Thanks, you answered my question.
(This morning I run my program without pfr, it showed me error something like this hardware_addr=0 missing)
Thank You Again. Mostly it should work, Will let You know if this work or no.
pcmanbob
Tue Aug 08, 2017 10:08 am
Look at your jumper settings for J1, J2, J3 make sure the bottom board in your stack has jumpers set for addr = 0 and the next board in your stack has jumpers set for addr = 1 and so on if you have more boards.
your previous post has the jumper settings listed its the first 2 in the list.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 15 guests
