modsbyus
How to count button presses during a specified amount of time
Tue Aug 01, 2017 10:52 pm
I am trying to count button presses within a 5 second period. My problem is that I dont know how to look for button presses for only 5 seconds.
I want to press my button on gpio 20 then after that count any additional presses until 5 seconds has passes from the time of the first press.
Massi
Re: How to count button presses during a specified amount of time
Wed Aug 02, 2017 7:26 am
well, you could set up a callback on the button with a watchdog 5 seconds long.
Untested:
#!/usr/bin/env python3
#coding=utf-8
import time
import pigpio
#setup vars
gpio = 7 #where the switch is connected
debounce = 1000 #debounce time, in us
clickPeriod = 5000 #control period for clicks. in ms
clickCount = -1 #number of clicks in the period
def intCallback(g, level, tick):
	global clickCount
	if level == pigpio.HIGH:
		#button release
		if clickCount == -1:
			#this is the starting click. Setting up watchdog
			pi.set_watchdog(g, clickPeriod)
		clickCount += 1
	elif level == pigpio.TIMEOUT:
		#kill watchdog and print result
		pi.set_watchdog(g, 0)
		print("Total clicks in {}ms period: {}".format(clickPeriod, clickCount)
		clickCount = -1
pi = pigpio.pi()
pi.set_mode(gpio, pigpio.INPUT)
pi.set_glitch_filter(gpio, debounce)
pi.set_pull_up_down(gpio, pigpio.PUD_UP) #this depends on how the switch is connected. In this case it is between GPIO and GND
cb = pi.callback(gpio, pigpio.RISING_EDGE, intCallback)
try:
	while True:
		time.sleep(1)
except (KeyboardInterrupt, SystemExit) as e:
	print("Clean exit")
except Exception as e:
	print("Bad exit")
finally:
	cb.cancel()
	pi.stop()
modsbyus
Wed Aug 02, 2017 8:55 am
My daughter and I have been working on this for a while and have never found any reference to that. Thank you tremendously. Would you please leave a link that further explains this watchdog timer and it's use?
Massi
Wed Aug 02, 2017 11:46 am
as you can see the code is based on pigpio module
ref: http://abyz.co.uk/rpi/pigpio/index.html
on the GPIO used for the button is set up a callback (= a function called by the system when a event - rising or falling edge - is found on the gpio)
the pigpio's "watchdog" waits for some events on the GPIO for the specified amount of time. after that time, the callback is called with a "special" level, so you can know that the time has passed.
have you tried the code? does it work?
feel free to ask if any part is not clear (or, probably, if it's not working :))
modsbyus
Wed Aug 02, 2017 12:00 pm
We haven't had a chance yet. We are US east coast, so we are just waking up here. My daughter should be trying this today and corresponding her troubles and successes.
MsCheesyPuff
Wed Aug 02, 2017 6:24 pm
Hi, this is his daughter. I've ran the code after downloading the pigpio library:
[#!/usr/bin/env python3
#coding=utf-8
import time
import pigpio
#setup vars
gpio = 20 #where the switch is connected
global clickCount
#button release
clickCount += 1
print("Total clicks in {}ms period: {}".format(clickPeriod, clickCount))
clickCount = -1
pi = pigpio.pi()
try:
while True:
time.sleep(1)
print("Clean exit")
print("Bad exit")
finally:
cb.cancel()
pi.stop()
The program ran successfully, but there aren't any outputs, no syntaxes, errors messages, nothing is printed either. What problems could cause this the happen? Thank you so much for helping us!
Massi
Thu Aug 03, 2017 6:38 am
how did you phisically connect the switch?
are you sure you are using the GPIO 20 (pigpio uses BCM numbers, see www.pinout.xyz)
That said, at least you should see the "clean exit" message when you ctrl+c to close the program.
Try adding a "print something" in the callback, just to check if it's called (and when)
debug it a little :)
MsCheesyPuff
Thu Aug 03, 2017 1:36 pm
Yes, it does show 'Clean Exit' when I use Ctrl C. However, when I try to call the function, I didn't have any arguments. As I was in the process in adding arguments, I noticed that 'tick' was nowhere in the program besides declaring the function intCallback. Is 'tick' necessary and what would it's use be?
Massi
Thu Aug 03, 2017 1:59 pm
you don't have to manage those arguments, since it is pigpio itself to send arguments to the callback.
As you can see here:
http://abyz.co.uk/rpi/pigpio/python.html#callback
the set up callback receives 3 arguments.
"g" is our gpio, we know it, it's used since you can use the same callback on different gpios
"level" is the level that has triggered the callback (we are waiting for a rising edge, so this should be always high)
"tick" is the system tick when the level change occurred. Very useful when you need to precisely monitor timings between callbacks, useless in our case (the watchdog is counting this..)
I can't test it today, please add to the callback a "debug" print, just to see if it's called in any way, and try to see what it prints and when.
It should print when you RELEASE the button
        print("{} {} {}".format(g,level,tick))
        global clickCount
it's so hard to debug a sample code having no raspberry under hand :)
MsCheesyPuff
Thu Aug 03, 2017 3:08 pm
The code is now successfully working but it's running too fast, instead of running for 5 seconds it only runs for 1 second. Why would this be, would I need to increase the milliseconds or is there another solution? You've been very helpful. Many thanks!
Massi
Thu Aug 03, 2017 9:10 pm
what did you need to correct in code? i'm quite curious :)
the code should count clicks for 5000ms starting from the first click, isn't it?
Massi
Fri Aug 04, 2017 7:39 pm
well, i just discovered how watchdog works :)
it's giving the timeout only when for 5 seconds nothing changes on the GPIO
Not right for what we are trying to do.. At least, not that easy :)
New version
#coding=utf-8
import time
import pigpio
#setup vars
gpio = 16 #where the switch is connected
clickCount = 0 #number of clicks in the period
startTick = None
	print("Callback: level {} - tick {}".format(level,tick))
	global clickCount, startTick
		#button release
		if startTick is None:
			print("Starting count..")
			startTick = tick
			clickCount = 0
			pi.set_watchdog(gpio,clickPeriod) #if no clicks will come, this will give the timeout
		else:
			print("Adding one..")
			clickCount += 1
			#need to update the watchdog
			pi.set_watchdog(gpio,clickPeriod-pigpio.tickDiff(startTick, tick)/1000) #next timeout
		#over
		print("Total clicks in {}ms period: {} (real: {})".format(clickPeriod, clickCount,pigpio.tickDiff(startTick, tick)/1000))
		pi.set_watchdog(gpio,0)
		startTick = None
pi = pigpio.pi()
try:
	while True:
		pi.write(gpio,0)
		time.sleep(0.1)
		pi.write(gpio,1) #this triggers the count
		time.sleep(1)
		pi.write(gpio,0)
		time.sleep(1)
		pi.write(gpio,1) #click one
		time.sleep(1)
		pi.write(gpio,0)
		time.sleep(1)
		pi.write(gpio,1) #click 2
		time.sleep(1)
		pi.write(gpio,0)
		time.sleep(5)
	print("Clean exit")
	print("Bad exit")
finally:
	cb.cancel()
	pi.stop()
Obviously to test your switch take out all the "try" part (leave only a sleep, like in the first version)
This returns something like
pi@baguette:~/wip $ python3 clicks.py
Callback: level 1 - tick 374457983
Starting count..
Callback: level 1 - tick 376460608
Adding one..
Callback: level 1 - tick 378463313
Adding one..
Callback: level 2 - tick 379459176
Total clicks in 5000ms period: 2 (real: 5001.193)
Callback: level 1 - tick 384570349
Starting count..
Callback: level 1 - tick 386573024
Adding one..
Callback: level 1 - tick 388575704
Adding one..
Callback: level 2 - tick 389571826
Total clicks in 5000ms period: 2 (real: 5001.477)
Callback: level 1 - tick 394682759
Starting count..
Callback: level 1 - tick 396685544
Adding one..
Callback: level 1 - tick 398688280
Adding one..
Callback: level 2 - tick 399684102
Total clicks in 5000ms period: 2 (real: 5001.343)
^CClean exit
Seems good, isn't it?
MsCheesyPuff
Sat Aug 05, 2017 12:58 am
I've been able to fix the timing, but it starts when the program starts instead of waiting for the button press.
    print('{} {} {}'.format(g, level, tick))
    global clickCount
        #button release
        print ('button pressed')
        clickCount = clickCount + 1
        clickCount = -1
Your code looks fantastic! Unfortunately I won't be able to test it quite yet, I'm going on a family outing and I will get back to you as soon as possible. Thank you again! :D
MsCheesyPuff
Mon Aug 07, 2017 1:13 pm
I'm trying to test out your code and my switch but I get the error:
AttributeError: 'NoneType' object has no attribute 'send'
But, I think the reason this is happening is that I'm using Python 2 instead of using Python 3 like you are. I don't know much about Python 3 but, wouldn't that impact the way the program works?
Massi
Mon Aug 07, 2017 1:26 pm
This is a PiGPIO error i usually see on i2c transactions, not our case, and should happen occasionally.
Is it giving this error to you every time? In this case you should dig deeper in the code adding the traceback for errors..
no, the code should work with python2 and python3
try calling it with a simple "python3 scriptname.py" (you should have python3 installed..)
MsCheesyPuff
Tue Aug 08, 2017 9:30 pm
I finally got some results. But, instead of waiting for a button press, it's automatically making one for me. As I was debugging I noticed that you had written for my Raspberry Pi to make button presses instead of having to wait for actual button presses from my hardware. The code works, but it isn't exactly what I needed for my program. However, it's brilliant and I really appreciate you helping me. :)
Massi
Wed Aug 09, 2017 4:32 am
as i told you before, you have to turn this
	while True:
		pi.write(gpio,0)
		time.sleep(0.1)
		time.sleep(1)
		pi.write(gpio,0)
		time.sleep(1)
		time.sleep(1)
		pi.write(gpio,0)
		time.sleep(1)
		time.sleep(1)
		pi.write(gpio,0)
		time.sleep(5)
to this
	while True:
		time.sleep(1)
OutoftheBOTS
Wed Aug 09, 2017 7:37 am
I am a bit old school but my solution would have been def a routine that returns true or false. this routine needs to test if a button is pressed, if not pressed then return false if true then start a while loop while the button is true so that it will stay in this loop until the button is release then return true. Then the main program will take start time and set counter = 0 then have a while loop for start time + 5 secs and call the above routine and if true then counter +=1. After it exits the whil + 5 secs loop the value of counter will = the amount of tiem the button was pressed and released :)
MsCheesyPuff
Wed Aug 16, 2017 4:10 pm
In my original code, that was what I had but the button I'm using to count the button presses, I believe it's pulling ground, not allowing my LED to light up, why would this be? Here is my code for the button press and LED:
import time
import RPi.GPIO as GPIO
from time import sleep
from sys import exit
GPIO.setmode(GPIO.BCM)
GPIO.setwarnings(False)
GPIO.setup(20, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(17, GPIO.OUT)
GPIO.output(17, False)
debounce = 1000
ClickPeriod = 5000 #time period for presses in milliseconds
ClickCount = 0 #number of clicks in ClickPeriod
print ('LED ready')
while True:
    try:
        if (GPIO.input(20) == False):
            while (GPIO.input(20) == False):
                GPIO.output(17, True)
        sleep(1)
    except KeyboardInterrupt:
        print ('Clean Exit')
        exit()
GPIO.cleanup()
MsCheesyPuff
Tue Aug 22, 2017 12:56 am
My program is nearly complete but I'm having an issue. When I start the program, it waits for me to press the button then, it's supposed to count how many times I press it and return it to use in my main program. However, as I press the button to 'activate' it, the button press is automatically counted as 1 button press then 2 when I press it again later. But, I want to reset ClickCount so when I re-enter the button_timer() it starts counting button presses from 0 again. Here's my code:
import pygame.mixer
import datetime
GPIO.setup(21, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(19, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(7, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(8, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(9, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(10, GPIO.IN, pull_up_down=GPIO.PUD_UP)
GPIO.setup(13, GPIO.OUT)
GPIO.setup(6, GPIO.OUT)
GPIO.setup(5, GPIO.OUT)
GPIO.setup(24, GPIO.OUT)
GPIO.setup(23, GPIO.OUT)
GPIO.setup(27, GPIO.OUT)
GPIO.output(13, False)
GPIO.output(6, False)
GPIO.output(5, False)
GPIO.output(24, False)
GPIO.output(23, False)
GPIO.output(27, False)
ClickPeriod = 5000
ClickCount = 0
def button_timer():
    ClickPeriod = 5000
    while ClickPeriod > 0:
        ClickPeriod -= 0.20
        print ('Button Ready')
        global ClickCount
        ClickCount += 1
        return ClickCount
def lib_a():
    print ('Soundboard Lib A')
    pygame.mixer.init(48000, -16, 1, 1024)
    sound_1=pygame.mixer.Sound('/home/pi/Documents/PiSounds/applause.wav')
    sound_2=pygame.mixer.Sound('/home/pi/Documents/PiSounds/buzzer.wav')
    sound_3=pygame.mixer.Sound('/home/pi/Documents/PiSounds/castlethunder.wav')
    sound_4=pygame.mixer.Sound('/home/pi/Documents/PiSounds/clap.wav')
    sound_5=pygame.mixer.Sound('/home/pi/Documents/PiSounds/scream.wav')
    sound_6=pygame.mixer.Sound('/home/pi/Documents/PiSounds/scream2.wav')
    soundChannel1=pygame.mixer.Channel(1)
    soundChannel2=pygame.mixer.Channel(2)
    soundChannel3=pygame.mixer.Channel(3)
    soundChannel4=pygame.mixer.Channel(4)
    soundChannel5=pygame.mixer.Channel(5)
    soundChannel6=pygame.mixer.Channel(6)
    while True:
        try:
            if (GPIO.input(21) == False):
                soundChannel1.play(sound_1)
                while pygame.mixer.get_busy() == True:
                    GPIO.output(13, True)
                else:
                    GPIO.output(13, GPIO.LOW)
            if (GPIO.input(19) == False):
                soundChannel2.play(sound_2)
                    GPIO.output(6, True)
                else:
                    GPIO.output(6, GPIO.LOW)
            if (GPIO.input(7) == False):
                soundChannel3.play(sound_3)
                    GPIO.output(5, True)
                else:
                    GPIO.output(5, GPIO.LOW)
            if (GPIO.input(8) == False):
                soundChannel4.play(sound_4)
                    GPIO.output(24, True)
                else:
                    GPIO.output(24, GPIO.LOW)
            if (GPIO.input(9) == False):
                soundChannel5.play(sound_5)
                    GPIO.output(23,  True)
                else:
                    GPIO.output(23, GPIO.LOW)
            if (GPIO.input(10) == False):
                soundChannel6.play(sound_6)
                    GPIO.output(27,  True)
                else:
                    GPIO.output(27, GPIO.LOW)
                return
            sleep(1)
            exit()
    GPIO.cleanup()
def lib_b():
    print ('Soundboard Lib B')
    sound_7=pygame.mixer.Sound('/home/pi/Documents/PiSounds/buzzer.wav')
    sound_8=pygame.mixer.Sound('/home/pi/Documents/PiSounds/clap.wav')
    sound_9=pygame.mixer.Sound('/home/pi/Documents/PiSounds/scream.wav')
    sound_10=pygame.mixer.Sound('/home/pi/Documents/PiSounds/scream2.wav')
    sound_11=pygame.mixer.Sound('/home/pi/Documents/PiSounds/castlethunder.wav')
    sound_12=pygame.mixer.Sound('/home/pi/Documents/PiSounds/applause.wav')
    soundChannel7=pygame.mixer.Channel(1)
    soundChannel8=pygame.mixer.Channel(2)
    soundChannel9=pygame.mixer.Channel(3)
    soundChannel10=pygame.mixer.Channel(4)
    soundChannel11=pygame.mixer.Channel(5)
    soundChannel12=pygame.mixer.Channel(6)
    while True:
        try:
                soundChannel7.play(sound_7)
                else:
                soundChannel8.play(sound_8)
                else:
                soundChannel9.play(sound_9)
                else:
                soundChannel10.play(sound_10)
                else:
                soundChannel11.play(sound_11)
                else:
                soundChannel12.play(sound_12)
                else:
                return
            sleep(1)
            exit()
    GPIO.cleanup()
while True:
        button_timer()
        if ClickCount == 1:
            sleep(1)
            lib_a()
        if ClickCount == 2:
            sleep(1)
            sleep(1)
            sleep(1)
            lib_b()
        if ClickCount == 3:
            print ('Timeout')
            exit()
bensimmo
Tue Aug 22, 2017 9:35 am
You are defining ClickPeriod Twice, one outside and then once locally in the count ?
In button_timer...
Why make the count global, keep it in the function and just return the value.
Of course I've skimmed everything after that as cannot test it and it's not easy on a mobile to read.
MsCheesyPuff
Wed Aug 23, 2017 11:12 pm
How about doing it this way? The only problem I'm having with this is when I try to run it, I get this error :
TypeError: unsupported operand type(s) for +: 'datetime.datetime' and 'int'
def timer():
    print ('Ready')
    while True:
        try:
            SystemTime = datetime.datetime.now()
            ClickCount = 0
                CountDown = SystemTime
                while SystemTime <= CountDown + 5:
                        global ClickCount
                        ClickCount +=1
                    print ('ClickCount: ', ClickCount)
                    return ClickCount
Return to “Python”
Who is online
Users browsing this forum: No registered users and 20 guests
