RPi.GPIO not working with curses?
Posted: Sun Sep 30, 2012 5:22 pm
by karl101
I'm trying to write a python program that responds to a switch attached to GPIO pin 11, using the push button circuit from Mag Pi issue 2 http://www.themagpi.com/. Using the code in the magazine the button pressing works as expected, however when I try to do the same using python curses, nothing is displayed on screen, it doesn't seem to be reading the GPIO state.
Can anyone see what I'm doing wrong? I am using Python 2.7
#! /usr/bin/python
# -*- coding: utf-8 -*-
import RPi.GPIO as GPIO
import curses
GPIO.setup(11, GPIO.IN)
def swichtest():
    count = 0
    screen = curses.initscr()
    curses.noecho()
    curses.curs_set(0)
    screen.keypad(1)
    top = 2
    left = 0
    screen.addstr("Press a Little Button (or press 'q' to quit)")
    while True:
        mybutton = GPIO.input(11)
        if mybutton == False:
            count += 1
            screen.addstr(top, left, "Button Pressed")
        else:
            screen.addstr(top, left, "              ")
        event = screen.getch()
        if event == ord("q"):
            break
    curses.endwin()
    return count
if __name__ == "__main__":
    count = swichtest()
    print count, "fin."
Karl.
Re: RPi.GPIO not working with curses?
Posted: Sun Sep 30, 2012 7:20 pm
by Grumpy Mike
Are you sure what is being referred to as pin 11 is the same in both examples. It could be that one uses physical pin numbers and the other uses GPIO numbers.
Physical pin 11 has on it GPIO 17
Where as:-
GPIO 11 is on physical pin 23
Posted: Sun Sep 30, 2012 7:50 pm
by karl101
Grumpy Mike wrote:Are you sure what is being referred to as pin 11 is the same in both examples. It could be that one uses physical pin numbers and the other uses GPIO numbers.
Where as:-
No, the hardware is working, and it's connected to the correct GPIO pin. My non-curses test code works as expected:
from time import sleep
def dialtest():
    count = 0
    while True:
            count = count +1
            print "count ", count
            sleep(.2)
    return
    dialtest()
Karl.
Posted: Sun Sep 30, 2012 8:13 pm
by mister_wavey
is the first one still running when you test the curses one?
also, set the pin reference mode first. Later versions won't even run without it:
[email protected] ~/dev/curses $ sudo python cursestest.py
File "cursestest.py", line 6, in <module>
RPi.GPIO.ModeNotSetException: Please set mode using GPIO.setmode(GPIO.BOARD) or GPIO.setmode(GPIO.BCM)
Posted: Sun Sep 30, 2012 8:50 pm
by karl101
mister_wavey wrote:is the first one still running when you test the curses one?
Looks like I had an old version (v0.2) of RPi.GPIO so I didn't get that error. However upgrading to v0.3a from the apt repository and adding GPIO.setmode(GPIO.BOARD) before the pin designation has made no difference. The line 'Button Pressed' is not displayed when the switch is pressed but changing the non-curses version in a simmilar fashion works how I would expect.
Karl.
Posted: Sat Feb 23, 2013 11:21 am
by smiffydotcom
Considering the date of the original post, its probably sorted...
I'm having "similar issues" - but looking at your code example I cant see the line
refresh()
which I understand you have to include after writing to the curses screen...
Thanks for your code example though, its helped me :)
