leejohnson
Python code error but cant find it
Mon Jun 05, 2017 12:05 pm
Hey guys
Ive coded some web extraction tool for my website bassically gets game board information and ends up in excel. I have however got an error but cant seem to work it out could someone kindly cast their eyes over as mine are dead lol
# coding: utf-8
from __future__ import unicode_literals
from copy import copy
from .things import Thing
from .exceptions import BoardGameGeekError
from .utils import fix_url
   A boardgame retrieved from the collection information, which has less information than the one retrieved
    via the /thing api and which also contains some user-specific information.
    def __repr__(self):
        return "CollectionBoardGame (id: {})".format(self.id)
    def _format(self, log):
        log.info("boardgame id      : {}".format(self.id))
        log.info("boardgame name    : {}".format(self.name))
        log.info("last modified     : {}".format(self.lastmodified))
        log.info("rating            : {}".format(self.rating))
        log.info("own               : {}".format(self.owned))
        log.info("preordered        : {}".format(self.preordered))
        log.info("previously owned  : {}".format(self.prev_owned))
        log.info("want              : {}".format(self.want))
        log.info("want to buy       : {}".format(self.want_to_buy))
        log.info("want to play      : {}".format(self.want_to_play))
        log.info("wishlist          : {}".format(self.wishlist))
        log.info("wishlist priority : {}".format(self.wishlist_priority))
        log.info("for trade         : {}".format(self.for_trade))
    @property
    def lastmodified(self):
        return self._data.get("lastmodified")
    @property
    def last_modified(self):
        :return: last modified date
        :rtype: str
    @property
    def rating(self):
        :return: game rating
        :rtype: float
        :return: ``None`` if n/a
        return self._data.get("rating")
    @property
    def owned(self):
        :return: game owned
        :rtype: bool
        return bool(int(self._data.get("own", 0)))
    @property
    def preordered(self):
        :return: game preordered
        :rtype: bool
        return bool(int(self._data.get("preordered", 0)))
    @property
    def prev_owned(self):
        :return: game previously owned
        :rtype: bool
        return bool(int(self._data.get("prevowned", 0)))
    @property
    def want(self):
        :return: game wanted
        :rtype: bool
        return bool(int(self._data.get("want", 0)))
    @property
    def want_to_buy(self):
        :return: want to buy
        :rtype: bool
        return bool(int(self._data.get("wanttobuy", 0)))
    @property
    def want_to_play(self):
        :return: want to play
        :rtype: bool
        return bool(int(self._data.get("wanttoplay", 0)))
    @property
    def for_trade(self):
        :return: game for trading
        :rtype: bool
        return bool(int(self._data.get("fortrade", 0)))
    @property
    def wishlist(self):
        :return: game on wishlist
        :rtype: bool
        return bool(int(self._data.get("wishlist", 0)))
    @property
    def wishlist_priority(self):
        # TODO: convert to int (it's str)
        return self._data.get("wishlistpriority")
[docs]class BoardGame(Thing):
    Object containing information about a boardgame
    def __init__(self, data):
        kw = copy(data)
        # if we have any "expansions" for this item..
        if "expansions" not in kw:
            kw["expansions"] = []
        for to_fix in ["thumbnail", "image"]:
            if to_fix in kw:
                kw[to_fix] = fix_url(kw[to_fix])
        self._expansions = []           # list of Thing for the expansions
        self._expansions_set = set()    # set for making sure things are unique
        for data in kw["expansions"]:
            try:
                if data["id"] not in self._expansions_set:
                    self._expansions_set.add(data["id"])
                    self._expansions.append(Thing(data))
            except KeyError:
                raise BoardGameGeekError("invalid expansion data")
        # if this item expands something...
        if "expands" not in kw:
            kw["expands"] = []
        self._expands = []              # list of Thing which this item expands
        self._expands_set = set()       # set for keeping things unique
        for data in kw["expands"]:         # for all the items this game expands, create a Thing
            try:
                if data["id"] not in self._expands_set:
                    self._expands_set.add(data["id"])
                    self._expands.append(Thing(data))
            except KeyError:
                raise BoardGameGeekError("invalid expanded game data")
        self.boardgame_rank = None
        if "ranks" in kw:
            # try to search for the boardgame rank of this game
            for rank in kw["ranks"]:
                if rank.get("name") == "boardgame":
                    value = rank.get("value")
                    if value is None:
                    else:
                        self.boardgame_rank = int(value)
                    break
        super(BoardGame, self).__init__(kw)
    def __repr__(self):
        return "BoardGame (id: {})".format(self.id)
[docs]    def add_expanded_game(self, data):
        Add a game expanded by this one
        :param dict data: expanded game's data
        :raises: :py:exc:`boardgamegeek.exceptions.BoardGameGeekError` if data is invalid
        try:
                self._data["expands"].append(data)
        except KeyError:
[docs]    def add_expansion(self, data):
        Add an expansion of this game
        :param dict data: expansion data
        try:
                self._data["expansions"].append(data)
        except KeyError:
        log.info("boardgame rank    : {}".format(self.boardgame_rank))
        if self.alternative_names:
            for i in self.alternative_names:
                log.info("alternative name  : {}".format(i))
        log.info("year published    : {}".format(self.year))
        log.info("minimum players   : {}".format(self.min_players))
        log.info("maximum players   : {}".format(self.max_players))
        log.info("playing time      : {}".format(self.playing_time))
        log.info("minimum age       : {}".format(self.min_age))
        log.info("thumbnail         : {}".format(self.thumbnail))
        log.info("image             : {}".format(self.image))
        log.info("is expansion      : {}".format(self.expansion))
        if self.expansions:
            log.info("expansions")
            for i in self.expansions:
                log.info("- {}".format(i.name))
        if self.expands:
            log.info("expands")
            for i in self.expands:
        if self.categories:
            log.info("categories")
            for i in self.categories:
                log.info("- {}".format(i))
        if self.families:
            log.info("families")
            for i in self.families:
        if self.mechanics:
            log.info("mechanics")
            for i in self.mechanics:
        if self.implementations:
            log.info("implementations")
            for i in self.implementations:
        if self.designers:
            log.info("designers")
            for i in self.designers:
        if self.artists:
            log.info("artistis")
            for i in self.artists:
        if self.publishers:
            log.info("publishers")
            for i in self.publishers:
        log.info("users rated game  : {}".format(self.users_rated))
        log.info("users avg rating  : {}".format(self.rating_average))
        log.info("users b-avg rating: {}".format(self.rating_bayes_average))
        log.info("users commented   : {}".format(self.users_commented))
        log.info("users owned       : {}".format(self.users_owned))
        log.info("users wanting     : {}".format(self.users_wanting))
        log.info("users wishing     : {}".format(self.users_wishing))
        log.info("users trading     : {}".format(self.users_trading))
        log.info("ranks             : {}".format(self.ranks))
        log.info("description       : {}".format(self.description))
DirkS
Re: Python code error but cant find it
Mon Jun 05, 2017 1:51 pm
leejohnson wrote:I have however got an error
Please post the full error message
PeterO
Mon Jun 05, 2017 1:58 pm
Is this an algorithmic or syntactic error ?
PeterO
PeterO
Mon Jun 05, 2017 2:55 pm
supra wrote:
PeterO wrote:Is this an algorithmic or syntactic error ?
PeterO
Here is link:
https://github.com/commadelimited/boardgamegeek
Look for game.py in boardgamegeek's folder
No thanks.
PeterO
scotty101
Mon Jun 05, 2017 4:02 pm
I guess what PeterO is trying to say is that there is absolutely way that we can tell the OP how to fix their error unless we know what the error is!
Does python crash with a particular error message?
Or does the code just not work as expected? If so what does it do and what should it do.
Paeryn
Mon Jun 05, 2017 8:21 pm
leejohnson wrote:Hey guys
# coding: utf-8
    def __repr__(self):
For a start you've got the imports commented out so the following comment is now being parsed as code. Also this looks like it is meant to be part of a class, but no class definition.
Further on down you've got lines like this starting with [docs],
That's not valid Python.
Return to “Python”
