jebukaty
Executing a python script from web page
Thu May 18, 2017 9:12 pm
Hi, I was wondering if I could execute a python script from a web page. I have a adafruit motor hat on my pi that I use to control motors. And I use python to write the script for the motors. If someone could point me in the right direction to be able to execute this script from a web page that would be great, thanks.
alphanumeric
Re: Executing a python script from web page
Fri May 19, 2017 10:03 am
Why not just clip and past the code into idle (file new) and then save it as a local file? Then run it locally on the Pi.
davef21370
Fri May 19, 2017 4:34 pm
alphanumeric wrote:Why not just clip and past the code into idle (file new) and then save it as a local file? Then run it locally on the Pi.
Because that wouldn't be executing the scripts from a web page!
I'm no expert on this but found this with various suggestions http://stackoverflow.com/questions/4488 ... pts-on-the
stackoverflow.com is always a good place to start.
Dave.
Apple say... Monkey do !!
irab88
Fri May 19, 2017 5:14 pm
http://raspberrywebserver.com/cgiscript ... ry-pi.html
This is what I used for my project. While I used text boxes, you can use buttons, check boxes, and more.
Just be sure to set permissions to allow GPIO to be run from a non-root user:
(I wasn't having luck with Jessie, so I used Wheezy for my project)
-$usermod -a -G group user
adding "root", "pi" and "www-data" to the groups "kmem" and "dialout"
However, I was still having issues accessing GPIO, so I had to do the following:
-$sudo nano /etc/rc.local
chmod 777 /dev/mem
chmod 777 /dev/gpiomem
exit 0
(I know it's not the best practice, but it's a $35 hobby project; I'm not too concerned about security.)
ghp
Fri May 19, 2017 7:09 pm
web applications tend to grow. A nice approach to handle this is a python app server as e.g. tornado. See http://www.tornadoweb.org/en/stable/
Extend the sample from the main page with something which has a button and call a class which does something python-style.
As the app server is already in python, there is almost no barrier.
Hope this helps,
Gerhard
Return to “Python”
Who is online
Users browsing this forum: No registered users and 3 guests
