sefikTim
Disable exit button
Wed May 17, 2017 2:52 pm
I'm currently programming a GUI on Tkinter. I want the GUI to run 24/7 so therefor I need to remove/disable the X-button on the top right corner. Any suggestions on how I can do that. I'm using python 3 and the newest tkinter.
Davies
Re: Disable exit button
Wed May 17, 2017 3:22 pm
root = tk.Tk()
root.overrideredirect(True)
root.geometry("{0}x{1}+0+0".format(root.winfo_screenwidth(), root.winfo_screenheight()))
root.resizable(width=FALSE, height=FALSE)
this will disable close and window size buttons, disable screen resize and set your gui to whatever size the screen is, running full screen. (on python 2.7.. i havent used on 3.4+ yet)
root.overrideredirect(True) also prevents the application been closed by alt + F4 etc.
RogerW
Wed May 17, 2017 3:43 pm
I am not sure how to remove the X button but you can stop it doing anything.
import tkinter as tk
def donothing():
    pass
main = tk.Tk()
main.protocol('WM_DELETE_WINDOW',donothing)
main.mainloop()
Return to “Python”
Who is online
Users browsing this forum: No registered users and 23 guests
