JMV1998
SyntaxWarning is used prior to the global decleration
Tue May 16, 2017 7:41 pm
Hi I have been programming for a short period of time and do not know all the features of python in which I have come stuck with this warning. 'New_Item_Window' is used prior to global decleration.
I am unsure on how to tackle the problem any help would be greatly appreciated
scotty101
Re: SyntaxWarning is used prior to the global decleration
Tue May 16, 2017 8:44 pm
Posting your code would help.
but try something like
New_Item_Window = None
right at the very start of your code.
elParaguayo
Wed May 17, 2017 8:51 am
Agreed, we need your code but my guess is that you've got a variable called New_Item_Window in the main body of your script. You've then got function which tries to assign a value/manipulate to New_Item_Window. That will throw the error you're seeing unless your function includes the line "global New_Item_Window" before you try to manipulate the variable.
RPi Information Screen: plugin based system for displaying weather, travel information, football scores etc.
JMV1998
Thu May 18, 2017 1:24 pm
[quote="scotty101"]Posting your code would help.
Thank you, for your help i will look at this and get back to you
Thanks again,
Josh
Return to “Python”
Who is online
Users browsing this forum: scotty101 and 11 guests
