iggy1
How can I ignore checksum errors when using pynmea2?
Tue May 16, 2017 11:52 am
Hello world,
I am using pynmea2 with python 2 to control various flight-related things on a high-altitude balloon. However, my GPS data stream seems a bit flaky, and every so often, pynmea2 detects a checksum error and the program stops.
Here is a typical error message:
File "/home/pi/separate_gps_sms_test.py", line 145, in <module>
parseGPSGGA(string)
File "/home/pi/separate_gps_sms_test.py", line 17, in parseGPSGGA
msg = pynmea2.parse(string)
File "/usr/local/lib/python2.7/dist-packages/pynmea2/nmea.py", line 116, in parse
'checksum does not match: %02X != %02X' % (cs1, cs2), data)
ChecksumError: ('checksum does not match: 5C != 1B', ['', '112811.00', '5001.98613', 'N', '00841.70790', 'E', '1', '11', '1.12', '148.5', 'M', '47.6', 'M', '', ''])
How can I prevent this from happening? Any help appreciated, as reliability is crucial if we are going to recover the balloon.
Ilya
import serial
import time
import pynmea2
GPSDATA=0
TIME=0
LAT=0
LON=0
ALT=0
SPEED=0
time.sleep(1)
def parseGPSGGA(string):
    global GPSDATA,TIME,LAT,LON,ALT
    print "GPGGA received"
    if msg.gps_qual > 0 and msg.gps_qual < 6 and int(msg.num_sats) > 2:
        GPSDATA=1
        TIME = msg.timestamp
        LAT = msg.latitude
        LON = msg.longitude
        ALT = msg.altitude
    else:
        GPSDATA=0
    return
def parseGPSRMC(string):
    global SPEED
    print "GPRMC received"
    SPEED = str(msg.spd_over_grnd)
    if SPEED=="None":
        SPEED = 0
    else:
        SPEED = msg.spd_over_grnd
    SPEED = float(SPEED) * 1.852
    return
def sendSMS():
    global LOCATION,gsmsignal,PhoneNumber_1
    ser1 = serial.Serial("/dev/ttyUSBGSM", 9600, timeout=10)
    ser1.write('AT+CMGS=' + PhoneNumber_1 + '\r')
    time.sleep(1)
    ser1.write (LOCATION + ", GSM Signal: " + str(gsmsignal))
    ser1.write (chr(26))
    ser1.flushInput()
    ser1.close()
    return
# This section ensures that the program waits
# for the GPS and GSM module to boot and connect to the network
data = ""
previousaltitude = 0
time.sleep(10)
SMSCentre = '"+491770610000"'
PhoneNumber_1 = '"+4915201575169"'
# Open serial port (via USB) and flush all data in buffers
ser1 = serial.Serial("/dev/ttyUSBGSM", 9600, timeout = 0.5)
ser1.flushInput()
ser1.flushOutput()
time.sleep(0.5)
# The next line makes sure any "overhanging" SMS
# is sent and modem can accept commands
ser1.write(chr(26))
while True:
    ser1.write('AT\r')
    data = ser1.read(45)
    if data.find('OK') != -1:
        break
    time.sleep(1)
# Place SMS mode to 'text'
ser1.write("AT+CMGF=1\r")
# This sets up the SMS processing centre number (network specific)
ser1.write('AT+CSCA=' + SMSCentre + '\r')
time.sleep(1)
# Request GSM signal strength
csq = 'a,:b,:c'
# This inner loop ensures the data received is
# valid signal strength before parsing
while True:
    ser1.flushInput()
    ser1.write('AT+CSQ\r')
    time.sleep(0.5)
    csq = ser1.read(120)
    if csq.find('CSQ') != -1:
        break
print csq
csq = csq.split(":")
csq = csq[1].split(",")
gsmsignal = float(csq[0])
print 'GSM signal strength = ' + str(gsmsignal) + '\n'
#ser.close()
time.sleep(1)
ser0 = serial.Serial("/dev/ttyUSBGPS", 9600, timeout=10)
ser0.flushInput()
COUNT = 0
while True:
    ser0.flushInput()
    string = ser0.readline()
    if string.find('RMC') > 0:
        parseGPSRMC(string)
    if string.find('GGA') > 0:
        parseGPSGGA(string)
        if GPSDATA==1:
            ser0.close()
            COUNT += 1
            print COUNT
            LOCATION = "Timestamp: " + str(TIME) + ", Latitude: " + str(LAT) + "N" + ", Longitude: " + str(LON) + "W" + ", Altitude: " + str(ALT) + "m, Speed: " + str(SPEED) + "km/h"
            print LOCATION
# SAVE DATA TO FILE GOES HERE
            time.sleep(29)
            if COUNT == 10:
                while True:
                    ser1.flushInput()
                    time.sleep(0.5)
                        break
                print (csq)
                if gsmsignal > 7:
                    sendSMS()
                COUNT = 0
joan
Re: How can I ignore checksum errors when using pynmea2?
Tue May 16, 2017 12:12 pm
Python has a try/except syntax to deal with exceptions. I suggest you wrap the parse calls with try/except. You will have to decide how you deal with the error. It might be as simple as ignoring that record or returning the last good record.
iggy1
Tue May 16, 2017 12:39 pm
Cheers, that works a treat!
Return to “Python”
Who is online
Users browsing this forum: No registered users and 29 guests
