raymondlee306
Software PWM for beginner
Tue May 16, 2017 1:53 am
Hi Everyone. First time playing with Python and 1st time posting. I'm trying to use software PWM to control two servos independently. I'm okay with a little "jitter" for this project and plan to add an PCA9685 driver later down the road but I'm trying to do this for the time being. I have the left servo working great following some tutorials I found. It behaves exactly like I want in the for loop. The problem comes when I try to split the loop to control the left and right servos either together or on delays from each other. So two question I guess...can the GPIO run two PWM at the same time? and what's the best way to modify the code below to control another servo within the same loop. Or a separate loop but at the same time as the first loop (that would work too)
Thanks In Advance,
import RPi.GPIO as GPIO
import time
GPIO.setwarnings(False)
GPIO.setmode(GPIO.BOARD)
leftpin = 11
rightpin = 13
GPIO.setup(leftpin, GPIO.OUT)
GPIO.setup(rightpin, GPIO.OUT)
freq = 50
pwmleft = GPIO.PWM(leftpin, freq)
pwmright = GPIO.PWM(leftpin, freq)
left_up = 0.75
left_rev = 2.5
left_down = (left_rev- left_up) / 2 + left_up
right_up = 2.5                      #servo is 180 degrees from left, hence DC reversed
right_rev = 0.75                   #servo is 180 degrees from left, hence DC reversed
right_down = (right_up - right_rev) / 2 + right_rev                 #servo is 180 degrees from left, hence DC reversed
positionlistleft = [left_up, left_down]
positionlistright = [right_up, right_down]
mpc_left = 1000 / freq
mpc_right = 1000 / freq
for i in range(3):
    for positionleft in positionlistleft:                       #I have tried adding a new line here with "right" in place of "left"
        dcpleft = positionleft * 100 / mpc_left          #I have tried adding a new line here with "right" in place of "left"
        pwmleft.start(dcpleft)                                     #I have tried adding a new line here with "right" in place of "left"
        time.sleep(1)
pwmleft.stop()
GPIO.cleanup()
ghp
Re: Software PWM for beginner
Tue May 16, 2017 4:41 am
the rpi.gpio module is able to have multiple pwm active, each for a separate gpio-pin.
Your code does not fully follow this definition:
the second line should be
pwmright = GPIO.PWM(rightpin, freq)
Your approach to use arrays to store the target positions is a nice idea.
You could solve your problem by
# define servo pos 0..100 range (easy to read)
leftList  = [   0,  10,  20,  30,  40,  60, 100 ]
rightList = [ 100,  60,  40,  30,  20,  10,   0 ]
# start with 50%
pwmRight = GPIO.PWM(rightPin, 50)
pwmLeft = GPIO.PWM(leftPin, 50)
pwmRight.start(7.5)
pwmLeft.start(7.5)
for i in range ( len(leftList)):
    print ( leftList[i])
    print ( rightList[i])
    # pwm pulse width is 1 to 2 ms in 20 ms cycle,
    # which is 5% to 10%
    pLeftValue = float(100.0 + leftList[i]) / 20.0
    pRightValue = float(100.0 + rightList[i]) / 20.0
    print ( pLeftValue )
    print ( pRightValue )
    pwmLeft.ChangeDutyCycle(pLeftValue)
    pwmRight.ChangeDutyCycle(pRightValue)
    # sleep a while
The trick is to use an index variable (here 'i') to grab values from both arrays.
Hope this helps,
Gerhard
joan
Tue May 16, 2017 4:42 am
RPi.GPIO has a software PWM class which is implemented using threads. You could use that.
Alternatively use something like servoblaster or (my) pigpio which provide hardware timed PWM pulses suitable for servos on GPIO 0-31.
See http://abyz.co.uk/rpi/pigpio/python.htm ... pulsewidth
raymondlee306
Tue May 16, 2017 10:34 am
Thank you both very much. I'll read through this and try some of it after work tonight.
Return to “Python”
Who is online
Users browsing this forum: No registered users and 10 guests
