python /home/pi/Documents/Monkey\ Studio/Projects/metro_uic.py
File "/home/pi/Documents/Monkey Studio/Projects/metro_uic.py", line 10, in <module>
from mainwindow import MainWindow
File "/home/pi/Documents/Monkey Studio/Projects/mainwindow.py", line 12, in <module>
from UserData import UserData
File "/home/pi/Documents/Monkey Studio/Projects/UserData.py", line 10, in <module>
Ui_InputWindow, QtBaseClass = uic.loadUiType(InputWindow)
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/__init__.py", line 210, in loadUiType
winfo = compiler.UICompiler().compileUi(uifile, code_string, from_imports, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/Compiler/compiler.py", line 139, in compileUi
w = self.parse(input_stream, resource_suffix)
File "/usr/lib/python2.7/dist-packages/PyQt4/uic/uiparser.py", line 984, in parse
document = parse(filename)
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 1182, in parse
tree.parse(source, parser)
File "/usr/lib/python2.7/xml/etree/ElementTree.py", line 647, in parse
source = open(source, "rb")
IOError: [Errno 2] No such file or directory: 'datainput.ui'
