aitorman
python hangs on serial write()
Wed Apr 19, 2017 9:50 am
Using the Pi Zero W, Jessie Lite and python3, whenever I try to write to /dev/ttyAMA0 python hangs indefinitely (longer than the set timeout). When I stop it with Ctrl-C this is the message I get:
File "/usr/local/lib/python3.4/dist-packages/serial/serialposix.py", line 553, in write
    abort, ready, _ = select.select([self.pipe_abort_write_r], [self.fd], [], None)
This happens both in the python shell and when running it as a script, and I have disabled the serial console in raspi-config. This is the code I'm using, although I've tried many:
import serial
port = serial.Serial("/dev/ttyAMA0", baudrate=115200, timeout=3.0)
port.write(b'A')
Could this be a hardware issue? The pi fell on the ground once when I took it out of the box, but I don't want to buy a new one before making sure it isn't a software issue.
aitorman
Re: python hangs on serial write()
Wed Apr 19, 2017 11:01 pm
supra wrote:
aitorman wrote:Using the Pi Zero W, Jessie Lite and python3, whenever I try to write to /dev/ttyAMA0 python hangs indefinitely (longer than the set timeout). When I stop it with Ctrl-C this is the message I get:
import serial
port.write(b'A')
Add
port.close()
Put this at bottom
That makes no difference, since the program hangs on the write() call before reaching the bottom.
torus
Thu Apr 20, 2017 5:02 pm
I have the same issue on a freshly installed Ubuntu 17.04 64-bit with Python 2.7. I run a Python script communicating with an Arduino Uno through a custom protocol running over serial communication, and my script freezes after few hundred of exchanges ...
The same script was working perfectly for days when it was running on Ubuntu 16.10 ...
dgordon42
Sat Apr 22, 2017 10:58 am
Try changing all instances of "/dev/ttyAMA0" to "/dev/serial0" in your code.
That's 'serialZero', not 'serialOh'.
By default on a Pi Zero W, '/dev/ttyAMA0' is reserved by the system to talk to the Bluetooth Controller.
The 'serial0' alias is the new way to address the Serial Port, and should work on all Pi models running up to date Raspbian.
Hope this helps,
Dave.
aitorman
Sun Apr 23, 2017 7:30 pm
dgordon42 wrote:Try changing all instances of "/dev/ttyAMA0" to "/dev/serial0" in your code.
Hope this helps,
Dave.
That worked perfectly, thanks
chikiball
Fri Jan 12, 2018 3:05 pm
Hi, I am still having this issue where the serial.write() hangs
I did:
- put enable_serial=1 in /boot/config.txt
- add serial.close() method at the end of the code
- change to /dev/serial0 or /dev/serial1 instead of /dev/tty0 or /dev/ttyAMA0
currently if i do ls -l /dev/serial* the result would be
/dev/serial0 -> ttyS0
/dev/serial1 -> ttyAMA0
any help would be appreciated
dgordon42
Fri Jan 12, 2018 5:17 pm
Post the output from:
grep -v -e ^$ -e ^# /boot/config.txt
and
cat /boot/cmdline.txt
Hanging serial ports are sometimes caused by reading or writing to a port that's already in use.
Dave.
kibria
Sun Jan 21, 2018 10:07 pm
Hope this helps,
Dave.
Thanks Mate.You saved my night :P
EricSalemi
Sun Feb 04, 2018 9:39 am
The "timeout" option does not apply to write operations. You should use "write_timeout" option instead.
http://pyserial.readthedocs.io/en/lates ... l_api.html
dsimonet
Fri Aug 17, 2018 7:47 am
mine did the same thing until I changed in boot/config.txt
enable_uart=0
to
enable_uart=1
NB: On raspi zero W
Return to “Python”
Who is online
Users browsing this forum: buja and 6 guests
