RGhosh99
SIM 808 GSM module with Raspberry Pi
Wed Mar 29, 2017 1:10 pm
Can SIM 808 GSM module be used with Raspberry Pi for sending sms and making calls from Pi ?
If yes, can anyone help me with the Python code for that ?
pieman82
Re: SIM 808 GSM module with Raspberry Pi
Wed Mar 29, 2017 2:17 pm
The SIM808 is intented to be used as a GSM modem, to my best knowledge. This means that you can use it for creating an internet connection from your PI. There is a lot of documentation on how to setup the SIM808 (or other similar modems), to be used with the RPI, here is one:
https://www.cooking-hacks.com/documenta ... -tutorial/
And here is one for the 908 (which should be similar in interface):
http://projects-raspberry.com/geolocati ... pberry-pi/
You would have to write a small program program to do the texting. I would use a third-party sms gateway provider, like this:
https://www.clockworksms.com/
But there are many others similar to this.
Good luck with your project, it sound like great fun :-)
Raspberry Pi for your car? AutoPi.io connects your car with the cloud
https://www.autopi.io
drops
Mon Jan 07, 2019 6:28 pm
I purchased a sim 808 and connected to a pi. Inserted a sim, powered up.
I get a AT command OK, but it doesn't register to network( I waited more than a few minutes). I get +CGREG: 0,0
Ahy ideas please?
Return to “Python”
